10th September 2006, 16:32 | #122 | Link |
anyone can help me to extract 6 mono channels-16bit from 5.1 dtswav with WW? ( tebasuna51,are you around? )
with tranzcodegui is easy but only for 32 bits waves. i read the johnman "general info" http://forum.doom9.org/showpost.php?...42&postcount=5 but i can't put it working.(maps,etc..i'm lost) thanks so much. |
11th September 2006, 00:34 | #123 | Link | |
http://tranzcode.byethost22.com/file...0.40(beta).rar I still need to document some added commands. In short, it will (last I tested way back then), decode .ac3 and ddwav as well as .dts, .cpt and dtswav, and you can specify the output bit-depth (8,16,24,32 bit integer, and 32 & 64 bit floating pt), as well as resample to either 44100, 48000 and 96000 Hz. It will also do batch file processing (use the '*' character as the file delimiter (also use double quotes for filenames containing spaces-of course), and also a means to list channel files if you want to mux a multichannel wav. It can also strip channels from multichannel wavs. and you can specify the speaker settings since it will create in wave extensible format. I haven't done this for awhile muxing, err.. actually used/tested it since March, so bare with me. Oh ya, it will produce an accurate info on the DD/DTS files using hmm.. I forgot, think it's the /i (file info calculated)i, and /im (file info measured) commands if I recall correctly and also produce an info file .tzf (I think ) which I would later use for editing using the gui. So I suppose I'll have to write a short guide on some of the new commands. This may still work with TranzGUI but may only work as before which will be quite limited as to its capabilities. Copy 'Tranzcode.exe into the folder where the file you want to decode is in (or copy it into your i.e. 'C:\WINDOWS\system32' dir) So to decode to 16 bit, open a 'DOS' window (Start/Accessories/Command Prompt), Change dir 'cd' to the dir and issue the following command (example) tranzcode "my file.dts" /16 or if you want to resample the output as well.. tranzcode "my file.dts" /16 /44 [edited: thats WRONG! it sould be /44100 or /48000 or /96000 corrected: tranzcode "my file.dts" /16 /44100 Good luck, hope not to many bugz :P Ok I finally ran some testing (err guess I should have done that before posting it). No matter there were some log messages which you can ignore for now. I'll repack a new compile to get rid of any troubleshooting msgs and clean up any garbage I left in it, and add a list of some new commands with parameters. Also I'll add those commands here and totally hijack this thread completely :P (sorry John). BTW I would also like to mention that I thank Johnmann for giving me the inspiration, along with some pointers on how to incorporate SSRC (Shibatch Tools) into Tranzcode for resampling/bit depth conversion, dithering etc. Thanks guy! [EDIT] Ok it didn't take long to find bugs right away (I found 2 already) - which weren't there on preveous testing, so I messed something up. bug 1) When Upsampling & Bit Depth Converting together, it fails (at least on DTSWav and DDWav) bug 2) When decoding DDWav the progress display stays at 1% but actually decoded fine. Argh.. it may take awhile since I haven't look at the code so long ago. Sorry folks never expected this... Really! Already tarnished my bad reputation Ok it should be ok for now, uploaded a slightly older working version. Seems the link is not working, so just go to the website and download it from there: http://tranzcode.byethost22.com Cheers -AF Last edited by Austin Forgotten; 11th September 2006 at 08:07. |
11th September 2006, 00:49 | #124 | Link | |
You can use WaveWizard to convert the TranzGUI output to 16 bit int, or DTSParser to convert dtswav to dts an after decode to 6 mono wav 16 int with BeHappy. Sorry I don't know dtswav -> 6 mono wav 16 bit int in only 1 step. Edit: I don't see the Austin Forgotten post. We can try with Tranzcode v0.40 Last edited by tebasuna51; 11th September 2006 at 00:56. |
16th September 2006, 00:27 | #125 | Link |
hello ppl, guess who is back
as you might have seen development of ww sort of halted last couple of months but i just wanted to drop by to see what has happened. Who knows what the future brings . iirc the last thing i was working on was vst chaining and multichannel recording but to be honest i am not really sure .
