10th April 2006, 21:13 | #381 | Link |
@cc979: I dunno.... if I turned resizing off, I wouldn't want it to turn back on when I selected my cropping. You have a point, though.
@all: Yep, I am considering doing that implicit avs creation. There needs to be some way to smoothly integrate the two, so if people can come up with some ideas, that would be great. The way that I thin the implicit avs creation would work would not be like AutoGK, as shon3i said, but simply a single input line. So, if you load a video file, then MeGUI creates an avs that has a DirectShowSource call (or AviSource, etc), with no resizing or cropping. If you want to configure it yourself, then you (somehow) tell MeGUI to open this with the AviSynth script creator, and if you want AutoGK-style automated script generation, you use the One Click Encoder (this could do with some extension, to support directshowsource files for input -- perhaps using the MediaInfo lib for track information). Last edited by berrinam; 10th April 2006 at 21:18. |
10th April 2006, 22:01 | #382 | Link |
Curious BetaTester
@berrinam ... if autocrop is used and resizer is disabled maybe increase the crop so it is a mod of 16 or re-enable the resize or give a choice
depends on the encode maybe
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
11th April 2006, 01:52 | #383 | Link | |
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Live long and prosperLive long and prosperLive long and prosper |
11th April 2006, 02:14 | #384 | Link |
Does it really matter?
your basically the same person so whatever. Besides ignoring the technical reasons for this MeGUI is NOT Virtualdub. Re-read a few of my posts and you'll understand why implementing it will be not worth the effort.
11th April 2006, 02:47 | #385 | Link |
Angel of Night
If you need a virtualdub for newer formats, please, use avidemux! It was made to be a virtualdub-style editor for them. MeGUI is just an encoder that levarages smart algorithms and the power of avisynth to make your encoding easier, but it will never be an NLE.
11th April 2006, 10:08 | #386 | Link |
clueless n00b
Here's the only thing that makes sense from a programmer's perspective: relax the filter to other types. If the file selected has the extension .avs, everything works as normal. If the extension is .avi, megui writes a new avs named yourmovie.avi.avs containing:
avisource("yourmovie.avi") and loads that avs. The avs is written in the same directory as the avi. If the extension is anything else, the avs written has the same naming system, but instead contains directshowsource("yourmovie.extension") But for megui, there's only avs and anything that goes beyond that would be a major effort - that time is better invested into something else. Also keep in mind a directshowsource call without fps is dangerous.. but it's the only thing that can be done because we can't just get fps info from an arbitrary file unless either writing parsers for X different containers, or start messing with directshow (render the file and hopefully the fps can be gotten from that). But in the input window, you still only have avs shown, and you cannot use the typing facility to manually put a non avs filename there.. that would already turn things too complicated again.
11th April 2006, 10:22 | #387 | Link | |
EDIT: Done. It is a very stupid script generator, and it won't deal with any problems like flipped video. If you run into them that's your problem -- use the Avisynth script creator which is designed to deal with all of that. Last edited by berrinam; 11th April 2006 at 10:48. |
18th April 2006, 12:29 | #388 | Link |
"Shutdown when finished" is going onto my mind
I don't think there's any user who wants to go on with the shutdown when he aborts a job manually. Besides that, a timed interception possibility would be useful, just in case. (Encodes packed with filters take so long that one might forget that the option has been set.) Last edited by faxmactor; 18th April 2006 at 15:25. |
19th April 2006, 15:35 | #389 | Link |
BluRay Maniac
I can't belive MeGUI finally looks like a big app for multiformat encoding, all greetings to MeGUI devs, but you miss only one big thing. That's thing is 5.1 audio encoding. I know MeGUI supports 5.1 encoding for both BeSweet and AviSynth, but encoders is very bad. Nero and FAAC need bitrate like AC3 to sounds normaly. So only one encoder is good for 5.1 HE encoding and we know is that Coding Tehnologies (Winamp). Thanks to Dimzon and his encAACPlus.exe comandline encoder, encoding is very sipmply. New Nero encoder shall to be out in few months which all bugs in 5.1 encoding is cleared but until now you can add support for CT becouse is aslo good in stereo encoding. CT now support both LC and HE profiles, aslo LC encoder support 8-320kbs, HE 8-320kbs, 6ch HE 96-213kbs which all bitrates good for 1cd rips especialy 96-128, and 128-213 is good for 2 or more cd's, aslo LC supports 6ch. Thanks
EDIT: Encoding via BeSweet have no sense, so clear your agony and remove it form MeGUI Last edited by shon3i; 19th April 2006 at 15:39. |
19th April 2006, 15:42 | #390 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
19th April 2006, 16:03 | #391 | Link |
BluRay Maniac
@dimzon thanks anyway. When you back to url can you start working on this. I am not sure but i don't now how nero distribute their new aac codec, Ivan told that will be new distribution and maybe limitation over encoding.
