Old 14th January 2023, 22:19   #1  |  Link
filler56789
SuperVirus
filler56789's Avatar
DTS-HD Master Audio v.2.6 issue with Wi-Fi adapters
I became aware of this problem only two days ago, after installing v.2.6 on an ancient laptop running Windows 8.1.
The symptom: the job queue never starts, the mini-window only says "PENDING".
The workaround: disable the Wi-Fi adapter before using the encoder.
The solution: replace the original DtsJobQueue.exe with the fixed one. :-|
https://www.mediafire.com/file/nizxv..._bomb.rar/file
P.S.: I also discovered that the file dtshd.exe must be run in compatibility-mode (Windows 7 or earlier),
otherwise the splash screen will not be shown and the encoder's GUI will start minimized to the taskbar.
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 15th January 2023, 12:17   #2  |  Link
von Suppé
von Suppé's Avatar
I recently narrowed down the same happens when my VPN tool is enabled.
I also discovered that the file dtshd.exe must be run in compatibility-mode (Windows 7 or earlier), otherwise the splash screen will not be shown and the encoder's GUI will start minimized to the taskbar.
This is good to know for when (if ever) upgrading to a newer windows version. Still on 7 now.
Thank you.
Old 15th January 2023, 15:45   #3  |  Link
filler56789
SuperVirus
You're welcome.
Many for the useful information.
Which makes me believe the infinite-loop induced by, let's say, network-related factors, was less of a bug and more of an intentional "feature"
(read: a design flaw).
The "feature" was introduced in version 2.5 and was NOT fixed in (removed from) version 2.6.
F.W.I.W....
DOUBLE_FIX_DTSJOBQUEUE.EXE
000418E5: 79 EB <== time-bomb fix
00083F2E: 6F 6D <== Wi-Fi fix
Since Wi-Fi cards are the norm for laptops,
we would like to know what was the ""reasoning"" of D.T.S. when they introduced the laptop-unfriendly feature, ooops, "bug", in the latest versions of the encoding suite.
dtsjobqueue.exe, master audio suite, network, pending, time bomb
