Old 16th February 2024, 16:47   #25141  |  Link
Siso
Soul Seeker
Siso's Avatar
I was hoping for a dsp plugin or other audio compressors.
Old 16th February 2024, 18:16   #25142  |  Link
clsid
If voices are too soft compared to the other sounds, then the center mix level is a great solution when downmixing.
Loudness Equalization is a standard Windows sound enhancement setting. It is not specific to Realtek driver.
MPC-HC has a "Volume Normalization" setting in its audio switcher settings. That does audio compression.
MPC-HC 2.2.1
Old 17th February 2024, 00:19   #25143  |  Link
Damien147
Now that you mentioned Realtek I found this the other day suggesting to put default format in 24 bits 48000hz.You agree or I am missing something?
Damien147 is offline   Reply With Quote
Old 17th February 2024, 05:56   #25144  |  Link
Sunspark
Yes, it is ideal because video is almost always that.
Old 17th February 2024, 11:01   #25145  |  Link
Siso
Soul Seeker
Siso's Avatar
MPC-HC's volume normalization adjust the volume in a noticable way, you can spot when the volume is adjusted, not what I'm looking for.
Old 17th February 2024, 14:55   #25146  |  Link
Damien147
Ok,thanks.
Old 17th February 2024, 17:11   #25147  |  Link
Sunspark
In fairness to the normalization function, it's a hard problem it's trying to solve. If the whole video was pre-fed into it, then it would be easier because it would be able to calculate everything in advance, but what happens instead is that it has to do it in real time. That, plus there are other parameters that can be set how it functions. Everyone has a different algorithm, this is why I suggest trying additional ones like the ones in the soundcard like Realtek's loudness equalization to compare against.
Related, the default value of 400% might be too high, 200% might be a better value to use.
Old 17th February 2024, 17:28   #25148  |  Link
Siso
Soul Seeker
Siso's Avatar
Loudness equalization is kind of a silly feature, tried it last night didn't like it at all.
Old 17th February 2024, 19:13   #25149  |  Link
Sunspark
It's a useful feature. It's needed for DTS 5.1>2.0 which will often be too quiet. Also for streaming video from various websites, haven't you noticed many are also quiet?
I was doing an listening test earlier in HC trying out different combinations. One suggestion I can make which will make a difference whether normalization is on or off, is to have "ignore system channel mixer" be checked. This is actually disable windows audio enhancements which you can also do manually in the sound control panel. I find that when it is unchecked (enabled), voices are quieter on this realtek. Also in LAV mixer output set to stereo, change mixing center level to 1.00 (default is 0.71).
Old 19th February 2024, 11:34   #25150  |  Link
flossy_cake
Save this as a .avs file and open it in your media player with LAV as the source filter for opening .avs files
file = "C:\YourVideoFile.mkv"
# Decode the source file using LWLibav decoders (most reliable imo)
video = LWLibavVideoSource(file)
audio = LWLibavAudioSource(file, stream_index=-1, av_sync=true)
AudioDub(video, audio)
# Apply audio peak normalization - scans the entire audio track prior to playback and raises
# peak volume until loudest sample touches 2% below clipping
Normalize(0.98)
If the loudness still isn't sufficient for your taste, you will have to use compression to boost the quiet sounds and lower the loud sounds relative to each other.
If implemented poorly like the Microsoft driver then you will hear volume pumping which sucks. Dolby compression profiles are a lot better imo and have less pumping. Here are the Dolby profiles implemented in Avisynth with Sox Filter (specifically pinterf's recently updated version here which supports realtime use without distorting audio).
