Old 15th October 2020, 16:23   #3641  |  Link
Selur
Selur's Avatar
might be a bug in 'minimize command line', not totally sure, will look at it when the debug output is approved,...
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 15th October 2020, 17:01   #3642  |  Link
Selur
Selur's Avatar
defaults:
x265 --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --qpfile GENERATED_QP_FILE --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix unknown --output OUTPUTFILE
activated hevc-ac:
x265 --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --qpfile GENERATED_QP_FILE --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --hevc-aq --no-cutree --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix unknown --output OUTPUTFILE
set psy-rd to 0:
x265 --tune psnr --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --qpfile GENERATED_QP_FILE --limit-refs 0 --ssim-rd --rdoq-level 2 --psy-rdoq 10.00 --hevc-aq --no-cutree --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix unknown --output OUTPUTFILE
-> used encoding call:
ffmpeg -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0  -f yuv4mpegpipe - | x265 --tune psnr --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --limit-refs 0 --ssim-rd --rdoq-level 2 --psy-rdoq 10.00 --hevc-aq --no-cutree --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt470bg --output "E:\Temp\2020-10-15@17_37_08_9710_01.265"
results in:
x265 [info]: HEVC encoder version 3.4+26-ga82c6c7a7
x265 [info]: build info [Windows][GCC 10.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 10 profile, Level-2.1 (Main tier)
x265 [info]: Thread pool created using 16 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 4 / wpp(6 rows)
x265 [warning]: Source height < 720p; disabling lookahead-slices
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : hex / 57 / 2 / 3
x265 [info]: Keyframe min / max / scenecut / bias  : 25 / 250 / 40 / 5.00
x265 [info]: Cb/Cr QP Offset                     : -2 / -2
x265 [info]: Lookahead / bframes / badapt        : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 3 / off / off
x265 [info]: Rate Control / qCompress            : CRF-18.0 / 0.60
x265 [info]: tools: limit-modes rd=3 ssim-rd rdoq=2 psy-rdoq=10.00 rskip mode=1
x265 [info]: tools: signhide tmvp b-intra strong-intra-smoothing
x265 [info]: tools: deblock(tC=-1:B=-1) sao
there is no info that hevc-aq would be ignored,...
MediaInfo reports:
Writing library                          : x265 3.4+26-ga82c6c7a7:[Windows][GCC 10.2.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=640x352 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=0 / limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=10.00 / no-rd-refine / no-lossless / cbqpoffs=-2 / crqpoffs=-2 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=64 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
-> 'no-hevc-aq'
hevc-aq documentaion:
--hevc-aq
Enable adaptive quantization It scales the quantization step size according to the spatial activity of one coding unit relative to frame average spatial activity. This AQ method utilizes the minimum variance of sub-unit in each coding unit to represent the spatial complexity of the coding unit.
source: https://x265.readthedocs.io/en/lates...option-hevc-aq
disabling 'minimize command line' results in:
x265 --frame-threads 0 --wpp --no-pmode --no-pme --log-level 2 --input - --output-depth 10 --y4m --profile main10 --high-tier --min-cu-size 8 --ctu 64 --qg-size 32 --no-opt-cu-delta-qp --tu-intra-depth 1 --tu-inter-depth 1 --limit-tu 0 --max-tu-size 32 --no-hme --me hex --subme 2 --merange 57 --no-analyze-src-pics --limit-modes --no-rect --no-amp --max-merge 3 --no-early-skip --rskip 1 --temporal-mvp --rdpenalty 0 --no-tskip --strong-intra-smoothing --no-constrained-intra --no-open-gop --gop-lookahead 0 --scenecut 40 --scenecut-bias 5 --no-scenecut-aware-qp --no-hist-scenecut --opt-ref-list-length-pps --keyint 250 --min-keyint 0 --max-ausize-factor 1 --radl 0 --bframes 4 --no-weightb --no-b-intra --bframe-bias 