5th January 2002, 04:35 | #21 | Link | |
But well for 2 CD rips if you I think is better to lower the resolution, but the difference between the filter and lowering the resolution isn't so obvious. As Matter says the overall quality with filter it's better but faces and other details have much more sharpness without filter and lowering the resolution. And I have used a TempSmoother(1). I think we could doubt between lowering resolution or TempSmoother(2,1) maybe (1) but I will never use level 2 for a 2 CD rip. Well here I attach my results. dres -> resolution 576x240 without filters dfil -> resolution 640x256 TempSmoother(1) Last edited by serbersan; 5th January 2002 at 04:37. |
5th January 2002, 04:46 | #23 | Link |
AC3 5.1 Addict
@serbersan
So you would always use at least a 1 with 1CD rips but why would make you use 2 for a 1 CD rip? If the film was more noisy you would use 2? What are you viewing your rips on to judge the PQ? I'm currently encoding a 141 minute movie going for 2 CDs using a temporal value of 2 @ 608 resolution. I'll let you know how it turns out. Maybe I'll encode it a 2nd time using a value of 1 just to see the difference. |
5th January 2002, 05:02 | #24 | Link |
Well MaTTeR, if I could attach the file I want you could view the difference between 576 without filtering and 640 with filter (1). And Yes the 576 has more sharpness in some cases but in others the overall better quality is for 640 (1) Well I choose 576 because the sharpness it's in zones of the image that are important.
For 1 CD I use TempSmoother(1) but if the movie it's easy to compress if you have any doubt use TempSmoother(2) but with level 3 in some action scenes or in faces the effect is very noticeable but if the movie is too large or difficult the overall quality will be good. My advice is use TempSmoother(1)(dark movies) or (2)(not easy or very easy movies) but be warned with level 3 and I not recommend to use level 4. And for your 141 minutes rip I think TempSmoother(1) will be good at least with 608, I think I used it with so long movies, or TempSmoother (2,1). In any case with 141 minutes I don't think TempSmoother was a bad choice only you have to see if the movie has much noise or is difficult or simply for other times....do a test with 1 and if the result wasn't good enough use more filtering. I think for 2 CD rips first lower the resolution and then use filtering. But again, the difference will be very subtle unless the movie was easy to compress. |
5th January 2002, 16:58 | #25 | Link |
Well I have to remade my post, finally I burned the filter movie because the overall quality was better, there isn't backgrounds with strange efects of moving(because the too much noise and the lower resolution)
Well I think lower to 608 is right but no less without do before some filtering. I didn't do 608 without filtering because in 576 there was zones where appears smooth made by postfiltering because it hadn't enough bit to encode. Sorry for you time. |
5th January 2002, 23:03 | #28 | Link |
Are you sure ChristianHJW???
If I remember in the rip I've done of Dr T with TempSmoother, there was less noise in background and in some zones of the image, in some cases less detail in human skin. And the first minutes are very noisy. IMHO the filtering in this rip is better than lowering resolution the overall quality is better(less mosquito noise for example). Good Luck with your projects ChristianHJW |
5th January 2002, 23:08 | #29 | Link | |
Re:
5th January 2002, 23:37 | #30 | Link |
Retired
@Matter
The reason why it removes "grainyness" is based on the fact that a certain pixel in one frame has the grain-effect, but the two pixels in the two adjactent frames are enormal. Hence it's being corrected and the "grainyness" disappears. BUT this doesn't blur the picture unless you use a very high setting. @Peters That's actually only half of the story. If you push the edit button on GKnot you'll see that the noise filter is actually a combination of various decrees of TemporalSmoother and SpatialSoftenMMX. TemporalSmoother reduces the delta information between frames, SpatialSoften reduces the noise by blurring the image inside one frame. Btw, used in conjuction they don't increase compression over using just TemporalSmoother alone. But SpatialSoften blurs a whole lot more than TempSmoother so don't use it unless you've got very bad noise. |
5th January 2002, 23:50 | #31 | Link |
@Acaila
SpatialSoften is not used by Gordian Knot if you choose little noise. So don't say it's not a noise reducer! TemporalSmoother(clip[,strength[,radius]]) This is a port of the TemporalSmoother filter from VirtualDub. It works in RGB32 & YUY2 pixel formats. From VirtualDub help file: This filter is an adaptive noise reducer, working along the time axis; it is most effective when the image is not moving much. Increase the filter strength to increase noise reduction, and decrease it to reduce speckling and ghosting artifacts. It is recommended that you combine this filter with a spatial (area-based) noise reducer for greatest effect |
6th January 2002, 18:01 | #32 | Link |
AC3 5.1 Addict
My 141 minute movie turned out nicely using a temporal value of 2 with DivX 3(2 CDs). I'm going to encode it again with a value of 1 though.
I also decided to encode the movie with a value of 1 using DivX4. The results were unimpressive. I don't use DivX4 very often so I thought I would give it a try with Gknot and use the same Gknot settings basically as my DivX3 settings. Of course using DivX4, Gknot tells me I'll get 1227 bitrate compared to 1197 for DivX3 so I expected it would look alittle better. Personally, my eyes like the DivX3 version that I encoded with a temporal value of 2. However, now I want to encode it again with a value of 1 using Divx3. I had my girlfriend view both DivX4 and DivX3 encodes without her know which was which. She picked the DivX3 version also. Overall, it seems Like the DivX 4.12 codec is much darker. It's almost like it tries darken an object in the picture that it feels is unimportant just to get better compressibility. That method would be fine but it's a little to agressive. I guess I now see why most of the pros/gurus here use DivX 3 instead of DivX4.12 Again, the temporal smoother setting just simply rocks! It gives a better overall picture without really losing any definition of the fine areas. EDIT- Anyone notice that file size predictability isn't as good while using the temporal smoother? I'm having to add about 20MB to the total size selection in Gknot to fill the CD's Last edited by MaTTeR; 6th January 2002 at 18:17. |
6th January 2002, 19:48 | #33 | Link |
is it still believed that smart smoother should also be applied? (I apply temp. smoother before resizing (.6 bicubic) and smart smoother after resizing for my anime rips). also, what is this "2D Cleaner (Optimized)" I now see on Donald Graft's filter page? Is this comparable to or better than smart smoother?
6th January 2002, 21:01 | #34 | Link | |
Retired
I've done some testing of TempSmooth with SmartSmooth in the past, especially on anime. What I saw was absolutely no extra compression of using TempSmooth + SmartSmooth over TempSmooth alone. However using SmartSmooth put a serious blur over my movies, even at low filter settings. Obviously I don't like using it anymore, I just stick to TempSmooth.
1 CD Movie -> TempSmooth 2 or 3 2 CD Movie -> TempSmooth 1 Quote:
