Old 13th June 2010, 10:17   #10121  |  Link
nibus
Telewhining
What are the advantages of demuxing with eac3to rather than another decoder like DGIndex, DGAVCIndex, or DGdecNV?
nibus is offline
Old 13th June 2010, 10:31   #10122  |  Link
nurbs
Audio handling when the movie comes in multiple files is better with eac3to especially if you convert the audio directly with it. eac3to detects and corrects gaps and overlaps as good as possible when you demux or entirely when you reencode.
nurbs is offline
Old 13th June 2010, 12:22   #10123  |  Link
AnryV
About decoding DTS-HD MA 6.1 and TrueHD 6.1:
1) Decoding by the Arcsoft decoder gives the garbage
2) Decoding by the Sonic decoder gives normal wavs, but the order of the surraund and back center channels is changed. After decoding it is necessary to make the following renamings: SL -> SR, SR -> BACK (BC), BC -> SL.
The decoding of TrueHD 6.1 16 bit has the same error in spite of the use of another decoder (libav).
AnryV is offline
Old 13th June 2010, 15:54   #10124  |  Link
Inspector.Gadget
With movie Van Helsing Arcsoft Total Media Teather show me 37 subtitles, but eac3to only list 32 subtitles, 5 last ones are absent.
eac3to, in my experience, is smart about detecting authoring oddities on Blu-ray discs that throw off other software. How many subtitles are actually accessible through the disc's subtitles menu? Be aware also that subtitles may correspond to images used for picture-in-picture or trivia content and not actually be "subtitles" in the traditional sense.
Inspector.Gadget is offline
Old 13th June 2010, 16:34   #10125  |  Link
alfixdvd
The disc's subtitles menu with Arcsoft Totalmedia Teather show 37 subtitles, and activate #36 that are the forced.
eac3to only shows 32, also tsMuxerR shows 32 but says there are some tracks not recognized that don't show. Perhaps they are the five subtitles streams absents.
BdInfo also shows only 32 subtitles streams, but Arcsoft Totalmedia Theater shows 37 and activate #36
How to extract them?
alfixdvd is offline
Old 13th June 2010, 17:25   #10126  |  Link
Inspector.Gadget
I'm asking about the graphical menu on the disc, not the Arcsoft context menu. Is that the one you're talking about?
Without the disc in front of me, I can't say. Maybe someone else can check.
Old 13th June 2010, 23:52   #10127  |  Link
alfixdvd
Yes I'm talking about Arcsoft context menu.
The graphical menu on the disk only shows 14 subtitles
eac3to, tsmuxerR and BdInfo shows 32, the Arcsoft context menu shows 37
alfixdvd is offline
Old 14th June 2010, 00:12   #10128  |  Link
Inspector.Gadget
Trust the disc, not the context menu.
Old 14th June 2010, 06:20   #10129  |  Link
setarip_old
setarip_old's Avatar
@alfixdvd
Hi!
The following link will provide a multitude of what I believe to be pertinent posts made in the BD-Rebuilder sub-forum regarding this topic:
http://forum.doom9.org/search.php?searchid=5253964
setarip_old is offline
Old 14th June 2010, 10:33   #10130  |  Link
alfixdvd
Originally Posted by setarip_old View Post
@alfixdvd
Hi!
The link says "Sorry - no matches"
What's the criteria for search, please ?
alfixdvd is offline
Old 14th June 2010, 20:52   #10131  |  Link
mrr19121970
alfixdvd is right, the mpls does have 5 extra subpath pids 0x1800 onwards. i've no idea how to help him further though.
mrr19121970 is offline
Old 14th June 2010, 21:02   #10132  |  Link
setarip_old
@alfixdvd
Sorry about that.
Go to:
http://forum.doom9.org/showthread.php?t=143716
Click on the "Search this thread" tab and enter as one line, including quotation marks: "Mummy" and "subtitles"
Old 14th June 2010, 22:15   #10133  |  Link
alfixdvd
@alfixdvd
Sorry about that.
Go to:
Thanks, reading at the thread I reached http://forum.doom9.org/showthread.php?t=146501
alfixdvd is offline
Old 14th June 2010, 22:18   #10134  |  Link
alfixdvd
Problem solved, thanks to deank's explanations at thread :http://forum.doom9.org/showthread.php?t=146501
alfixdvd is offline
Old 14th June 2010, 22:58   #10135  |  Link
setarip_old
@alfixdvd
Glad to hear that I may have steered you in the right direction ;>}
Old 14th June 2010, 23:45   #10136  |  Link
crasus
Why the difference in the second and third audio tracks, in regards to bitrate and channels upon detection?
Using latest versions of both software.
vs
crasus is offline
Old 16th June 2010, 16:22   #10137  |  Link
Wojszwillo
Can anybody confirm this information?
I need to decode DTS-HD MA 6.1 to wav's but now im not sure...
Wojszwillo is offline
Old 16th June 2010, 23:03   #10138  |  Link
tebasuna51
tebasuna51's Avatar
No, but try yourself
tebasuna51 is offline
Old 17th June 2010, 09:09   #10139  |  Link
ACrowley
No, DTS HD 6.1 via Arcsoft and TrueHD 6.1 via libav should be fine
I had few 6.1 Tracks without Problems
ACrowley is offline
Old 17th June 2010, 09:15   #10140  |  Link
AnryV
It can be easily confirmed - try to encode DTS-HD MA 6.1 16-bit descrete by DTS-HD Master Audio Suite Encoder from some test wavs.
As example - Blu-ray "Evangelion 2.22".
AnryV is offline
eac3to