0 --b-adapt 2 --b-pyramid --ref 3 --weightp --rc-lookahead 20 --slices 1 --lookahead-threads 0 --qpstep 4 --qpmin 0 --qpmax 69 --qblur 0.50 --cplxblur 20.0 --crf 18.00 --opt-qp-pps --no-rc-grain --cbqpoffs -2 --crqpoffs -2 --ipratio 1.4 --pbratio 1.3 --nr-intra 0 --nr-inter 0 --qpfile GENERATED_QP_FILE --limit-refs 0 --rd 3 --no-fast-intra --ssim-rd --no-rd-refine --no-psy-rd --rdoq-level 2 --psy-rdoq 10.00 --signhide --no-splitrd-skip --qcomp 0.60 --qp-adaptation-range 1 --no-aq-motion --aq-mode 0 --hevc-aq --no-cutree --no-const-vbv --vbv-maxrate 0 --vbv-bufsize 0 --vbv-init 0.9 --vbv-end 0.000 --no-hrd --no-aud --info --no-idr-recovery-sei --deblock=-1:-1 --sao --selective-sao 4 --no-sao-non-deblock --limit-sao --no-repeat-headers --no-temporal-layers --log2-max-poc-lsb 8 --no-fades --no-psnr --no-ssim --no-interlace --range limited --colormatrix bt470bg --no-single-sei --no-hdr10 --output "E:\Temp\test.265"
and
ffmpeg -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0  -f yuv4mpegpipe - | x265 --frame-threads 0 --wpp --no-pmode --no-pme --log-level 2 --input - --output-depth 10 --y4m --profile main10 --high-tier --min-cu-size 8 --ctu 64 --qg-size 32 --no-opt-cu-delta-qp --tu-intra-depth 1 --tu-inter-depth 1 --limit-tu 0 --max-tu-size 32 --no-hme --me hex --subme 2 --merange 57 --no-analyze-src-pics --limit-modes --no-rect --no-amp --max-merge 3 --no-early-skip --rskip 1 --temporal-mvp --rdpenalty 0 --no-tskip --strong-intra-smoothing --no-constrained-intra --no-open-gop --gop-lookahead 0 --scenecut 40 --scenecut-bias 5 --no-scenecut-aware-qp --no-hist-scenecut --opt-ref-list-length-pps --keyint 250 --min-keyint 0 --max-ausize-factor 1 --radl 0 --bframes 4 --no-weightb --no-b-intra --bframe-bias 0 --b-adapt 2 --b-pyramid --ref 3 --weightp --rc-lookahead 20 --slices 1 --lookahead-threads 0 --qpstep 4 --qpmin 0 --qpmax 69 --qblur 0.50 --cplxblur 20.0 --crf 18.00 --opt-qp-pps --no-rc-grain --cbqpoffs -2 --crqpoffs -2 --ipratio 1.4 --pbratio 1.3 --nr-intra 0 --nr-inter 0 --limit-refs 0 --rd 3 --no-fast-intra --ssim-rd --no-rd-refine --no-psy-rd --rdoq-level 2 --psy-rdoq 10.00 --signhide --no-splitrd-skip --qcomp 0.60 --qp-adaptation-range 1 --no-aq-motion --aq-mode 0 --hevc-aq --no-cutree --no-const-vbv --vbv-maxrate 0 --vbv-bufsize 0 --vbv-init 0.9 --vbv-end 0.000 --no-hrd --no-aud --info --no-idr-recovery-sei --deblock=-1:-1 --sao --selective-sao 4 --no-sao-non-deblock --limit-sao --no-repeat-headers --no-temporal-layers --log2-max-poc-lsb 8 --no-fades --no-psnr --no-ssim --no-interlace --range limited --colormatrix bt470bg --no-single-sei --no-hdr10 --output "E:\Temp\2020-10-15@17_44_14_4510_01.265"
results in:
x265 [info]: tools: signhide tmvp strong-intra-smoothing deblock(tC=-1:B=-1)
x265 [info]: tools: sao
MediaInfo report:
cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=640x352 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=0 / limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=10.00 / no-rd-refine / no-lossless / cbqpoffs=-2 / crqpoffs=-2 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=64 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
-> 'hevc-aq'
so it's an issue with 'minimize command line'.
so looking at command line before setting psy-rd to zero:
and with psy-rd to 0:
before: --psy-rd 2.50 --aq-mode 0 --hevc-aq
after: --tune psnr -hevc-aq
checking tune psnr:
if (!strcmp(tune, "psnr"))
    param->rc.aqStrength = 0.0;
    param->psyRd = 0.0;
    param->psyRdoq = 0.0;
see: https://bitbucket.org/multicoreware/...mmon/param.cpp (line 566-571)
so: "--aq-strength 0 --psy-rd 0 --psy-rdoq 0"
since "--aq-strength 0" should be the same as "--aq-mode 0".
now looking again at before and after:
after: --tune psnr --hevc-aq = --aq-mode 0 --psy-rd 0 --psy-rdoq 0 --hevc-aq
since after also has '--psy-rdoq 10.00'
after = --aq-mode 0 --psy-rd 0 --psy-rdoq 10.00 --hevc-aq
-> don't see where Hybrid is making a mistake. those command lines should be identical unless '--tune psnr' has other side effect that I don't know about.
