15th November 2007, 12:18 | #1821 | Link |
chumbo, no, i did not. i'm trying to help a buddy throw his EVOs to mkv to play on his NMT - like i said, i haven't toyed wih this stuff in quite a few months, and have not had the time to rip any content for testing, as this just came up yesterday. BUT...i did have the presence of mind to take a quick gawk thru this thread after my last post, and determined the filter combination he should try is simply haali matroska splitter (the excellent source input filter - thank you haali)>haali media muxer. i'll not bother the forum again for help until we run into an actual roadblock. thanks.
26th November 2007, 22:00 | #1823 | Link | |
Has anyone successfully done this? I would love to stream transformers to PS3. I'm getting the same non-compliance message when importing the video. If you google transformers and remux, you will find some chinese stuff, but I don't know if this version will stream to PS3. So it looks like there is a successful remux out there, the question is how, and will it play on ps3 or as a BD |
30th November 2007, 03:21 | #1825 | Link |
Joining EVOs
I just ripped "Return to House on Haunted Hill" HD-DVD and it has 14 feature EVOs(!).
It appears my version of EVOdemux only handles the first 9 EVOs (It stops at Feature_10.EVO). What is the best way to join EVO files? Is there a program available? I hope this is not too far off thread topic and apologize in advance if it is. Regards, The_Keymaker Last edited by The_Keymaker; 30th November 2007 at 03:30. |
30th November 2007, 03:57 | #1826 | Link | |
It's a pain, but it works. Not all titles use known naming either, so you have to rename in those cases too.
Chumbo |
30th November 2007, 08:03 | #1827 | Link |
Thanks for the suggestion Chumbo.
Yeah, I tried what you suggested and it looks like all the timing information gets screwed up doing it that way. What i will try next is: - Rebuild the first nine files in one EVO - Using GDSmux convert that EVO to a MKV and call it Part 1 - Do the same with the remaining EVOs and call it Part 2 - Merge the two using MKVtoolnix. I'll report back if it works... The_Keymaker |
30th November 2007, 19:56 | #1828 | Link | |
Chumbo |
22nd December 2007, 18:16 | #1830 | Link | |
DRM Destroyer
You might need to rename the files to get EvoDemux to read them in. |
23rd December 2007, 13:05 | #1832 | Link |
moved to hddvd/bluray forum, as i think this fits better there
23rd December 2007, 16:11 | #1833 | Link |
You can use Tssplitter to join all the files first, and then use evodemux. I have done this before. Tssplitter is free. Just make sure that when you click on file, then join, make sure to allow "all files" to be shown. And the program will join any file extension, they don't have to be .ts files.
6th January 2008, 17:58 | #1834 | Link |
How do I demux a full vc1 stream?
Hello,
I've been having a bunch of trouble demuxing evo. For some reason, I just can't get the full feature. If I demux a feature with 2 parts (feature_1 and feature_2) - it seems to work and join into a file the size expected. (With continue to next evo and count frames checked). The probelm is that if I drag the vc1 stream into a meda player, the time is wacked, and more importantly, the video is not complete (end of the vc1 stream is not the end of the movie). I've tried this on a rebuild joined stream and without rebuilding as well. I have tried adjust PTS and Rebuild ADV_PCKS as well (what are they by the way)). These did not make a difference. Am I missing something? I would expect that even with just the vc1 stream, i could at least see the video of the whole movie. The other odd thing is if I demux each part of the feature (1 and 2) seperately (no continue on evo), feature 1 ends before my joined one does, but feature 2 starts well after my joined one ends..... In other words, the supposed whole movie ends at a spot before the starting scene of feature 2, and feature 1 ends at a scene prior to the end of the joined feature? Could anyone help me out on what I'm doing wrong? I've tried this with a few different movies with the same issue. EVOdemux 0.627 b7, ripped with dvdfab hd decrypter.
It's better to burn out, then to fade away! |
6th January 2008, 21:34 | #1835 | Link | |
8th January 2008, 02:12 | #1836 | Link |
Thanks for the thoughts on what to try.
I tried to put into an mkv container to view by dropping the evo file in gsmux. If i drop the resulting mkv file into mkvsplitter it correctly identifies the vc1 and ddp stream inside of the container. My problem is i can't seem to playback the mkv now...it shows up as pure black in media player classic. I even tried remuxing from mkvsplitter to force the framerate to 24 as i read in some posts. I'm sure I'm still doing something wrong, any suggestions would be appreciated.
8th January 2008, 09:27 | #1837 | Link | |
26th January 2008, 16:16 | #1839 | Link |
First Time Poster, Long Time Reader
Hi All,
I just want to post thanks to everyone in this thread. It has helped (along with the EAC3TO thread) me backup my personal collection. I have been able to successfully mux a VC-1 stream plus a lossless 5.1 WMA stream (converted from one of the available audio tracks) into WMV files. These files play in the Xbox 360 Dashboard player just fine (unfortunately, they don't play in the Media Center Extender Interface). I use the Solveig ASF multiplexer (the demo version seems to work fine) in graphedit from the MKV source with the VC-1 stream. This MKV is easily created by EAC3TO. I then take the best audio track available and convert it to WMA 9.2 Lossless 5.1. Once I have the WMV and WMA file, I combine them with the Windows Media Stream editor. At the end of the day, I have a nice WMV file. With H.264 video, I use the MKV container with AC3 audio. Again - thanks to all for your posts! |
27th January 2008, 03:46 | #1840 | Link |
Any possibility the developers of eac3to and evodemux could merge the functionality?
I would really like to be able to take an evo and directly convert it into another evo, whilst stripping out all but selected video, audio and subtitle streams PLUS stripping pulldown flags for the video stream. I know evodemux already does the stuff before PLUS, but it's the functionality after PLUS that I would find of great additional benefit. Of course it would be even better still if evodemux was able to transcode audio formats ala eac3to as part of the evo->evo conversion process. |