25th April 2006, 15:31 | #392 | Link |
Curious BetaTester
@berrinam
just had time to do some testing (0.2.3.2129 20 April 2006) good job on the mod16 stuff just a little feature when encoding an .avs maybe have script preview window, incase some forget which what they are encoding
28th April 2006, 04:25 | #393 | Link |
Mr. Woof
I would like to request the addition of MP3 audio support in MP4 muxing operation. I realize AAC is the favored choice and perhaps the better one, but nonetheless if MP3 is supported in the container format, I think megui should be able to do it, and this shouldn't be a big deal to add.
28th April 2006, 08:40 | #395 | Link |
clueless n00b
@berrinam: if not already done, all that needs to be done to support that is adding the mp3 audio type as supported audio type.. I may have even already done it. Then of course there's the matter of making the mux windows muxer aware to they allow you to select input types that the muxer supports..
3rd May 2006, 15:56 | #397 | Link |
Flying Skull
Small ease of use request: when using file dialogues to open souce audio files for encoding, please treat Avisynth files (.avs) as an audio format along with .ac3, .dts etc. I create quite a few combined audio/video scripts to retime PAL movies to 24fps, so I often have avisynth as an audio source.
3rd May 2006, 15:59 | #398 | Link |
That however would be undetectable as to you having audio in the avs script. so it would be pointless.
you can't encode audio and video together and change the audio format. just won't work. Audio must be encoded separately. if you had a completely separate avs for audio it would be another matter. |
3rd May 2006, 16:16 | #399 | Link |
Flying Skull
* confused *
I do mean to encode the audio separately. Perhaps I should give an example. Say I have externally created an avisynth script called deadwood3.avs which has 24fps audio and video streams: LoadPlugin("C:\Program Files\DGMPGDec\dgdecode.dll") loadplugin("C:\Program Files\avisynth 2.5\plugins\NicAudio.dll") video=mpeg2source("C:\MyDox\My Videos\Staging\Deadwood 3\VTS_01_1.d2v",cpu=4) audio=nicac3source("VTS_01_1 T01 3_2ch 448Kbps DELAY 0ms.ac3",2) audiodub(video,audio) AssumeFPS(24,1,true) SSRC(48000,false) I open it once as a video source and again as a sound source, maybe using "AutoEncode" to do the mux as well, to get 2 or 3 related jobs. I open it as video as normal on th emain input tab, no problem. Then I in the main input tab I click on the "..." button to the right of the audio input filename. That launches the "Select your audio input" dialogue. In the bottom drop-list on that dialogue, labelled "Files of type", I can choose "Supported audio formats" {default}, "AC3 audio", "DTS audio", "MPEG audio", "WAV audio", and "All Files (*.*). At them moment, I have to choose "All Files" to open an avisynth file like deadwood3.avs as my source sound file. I would like to see "Avisynth Audio" added to the list of audio file types, and for it to fall within "Supported audio formats" so that avisynth files appear when I first launch the "Select your audio input" dialogue. {edit} It would also be quite useful if the audio input box on the main Input tab accepted avs files via drag and drop, like it accepts ac3 etc. [I'm referring to versions 0.2.3.2065 and 0.2.3.2127, if that matters. I've encoded over 100 files this way, generally to x264/FAAC.] Last edited by Morte66; 3rd May 2006 at 18:31. |
