Old 9th December 2008, 23:44   #801  |  Link
Originally Posted by HymnToLife View Post
Source sample needed?
Yes, please. I need to be able to duplicate your issue.
Guest is offline
Old 10th December 2008, 00:28   #802  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Hmm, big thread is big, what is the correct method to cut a sample from the TS?
Copy Protection:  A clever method of preventing incompetent pirates from
		   stealing software and legitimate customers from using it.
From http://www.gnu.org/fun/jokes/software.terms.html
HymnToLife is offline
Old 10th December 2008, 00:39   #803  |  Link
You can split it into pieces using DGSplit, for example.
Guest is offline
Old 10th December 2008, 01:48   #804  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Is setting start and end points in DGAVCIndexNV and then choosing "Save and demux video" a good way to get a stream sample? (the problem is reproductible with a stream obtained that way.)
Old 10th December 2008, 05:34   #805  |  Link
Certainly, that is fine if it allows me to duplicate your issue. Please provide a link to the stream and the script and instructions for duplicating the issue. I'm very keen to address issues with random access, as it is the raison d'etre of the DG tools. Thank you for your willingness to help with debugging.
Guest is offline
Old 10th December 2008, 06:44   #806  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
http://itsuki.fkraiem.org/stuff/toki...vs.demuxed.264
Create DGA file normally, then make an AVS script like this:
DGAVCDecodeNV_AVCSource("blah.dga")
Trim(90, 0)
and open in VDub.
(EDIT: Note the key point is accessing at frame 90, the problem does not happen with e.g. Trim(89, 0).)
Old 10th December 2008, 15:12   #807  |  Link
Thank you.
The encoding is very unusual and I'm not yet sure it is fully legal. Where did this stream come from?
Guest is offline
Old 10th December 2008, 23:11   #808  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Thank you.
Original Japanese Blu-ray.
Old 11th December 2008, 01:01   #809  |  Link
Interesting. The POCs are goofy in the stream (i.e., wrong) and I'm tempted to simply say that the stream is wrong. But there is a way to fix it. Instead of looking at the POCs of the first two pictures of the GOP to decide if it is open, I can look at the picture types. I've tried it and it fixes the problem so I'll probably go with that. I'm porting the AV sync fixes and I'll include this with the next release if it doesn't break anything else.
Guest is offline
Old 11th December 2008, 02:24   #810  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Other small question: is it safe to work on a DGAVCDec (non-NV) script in VDub while there is a DGAVCDecNV script encoding?
Old 11th December 2008, 04:07   #811  |  Link
Is it safe to work on a DGAVCDec (non-NV) script in VDub while there is a DGAVCDecNV script encoding?
As long as you are working on different files. You wouldn't want to rewrite the DGA file while the decoder is using it.
Guest is offline
Old 12th December 2008, 21:19   #812  |  Link
Originally Posted by rack04 View Post
I have noticed a discrepancy in the description of the detected audio streams from the audio demux and the audio section of the information panel.
I have fixed this problem. The fix will be in the next release
BTW, is it possible to give these appropriate names, i.e. DTS Master Audio, TrueHD?
If someone can tell me how to detect those audio types, I can probably do it.
Guest is offline
Old 12th December 2008, 23:42   #813  |  Link
madshi
This is with m2ts container, right? If so, you can use the stream type:
0x03: MP2 (MPEG-1 Audio Layer II)
0x04: MP2 (MPEG-2 Audio Layer II)
0x0f: AAC (MPEG-2 Part 7 Audio)
0x11: AAC (MPEG-4 Part 3 Audio)
0x80: LPCM (only if format id descriptor is 'HDMV')
0x81: AC3
0x82: DTS
0x83: TrueHD+AC3
0x84: E-AC3
0x85: DTS-HD High Resolution
0x86: DTS-HD Master Audio
0x87: E-AC3
0xA1: E-AC3 (secondary audio)
0xA2: DTS Express (secondary audio)
madshi is offline
Old 13th December 2008, 00:04   #814  |  Link
Thank you, rack04 and madshi.
Guest is offline
Old 13th December 2008, 00:13   #815  |  Link
Also, would you gents happen to have M2TS samples with these new audio types?
Guest is offline
Old 13th December 2008, 00:45   #816  |  Link
nautilus7
nautilus7's Avatar
0x83: TrueHD+AC3 http://www.sendspace.com/file/miye0c
0x86: DTS-HD Master Audio http://www.sendspace.com/file/eoboij
0x84: E-AC3 or 0x87: E-AC3 http://www.sendspace.com/file/08wkhg
I will upload samples with the ids below tomorrow.
nautilus7 is offline
Old 13th December 2008, 01:09   #817  |  Link
Thank you!
Guest is offline
Old 13th December 2008, 02:03   #818  |  Link
rica
DTS-HD-HR into m2ts container:
http://www.mediafire.com/?sharekey=6...1f79f1876d365a
You will find the modified pcm by Pcm2Tsmu and raw pcm under the same folder. (audio.pcm is raw and audiopcm_out.m2ts is modified by Pcm2Tsmu)
rica is offline
Old 13th December 2008, 02:06   #819  |  Link
Thank you!
Guest is offline
Old 13th December 2008, 19:11   #820  |  Link
moviefan
Just for curiousity, neuron2, have you planned creating a GPU based decoder for H264 and VC1 for ATI cards, using ATI's stream API? I would be very interested in that and I assume a lot others who own ATI graphics cards.
moviefan is offline
