Old 17th February 2012, 17:52   #21  |  Link
mastrboy
You don't have to "get" a version in the way DarkT suggested, if i understood his post as a pirating subliminal message. Microsoft offers 90 day trials of win7: http://technet.microsoft.com/en-us/evalcenter/cc442495 (If you don't have a MSDN or similear account you can get legal win7 trial here: http://www.softpedia.com/get/System/...indows-7.shtml )
mastrboy is offline   Reply With Quote
Old 17th February 2012, 19:41   #22  |  Link
@crl2007
Thankyou for the report, hope you tried the DGIndex batcher too, they work great
together. Shall up a new version, only real change will be compiled with the
recent compiler update.
@DarkT and Mastrboy
Thankyou both, I'm getting the real evaluation copy as suggested by Mastrboy,
am seeing my mate tomorrow as he's back now.
The eval copies are quite usable (I used to use W2K advanced server 90 day)
but are sometimes slightly restricted in certain areas), but when they timeout,
there is no alternative but to reinstall (leastwise thats how it was then).
EDIT: Slipstreaming was not possible in an evaluation version (unless you knew how).
Old 18th February 2012, 12:06   #23  |  Link
mastrboy
You can get the trial to be extended with 30 extra days when it expires with the following command: slmgr -rearm
Old 18th February 2012, 13:06   #24  |  Link
Thankyou kind sir.
Old 19th February 2012, 02:04   #25  |  Link
DarkT
That is all fine, well, and cookies... But, ahhhh, there's these wonderful, mmmmm, versions, yes, versions, which already have sata drivers, as well as, mmm, updates, everything alreayd inside it, and installation proccess semi-unattended... So... If you were to download the trial version... And then download just such a version as I described... Would it not be pretty much, ummm, similar with regards to... "license"? . atleast for the period a trial version would apply... *grins evully and hopes mods are not around*
DarkT is offline   Reply With Quote
Old 21st February 2012, 06:58   #26  |  Link
DarkT,
Yes, tis true, but dont really intend to spend that much time on W7, like it only
a little better than Vista (the pits). Bought Vista 2 days after launch and up until
testing out the Batcher's, had not booted it up for more than two years.
Anyways, I guess that you are quite used to W7 (a little less artificial stupidy
built in), but I really dont like either and am happy to have found a great little
add-on called Classic Shell (http://classicshell.sourceforge.net/) which takes
some of the sting out of the tail, and to some degree, puts you back in charge
(without having to change permissions or whatever).
Got W7 installed now (on an old 2.8 GHz single core m/c) and managed to
get the old graphics driver working OK, shall give the Batcher things a try out
tomorrow. Peace Bro.
Old 24th February 2012, 16:38   #27  |  Link
New version 24 Feb 2012, see 1st post.
EDIT: Working well, XP, Vista, W7.
Old 24th February 2012, 20:28   #28  |  Link
primahadi
automation work good, thx.
whats your next program sir, new x264 gui in pure autoit would be nice.
primahadi is offline   Reply With Quote
Old 25th February 2012, 00:10   #29  |  Link
Whoooow!, dont know bout that, I'm just a beginner!
Glad you like it, saves a lot of work, don't it.
EDIT:- Come to think of it, AutoIt and the IDE comes with a GUI designer, so it might
not be that difficult, you could quite easily pick up AutoIt, very similar to Basic with
the only real nasty being that every variable starts with a '$'. (always forget that
or put it at the end when a string). If you can manage Avisynth script, you should not
have too much difficulty mastering AutoIt, and having eg For/Next loops would seem a
real blessing. Cant say I've ever tried to use x264 directly, and I dont feel any great need
whilst someone else takes on the monster task of maintaining the likes of MeGUI. Must be
a nightmare to keep up with all of the mods in all of the disparate components of MeGUI,
respect to Zathor.
Old 28th May 2012, 05:21   #30  |  Link
Corpsecreate
This program is great. I have 300 .avs scripts to add to the queue and that would be a real pain to do manually.