If you have a difficult task, give it to a lazy person -- they will find an easier way to do it. |
18th September 2006, 11:19 | #127 | Link |
I have taken a look at the code and i was busy trying to chain vst's together. I wonder, is anyone still using the program ? even needfull things seems unreachable so i wonder if it would be worth the effort to atleast finish the vst chaining + multichannel recording?
It has been a while and it takes me a lot of effort to understand my 1000's lines of code And to be honest, the program is to complex to really grasp. I should have focussed more on functionality because now its a sort mess with the mapping and the vst chaning and merging of files.
If you have a difficult task, give it to a lazy person -- they will find an easier way to do it. Last edited by johnman; 18th September 2006 at 11:23. |
19th September 2006, 23:22 | #130 | Link |
Oh I think a lot of people are using ww. I've seen several comments to that effect. As for needfulthings, you should ask daphy about that. Last I heard, he was quite busy with work but I'm sure he hasn't completely given up. As for me, I intend to get back into surround once the autumn sets it. Lately I've been exploring, of all things, analog! I heard some transfers of vinyl LPs done from quality turntables and I must say they sounded better than anything I've ever heard on commercial CDs. So right now I'm exploring the possibility of purchasing a new turntable! Given the improved soundstage, etc., I'm actually excited about what kind of source these could be for 5.1!
20th September 2006, 02:09 | #132 | Link | |
foobaring my ass off
Ww is my butt-saver mandatory wonder audio tool for anything surround related. Keep the great work.. (please!!! )
"Damn, respect my authoritay!!" - E. Cartman |
21st September 2006, 17:27 | #133 | Link |
It is somewhat of a strange and unique program and it is capable of doing somethings most other programs can't. But its also not very user friendly, but when you get it to do what you want its kind of cool .
I've got a couple of free days now so i'll have a look if i can jumpstart my sourcecode and get it to work again. now let me get a mirror up, and daphy.. if you are back again send me a msg . !tebunasa, i know you have noticed a couple of bugs long long time ago, ill come to you soon about it and i hope you remember some of the bugs you found. Im afraid i dont . I even have a bit of a problem to use ww :P. edit 2. my computer broke so i only have a onboard soundcard on a very old computer that produces a lot of hum out of my speakers but it will have to do for now i guess :P. New Download link
If you have a difficult task, give it to a lazy person -- they will find an easier way to do it. Last edited by johnman; 21st September 2006 at 17:35. |
21st September 2006, 18:55 | #134 | Link | |
21st September 2006, 19:44 | #135 | Link | |
But i agree that it is to the point . But i would like it to be less functional and more usable. More functionallity in't always better imo.
22nd September 2006, 01:52 | #136 | Link | |
"Seems that Stream manipulation and Channelmapping don't work together, the merged file in pass 5 is always in correct wav order with Channel mapping enabled or disabled." But is solved in two steps for ac3enc.dll, and in one step without mapping thanks to the new encoder Aften with remapping included. Maybe for a new release you need include the new ac3/aac encoders Aften, Nero, CT (winamp). And don't forget a simple remapping option Dolby Prologic II downmix: Code:
6->2#mix#inactive#Dolby Prologic II downmix 0.325 0.000 0.000 0.325 0.230 0.230 0.000 0.000 -0.282 0.163 -0.163 0.282 |
27th October 2006, 10:41 | #137 | Link |
I have taken a look at the project and i really should have made more documentation. I have a little problem figuring it all out again and since i was busy with several things at once some functionallity doesn't work anymore so maybe i have to go back to the latest working release which is a real bummer since i came a long way with recording sound from the soundcard and vst's functionality and some other stuff .
8th November 2006, 13:11 | #139 | Link |
Thank you daphy, nice to be back
I went deep into the code and i am almost back on track from where i left of some time ago.
14th November 2006, 23:17 | #140 | Link |
I’m hoping someone can help me with this problem.
I have a 6-channel PCM wav that I’m trying to turn into an ac3 file. The problem I’m having is with the channel mapping. I cannot figure out how to map them correctly for ac3. No matter what I do, I seem to either get the center channel switched with a rear channel or the left switched with the center, etc. It’s driving me nuts! I’m using Wavewizard to re-map the channels from the wav file. The wav file was originally encoded from a 6-channel AAC file if that helps. Thanks |
