Old 26th January 2007, 22:22   #61  |  Link
The Scientist
The Scientist's Avatar
how do you know it encoded as DivX?
The Scientist is offline   Reply With Quote
Old 26th January 2007, 23:04   #62  |  Link
jeffy
Play it in Media Player Classic, right click for Properties/Details or in VirtualDubMod, fourCC DX50
jeffy is offline   Reply With Quote
Old 26th January 2007, 23:07   #63  |  Link
ricardo.santos
ricardo.santos's Avatar
working fine here encoded a small clip using xvid no problem status bar stats appeared correctly.
had a instalation error but i think it was due to be running the instalation file from the zip file, after extracting the msi it didnt produce any error
ricardo.santos is offline   Reply With Quote
Old 26th January 2007, 23:11   #64  |  Link
ricardo.santos
i think the fourcc is changed by avi.net for compatability reasons, i encoded using xvid and the fourcc is divx50
Old 27th January 2007, 00:03   #65  |  Link
jeffy
Ehm... you might be right!
Maybe you are right, GSpot tells Xvid0047 whereas older Avi.net with Divx doesn't. . I didn't consider FourCC code changing...
Old 27th January 2007, 00:05   #66  |  Link
The Scientist
It's an XVID, believe me.
Use the latest GSpot beta , it will say DX50 and XviD 1.1.2.
Old 27th January 2007, 00:08   #67  |  Link
jeffy
Use the latest GSpot, it will say DX50 and XviD 1.1.2.
Excuse me, where does it say Xvid 1.1.2? (My GSpot is 2.60 RC01). Thanks for clarifying. Anyway I tried to change the codec for DivX in beta 5 and it did encoded with the same FourCC but different data, so maybe you enabled the codecs while I thought they were still disabled... Thanks for being clear!
Old 27th January 2007, 00:22   #68  |  Link
The Scientist
Screenshot of GSpot 2.60 RC1 (top right corner). File encoded with avi.NET (XviD) codec used. See the "XviD 1.1.2 Final".
Old 27th January 2007, 00:25   #69  |  Link
The Scientist
Thank you all for helping me get to the bottom of that bug earlier, it's such a pain and time consuming without any users to test, cheers.
Old 27th January 2007, 00:38   #70  |  Link
jeffy
Glad to be of help
For me, it was pleasure, as it will hopefully help "the so-far silent" users of avi.net. My Xvid was over-installed with the latest AutoGK so it says
Old 27th January 2007, 00:55   #71  |  Link
The Scientist
That pic is not from an avi made with avi.NET..... avi.NET will say DX50 in first column, no matter what version of XviD you use, it the muxing program from DivX Networks that does this.
As for XviD, avi.NET will only work correctly with XviD v1.1.2 not other versions, this is important......
Old 27th January 2007, 01:03   #72  |  Link
jeffy
As I said ,
I forgot when trying the theory Xvid/Divx I did used Nick's FourCC changer and made it XVID. I'm sorry, it was really created with avi.net! Mine is 1.2-127 (Dec 8, 2006)
Old 27th January 2007, 01:24   #73  |  Link
The Scientist
Well it had me a bit worried as NVOP should be on, BVOP shoul d be on, and PB should be on....... Next time you do a test see what it says in GSpot, if it's different to what I've just mentioned then avi.NET is not working with that codec.....
Old 27th January 2007, 01:25   #74  |  Link
ricardo.santos
No need to thank, it us that should thank you for taking time to develop avi.net.
Old 27th January 2007, 06:26   #75  |  Link
JDK187
Thanks CloneAd You Rock! that fixed that problem.
I'd like to be able to convert the audio to mp3 at least down to 96kps if possible.
What i'd really like to see is an option to base my encodes on a particular template. for example, majority of my encodes come from my HDD JVC Everio that i send to family overseas so i always use the same settings for each. The index.net is a life saver.. if i could somehow save my index.net list and open that list within avi.net and run a template on it... It would be awesome.
One other question, would encodes be any faster if there was an option to downmix audio within the avs script (NicAC3Source..,2) for instance?
JDK187 is offline   Reply With Quote
Old 27th January 2007, 09:07   #76  |  Link
The Scientist
In what way? Explain a little more....
Not sure, I only use the Nic audio stuff during the preview.
Old 27th January 2007, 12:19   #77  |  Link
The Scientist
BETA 6 is now up.
Old 27th January 2007, 12:40   #78  |  Link
ricardo.santos
working fine here. (target size,subs,resolution.audio)
Old 27th January 2007, 14:01   #79  |  Link
The Scientist
Now that's what I like to hear...
Old 27th January 2007, 23:30   #80  |  Link
weaver4
I would like to see the av.Options parameters saved across restarts. I get tired of filling out the same info every time.
weaver4 is offline   Reply With Quote