In order from least compression to most compression:
# film light fast
SoxFilter("compand 0.01,1.00 -90,-90,-70,-64,-53,-47,-41,-41,-21,-21,-10,-16,0,-15 0 0 0.054")
# film light slow
SoxFilter("compand 0.10,3.00 -90,-90,-70,-64,-53,-47,-41,-41,-21,-21,-10,-16,0,-15 0 0 0.054")
# music light fast
SoxFilter("compand 0.01,1.00 -90,-90,-70,-58,-65,-53,-41,-41,-21,-21,0,-11 0 0 0.054")
# music light slow
SoxFilter("compand 0.10,3.00 -90,-90,-70,-58,-65,-53,-41,-41,-21,-21,0,-11 0 0 0.054")
#film standard fast
SoxFilter("compand 0.01,1.00 -90,-90,-70,-64,-43,-37,-31,-31,-21,-21,0,-20 0 0 0.054")
#film standard slow
SoxFilter("compand 0.10,3.00 -90,-90,-70,-64,-43,-37,-31,-31,-21,-21,0,-20 0 0 0.054")
# music standard fast
SoxFilter("compand 0.01,1.00 -90,-90,-70,-58,-55,-43,-31,-31,-16,-21,0,-20 0 0 0.054")
# music standard slow
SoxFilter("compand 0.10,10.0 -90,-90,-70,-58,-55,-43,-31,-31,-16,-21,0,-20 0 0 0.054")
# speech fast
SoxFilter("compand 0.01,0.20 -90,-90,-70,-55,-50,-35,-31,-31,-16,-21,0,-20 0 0 0.054")
# speech slow
SoxFilter("compand 0.10,1.00 -90,-90,-70,-55,-50,-35,-31,-31,-16,-21,0,-20 0 0 0.054")
For maximum volume do it before the Normalize(0.98) however the loading time will be longer due to having to run the whole audio track through SoxFilter first.
Fast/slow refers to the attack & decay times specified by Dolby which control how fast the compressor reacts to increases & decreases in the source volume.
Thanks to tebasuna51 for linking me to the Dolby docs to make these profiles from
Old 2nd March 2024, 17:39   #25151  |  Link
mzso
Hello!
Why is audio much lower volume with LAV then everything else on the system? The same file is also much louder if I play it with MPV. (players both at 100% of course)
Old 2nd March 2024, 17:49   #25152  |  Link
LigH
LigH's Avatar
Channels, mixing.
Can't tell you more without knowing all the details about your audio track and the setup of the LAV audio decoder.
New German Gleitz board
Old 2nd March 2024, 17:55   #25153  |  Link
Megalith
Sadly, the best solution is usually to just turn up the volume. The geniuses at Dolby/DTS know how to do 9,000-channel surround sound, but they never bothered to make a smarter way of folding down surround to stereo.
Megalith is offline   Reply With Quote
Old 2nd March 2024, 18:04   #25154  |  Link
mzso
Originally Posted by LigH View Post
Channels, mixing.
Can I at least increase the output volume or something?
Old 2nd March 2024, 18:05   #25155  |  Link
mzso
I'm not sure if it's just Dolby and DTS. The DVB mpeg-2 streams seem rather low as well.
Old 2nd March 2024, 19:31   #25156  |  Link
if you play 5.1 om stereo it is well known that the mixer in lavaudio does not have the same volume level as the windows mixer. this is intentional.
with pcm audio out there are multiply parts where the audio volume is changed so it's not just one to point at.
Old 3rd March 2024, 01:27   #25157  |  Link
mzso
But with audio set to 100% in media players I can do little other than change the system volume or speaker/TV volume all the time. Which sucks.
And the media player (with LAV) seems to be the lowest volume by a decent margin out of every app.
Old 3rd March 2024, 03:38   #25158  |  Link
if you don't mix it should be the same. at that point lavfilter doesn't do anything anymore.
you can also bit stream where lavfilter can't touch audio yet again.
all other stuff is the windows mixer the windows general audio level and some player allow for more then 100 % volume.
there is also the audio switcher.
mpv and mpc-hc have 100% the same volume here as it should be. but mpv allows for more then 100%.
Old 3rd March 2024, 12:08   #25159  |  Link
Siso
Soul Seeker
Siso's Avatar
There are two sound normalisers in mpc-be, the first one doesn't work as it should, the second one is from ffmpeg and it is ok. As for mpc-hc the internal normaliser is not so good tho.
Old 3rd March 2024, 13:24   #25160  |  Link
i don't see what this has todo with lavfilter?
the only place where lavfilter is changing "volume" is in mixing and DRC. the rest is bit perfect and the problem of the player and OS.