The only problem I have with it is that it uses the "AutoEncode" option instead of "Queue" in the video section. An option to choose whether or not to use "Queue" or "AutoEncode" at the program startup would make this program even better.
Corpsecreate is offline   Reply With Quote
Old 28th May 2012, 11:10   #31  |  Link
Shall keep it in mind, however, there are I think visible on the main form,
two QUEUE buttons, a QUEUE-ANALYSIS PASS and also a QUEUE tab.
If I could guarantee only 1 instance of an item name then no problem
(eg VQUEUE, AQUEUE). MeGUI is in constant development
and as such things could easily move around and break the Batcher.
Because of the utility having to run on multiple OS (XP, Vista,W7)
and also MeGUI is not in any specific file location, makes it difficult
to identify which button to click, especially if there are eg 3 or 4
items ALL starting with "Queue", on a single system ie mine, no problem.
(there is a unique way to access a button, but it is based on some kind
of hash on the program file location as well as other stuff).
Suggest download AutoIt, if you can code in Avisynth, AutoIt should be
only a small step further. The code is well commented (and is debug version
in editor during interpretation) and should not be too difficult to modify.
I wrote a library of routines for the batchers, to make it easy to eg click
on a button (activate window, wait till active, bring window to front , move
mouse to button, focus on button, click on button, etc all in one command).
You would normally have to execute a load of "Sleep" commands to wait for
a length of time and hope it had happened by then.
EDIT: The whole 'active' sequence loop, where it controls MeGUI is only about
22-25 lines of code (with a debug line telling what it's about to do between each)
and so it would not be too difficult to change.
Could you please enlighten me as to what the problem is with AutoEncode.
You want queue both audio and video, but not mux?
EDIT: Re-reading, looks like you just want Video queued.
EDIT: Give me your reason and I shall try to get it going (no promises).
Old 30th May 2012, 16:00   #32  |  Link
@Corpsecreate
Just a bump in case you did not see my edit above:
Give me your reason/requirements and I shall try to get it going (no promises).
EDIT: also, whats in the AVS's, both audio + video?
Old 1st June 2012, 21:43   #33  |  Link
@Corpsecreate,
Find below MeGUI AutoEncode Batcher v1.11b, with additional options
Queue Video + Audio
Queue Video
Queue Audio
Not tested on anything other than XP, but I envisage no problems.
EDIT: I have not introduced anything new (another dialog box eg FileSelector type)
so there are unlikely to be any problems in either Vista or W7).
Have not included any other files except exec and source, hence provided as beta status.
Should be A.O.K. if anyone else wants to take a peek.
You can get the brief instructions by copy paste from 1st post.
Source for DGIndex Batcher not included.
Sped up the mouse a little, the "Queue Video + Audio" option fairly zips along in comparison
with the slower MeGUI AutoEncode option (where MeGUI does some kind of scanning during
queuing).
Check it out and let us know if it meets your needs.
EDIT: Oops, forgot the link:
EDIT: Link Deleted
Old 10th June 2012, 19:38   #34  |  Link
New Version v1.11 - 10 June 2012.
Old 26th June 2012, 22:00   #35  |  Link
New version v1.12 - 26 June 2012.
Fixed, detects & restores minimized target window, could fail in Executable (not script) when batcher called
via eg desktop shortcut and target is running but minimized (and no other windows open).
Old 19th June 2013, 07:33   #36  |  Link
Corpsecreate
I actually ended up making my own batch tool. Heres a vid of it working.
MeGUI Batcher
Old 19th June 2013, 09:16   #37  |  Link
Published anywhere ?
Old 19th June 2013, 19:36   #38  |  Link
Corpsecreate
Not yet, I'm still making some adjustments. I'll gladly upload it for anyone that finds it useful.
Old 20th June 2013, 05:58   #39  |  Link
Yes please, also source if you will, always happy to learn.
EDIT: Alternative MeGui Batcher thread by Corpsecreate here:
http://forum.doom9.org/showthread.php?t=168131
Old 21st September 2013, 23:24   #40  |  Link
New MeGUI AutoEncode Batcher, Version v1.13. See first post.
autoencode, batcher, megui
