Old 18th June 2017, 16:23   #1  |  Link
renoturks
Megui + Subtitle with fonts and effects
Good Morning =D
Hello guys and girls, it's been ages since i've done something with megui and I've been reading lots of new stuff, but i have a problem.
I have a subtitte .ass with some effects, and i'm trying to encode a video with it via Megui 2715. I can't see to find a way to encode it with it's effects, I have the fonts installed on my desktop.
Could you guys help me out?
If this is a dumb question, I'm sorry to bother you =\
renoturks is offline   Reply With Quote
Old 18th June 2017, 16:27   #2  |  Link
sneaker_ger
Tools -> AVS Script Creator -> Filters -> Subtitles (at the bottom)
Old 18th June 2017, 17:20   #3  |  Link
renoturks
What you said it so insert it, That I did. =D
The problem is that I'm not able to use the fonts that are used on the .ass that was done on Aegisub.
The fonts should appear as the image with the girl, but it's coming like the other one.
http://imgur.com/a/kj7aK
Old 18th June 2017, 17:28   #4  |  Link
sneaker_ger
Font loading with TextSub():
- either copy fonts to Windows' font folder (usually c:\windows\fonts\) or
- start playback in e.g. MPC-HC and pause MPC-HC, then open in MeGUI and encode.
But .. I think for Aegisub to show them they already have to be installed? Not sure what's the problem.
Old 18th June 2017, 18:08   #5  |  Link
renoturks
Hi
I just realized that it's not showing on aegisub too =\
I'll look into it, thanks man =D
Old 18th June 2017, 18:10   #6  |  Link
hello_hello
It's working fine here so maybe there's something wrong with the subtitle file or you didn't install the fonts correctly.
Try changing the font in your subtitle file to a recognisable Windows font such as Comic Sans MS to see if that works as expected.
Old 18th June 2017, 18:41   #7  |  Link
renoturks
Thank you guys, Had to re install the font.
I appreciate for your help =D
effects, mp4, subtitle
