#2161 | Link |
Hi, sorry, arriving late to the 'Hybrid under Linux' call...
![]() xkinn123, I'm using Hybrid under Linux Mint 64bit for about a year (more?), and works great! Follow Selur advice, read the Selur site forum and his thread, and you will succeed. ![]() |
#2162 | Link | |
![]() Last edited by xkinn123; 21st April 2014 at 02:12. |
#2163 | Link | ||
But you wrote one month ago that 16 GB could be enough for 4K and also 8K ; http://forum.doom9.org/showthread.ph...55#post1674455 Quote:
#2166 | Link |
Only if you assume that no more than 250 frames get cached, if you use openGOP and/or a larger max GOP size this might not be the case.
So personally I would call 16 GB more a minimum requirement for 8k handling, but when I would have to build a machine for 8k encoding&editing, I would aim for 32GB or above. |
#2168 | Link |
It's time to think about the support of older OSs.
Should Hybrid try to keep supporting:
Would be nice to get some feedback. Cu Selur |
#2169 | Link |
@xkinn123: managed to reproduce the minimize-Problem on Ubuntu 14.04 (doesn't happen on Kubuntu 14.04), will look into it.
-> it's fixed in my current dev version, are you using 32bit or 64bit Ubuntu? Correction, not really fixed: I read up some more on the issue and the problem is that Unity needs applications to be white-listed to allow them to use the system try. on older Ubuntu versions using (before 13.04): Code:
gsettings get com.canonical.Unity.Panel systray-whitelist Code:
gsettings set com.canonical.Unity.Panel systray-whitelist <Hybrid> With 13.04 they added a new package 'sni-qt' which seems to fix the issue if the application was build with the same qt version sni-qt was build with. Problem is Ubuntu 14.04 uses Qt 5.2.1, but atm. I only compile Qt 4.6 and Qt 4.8 version. If you tell me if you use a 64bit or a 32bit Ubuntu 14.04 I can compile a 5.2.1 version for you to test, but upon further reading and testint another issue is that even if the tray icon of Hybrid is shown, it is shown at the wrong location.
Hybrid here in the forum, homepage Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,.. Last edited by Selur; 23rd April 2014 at 14:59. |
#2171 | Link |
@Havokdan: Sorry, but I don't get the question.
'Better batch encode?' has nothing to do with 'old OSs support' so I'm a bit confused about the intension of the question. If this is some sort of 'feature request', please share more details what you would like to be better. No clue what batch encode is lacking from your point of view, so I have no clue what you think should be changed to make it better. Personally I'm totally happy with the way batch encoding is supported atm. Cu Selur |
#2172 | Link |
It was a desired feature for me, having a window or tab to select certain profiles for each open file for example instead of navigating in aba in tab to select an option. As for the operating system, if it is for surfing like Windows XP, it would be nice keep the site the latest version compatible with the same.
#2173 | Link | |
#2178 | Link |
Hybrid rev 2014.04.28.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
#2179 | Link |
Did you also fix this ;
http://forum.doom9.org/showthread.ph...66#post1676666 and this ; http://forum.doom9.org/showthread.ph...68#post1676668 Actually you did in a version you sent me in PM but it's not mentionned in the fixed list. |