Cu Selur
Old 15th October 2020, 17:12   #3643  |  Link
Selur
Selur's Avatar
removing command line minimization for 'tune', Hybrid would use:
x265 --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --qpfile GENERATED_QP_FILE --limit-refs 0 --ssim-rd --no-psy-rd --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --hevc-aq --no-cutree --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt470bg --output OUTPUTFILE
and
ffmpeg -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "F:\TestClips&Co\files\test.avi" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0  -f yuv4mpegpipe - | x265 --input - --output-depth 10 --y4m --profile main10 --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2 --limit-refs 0 --ssim-rd --no-psy-rd --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --hevc-aq --no-cutree --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt470bg --output "E:\Temp\2020-10-15@18_07_32_7810_01.265"
resulting in:
and MediaInfo:
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=640x352 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=0 / limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=10.00 / no-rd-refine / no-lossless / cbqpoffs=-2 / crqpoffs=-2 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=64 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
-> so seems like '--tune psnr' does have additional side effects that were not documented (or where I do not know where it is documented).
Cu Selur
Ps.: created and entry in the x265 issue tracker: https://bitbucket.org/multicoreware/...-why-tune-psnr and a post in the x265 thread here https://forum.doom9.org/showthread.php?p=1925879.
Old 17th October 2020, 13:13   #3644  |  Link
Gravitator
AOM
Profile: high, 8bit&10bit, color sampling: 420 - crash encoding;
Profile: pro, 8bit&10bit, color sampling: 420 - crash encoding.
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
Old 18th October 2020, 11:38   #3645  |  Link
Selur
Selur's Avatar
Yeah, seems like the 'high'-profile is now restricted to 4:4:4 as the error it gives is: "Profile 1 requires 4:4:4 color format" and for the 'pro'-profile I get 'Profile 2 bit-depth <= 10 requires 4:2:2 color format"
I assumed:
Main Profile (0) is 8/10-bit 4:2:0 or Monochrome (4:0:0)
High Profile (1) is 8/10-bit 4:2:0, 4:4:4, Monochrome
Professional Profile (2) is 8/10/12-bit, 4:2:0, 4:2:2, 4:4:4, Monochrome
but seems like they limited it to:
High Profile (1) is 8/10-bit 4:4:4
Professional Profile (2) is 8/10/12-bit, 4:2:2, 4:4:4
Old 18th October 2020, 13:08   #3646  |  Link
sneaker_ger
AFAIK:
Professional Profile (2) is 12-bit with any sub-sampling; plus 8, 10 bit with 4:2:2
So there is (and always has been) 0 choice about the profile when encoding with a given bitdepth and sub-sampling.
Old 18th October 2020, 14:03   #3647  |  Link
Selur
Selur's Avatar
ah okay,...
Old 7th November 2020, 15:04   #3648  |  Link
Gravitator
AOM
Golden frame dist max: 1 - crash with any settings.
Old 11th November 2020, 21:07   #3649  |  Link
Selur
Selur's Avatar
I can reproduce the crash, it even gives and error:
Failed to control codec: Invalid parameter
    max_gf_interval out of range [AOMMAX(2, extra_cfg->min_gf_interval)..(MAX_LAG_BUFFERS - 1)]
-> so it needs to be at least 2 and below 'max frames to lag' -1
Old 12th December 2020, 15:06   #3650  |  Link
Selur
Selur's Avatar
Hybrid rev 2020.12.12.1:
*fixed*
  • Synth: Avisynth, color matrix seleciton (missing '.')
  • x264: min/max quant maximum (missing + 18)
  • Synth: Avisynth, 64bit/32bit switching filter path initialization problem
  • Synth: Avisynth, small fixes related: RemoveDirt, TFM
  • Synth: Avisynth, QTGMC filter call
  • Synth: Vapoursynth, fixed SSIQ
  • Synth: Vapoursynth, ImageReader always outputs RGB24
  • Synth: Vapoursynth, HQDering default, LSFMod gui control
  • Synth: Vapoursynth, ff3dFilter extended supported color spaces
  • Synth: Vapoursynth, LUTDeCrawl and LUTDeRainbow crashes when 'mask' was used
  • Synth: Avisynth, import Zs_RF_Shared for edgecleaner
  • Synth: Avisynth, a few bugs related to interlaced handling in Avisynth
  • Synth: Avisynth, ColorYUV 'Off' control U/V mixup
  • Synth: Avisynth, FastLineDarkenMOD call
  • refresh resize&co on manual input PAR change
  • Synth: Vapoursynth, typos 'sceneChroma' -> 'scenechroma','internations'->'interrations',...
  • Synth: respect filter order when calculating output frame count and frame rate.
  • Synth: handle RGB input
  • Synth: sRestore support mode -1,-3,-4
  • Synth: Avisynth, ColorMatrix change preview
  • Synth: av1 aomenc color space restriction
  • Synth: error about "overWriteOutputFrameRateValue" when Vapoursynth wasn't present
  • Muxing: always used ffmpeg for mkv muxing
*changed*
  • x265: using --scenecut-aware-qp <0..3> and --masking-strength <string> instead of --[no-]scenecut-aware-qp, --scenecut-window <0..1000>, --qp- delta-ref <0..10> and --qp-delta-nonref <0..10
  • x265: support for --vbv-live-multi-pass, --max-vbv-fullness, --min-vbv- fullness
  • x265: support for --min-vbv-fullness & --max-vbv-fullness
  • Synth: Avisynth, removed 'enableAvisynthForDVD' it's always assumed to be enabled now
  • Synth: Vapoursynth, added overwrite Smooth/Super/Vectors to Interframe
  • UI: removed simple view for Xvid and x264
  • Synth: Reset Avisynth and Vapoursynth filter order when filter count changed.
  • Synth: Avisynth´, force use of D2VSource instead of DGDecode when 64bit Avisynth is used (there does not seem to be any working 64bit DGDecode.dll)
  • UI: Rearranged the Vapoursynth filters into groups
  • Tools: FFMpeg, using '-video_size' instead of '-s'
  • Tools: FFMpeg use ignore_editlist for mov/mp4/3gb input
  • Synth: Avisynth, limit QTGMC imports
  • Synth: enforce Crop < Rotate < Resize < Letterbox order in custom filter orders
  • Synth: Vapoursynth, now also allows interlaced output of scripts
  • Video: FFvHuFF set output color space
  • Muxing: use '-of avi' instead of '-of lavf' when muxing to .avi using mencoder
  • Synth: Vapoursynth, support RGBS in Limiter and Levels
  • x265: disabled 'replace tune' in 'minimize command line', since atleast '--tune psnr' has some unknown side effects, see: https://bitbucket.org/multicoreware/...-why-tune-psnr
*added*
-> downloads: http://www.selur.de/downloads
Cu Selur
Ps.: Note that Vapoursynth now allows to change the filter order of each filter individually, but this requires to reset the default filter order.
Old 13th December 2020, 13:52   #3651  |  Link
Selur
Selur's Avatar
Hybrid rev 2020.12.13.1:
*fixed*
  • Decode: deinterlacing through FFmpeg wasn't used when Avisynth/ Vapoursynth was used.
  • Avisynth: custom before 'End'-section was missing
  • (e)ac3 dialog normalization ui glitch
Cu Selur
Old 17th December 2020, 23:10   #3652  |  Link
stax76
stax76's Avatar
@Selur
Did you try Anime4KCPP under AviSynth? It gives an access violation here.
Old 19th December 2020, 11:31   #3653  |  Link
Selur
Selur's Avatar
@stax76: tried it, didn't work for me either. Did not spend time on it since it works on Vapoursynth.
Cu Selur
Old 19th December 2020, 12:22   #3654  |  Link
stax76
stax76's Avatar
OK, thanks.
Old 31st January 2021, 19:26   #3655  |  Link
Selur
Selur's Avatar
Hybrid rev 2021.01.31.1:
*fixed*
  • Vapoursynth: libneo-fft3d.so -> libneofft3d.so
  • Vapoursynth: DaaMod fix 'no field vsDaaExpMod'
  • Sytnh: DVD handling Avisynth/Vapoursynth
  • Synth: Remove Trim from FilterOrder, always trim directly after source filter.
  • Avisynth: 64bit use MPEG2Dec_64
  • UI: (e)ac3 dialog normalization ui glitch
  • Vapoursynth: IVTCCustomDeinterlacerGPU ui glitch
  • Subtitle: subtitle extraction form MP4 files
  • Preview: title left/right mixup
  • x265: strictCBR handling
  • Vapousynth: MClean
  • Vapoursynth: Denois filters on their own were ignored
  • Audio: qaac language passthrough
  • Audio: ffmpeg aac reencode + ffmpeg cut causing audio glitch
  • Vapoursynth: VFM color space restriction
  • Synth: SelectEvery and SelectRageEvery
  • Vaporsyunth: AddGrain
  • NVEnc: L1/0 reference min value and gui glitch
  • Vapoursynth: make sure filters that change resolution or frame rate are applied to input&output in FilterView.
*changed*
  • Framework: switchted to Qt6 (Mac&Windows only)
  • Jobs: mplayer try to skip unnecessary muxing for video only encodings.
  • AutoCrop crash
  • Preview: add '-vf scale' during MPlayer Preview
  • UI: bunch of cosmetic changes
  • Synth: adjustements adjust to latest DGDecNV DGSource
  • Vapoursynth: Anime4k supported color formats
  • MPlayer: added 'ni' to mplayer dvd analysis call
*added*
  • NVEnc: support for --vpp-smooth
  • Vapoursynth: GLSL Resizer support
  • Vapoursynth: "only apply" from some filters.
  • Vapoursynth: support for GrainFactory3
  • Video: custom addition support for aomenc and vpx
  • Video: constrained quality 2pass VPX/AV1
Cu Selur
