6th October 2017, 12:11 | #15201 | Link |
any chance I can have a feature added?
if I could choose the core of a DTS track within an MKV it would be very helpful, and mean I don't have to use BDtoAVCHD. at the moment it doesn't let me choose core unless its a BD structure. |
6th October 2017, 12:25 | #15202 | Link |
@byteshare
Most likely one of plugins in your script causes crash in avs2yuv.exe. For example I have noticed that TextSub (VSFilter) sometimes crashes avs2yuv.exe in DE mode.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th October 2017 at 12:29. |
11th October 2017, 19:00 | #15204 | Link |
I get a blank decoding error window.
all it says is decoding error, with no text in the window. looking at temp folder i found: getAVSerror "C: cd "C:\Temp\RipBot264temp\job1" "C:\Program Files (x86)\RipBot264\Tools\ffmpeg\bin\ffprobe.exe" -i "C:\Temp\RipBot264temp\job1\getinfo.avs" >> "test.log" 2>&1 " |
12th October 2017, 13:50 | #15205 | Link |
Can somebody send me Bluray 4k (HEVC) sample? For example whole structure with trimmed .m2ts files (less than 100 MB for each file is ok). I've noticed that eac3to added support for HEVC and I would like to check how this works.
12th October 2017, 19:24 | #15206 | Link | |
Silent Reader
Nevermind: Found that recent version is 1.21 and downloaded new zip from first post. Last edited by Wishbringer; 12th October 2017 at 19:44. Reason: Solved |
13th October 2017, 17:47 | #15207 | Link |
hmm... i'm getting massive memory leaks in 1.21
I'm using distributed encoding, the server running Ripbot has 32gb of ram and it consumes 100% of ram to the point of entire windows becoming unstable and crashing... I did switch to MT version of AviSynth from the tools folder. |
15th October 2017, 22:37 | #15209 | Link |
Hi I just updated to 1.21.0 from 1.19.6. It asked me to to update to Avisynth+ MT which I did. Now when I'm running a distributed encode I'm only getting about half the frame rate that I used to. None of the servers are running anywhere close to 100% CPU like they did before the update. Is there a new setting somewhere that I've missed?
16th October 2017, 04:21 | #15210 | Link |
Sorry I didn't realize that I didn't install Avisynth+ correctly. Now that I have, all the servers appear to running properly at close to 100% utilization on all cores. Still the overall framerate appears to be lower than before the 1.21.0 update. I'm using 4 computers, an I7-2700K, I3 6100, Xeon-5450 and an AMD FX-8350. I could normally encode most movies in under an hour but now I'm atleast 25% slower.
16th October 2017, 10:57 | #15211 | Link | |
Problem with Avisynth+ MT
https://i.imgur.com/xCnjrfo.jpg in both version v1.21.0 and old 1.20.X the program run strange slowy and the cpu work alternate, example for 30 seconds the fps count increase, then 5 seconds the fps count remains stationary and then another 30s work again, so for the duration of all file, and the first pass is extreme slowy, but if deactivate "use mutiple processing threads" in both version all run fine without any problem. I have reinstalled program and Avisynth+ MT 3-4 time for test but same problem, i work in 2pass mode in distribuated encoded with one i5 3570k and one i7 6700k both without overclocking and windows 10. ps. sorry for my english i'm italian and i have used google for help me to write this, I hope I was clear. |
16th October 2017, 12:43 | #15212 | Link |
@tkwou and @ pinco1117
Yes disable that option if you do not perform any heavy filtering in script (for example deinterlacing with QMTC or denoising with MDegrain). It was my mistake that I left that option ON by default.
16th October 2017, 17:42 | #15214 | Link |
I've had issues lately with Ripbot not wanting to encode. Here is what I see in the encoding server.
Encoding started... ""\\DESKTOP-PC\Ripbot264temp\tools\avs2yuv\avs2yuv.exe" -seek 0 "\\DESKTOP-PC\RipBot264temp\job1\Chunks\1.avs" -o - | "\\DESKTOP-PC\Ripbot264temp\tools\x264\x264_x64.exe" --opencl --opencl-device 0 --crf 18 --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 1424 --sar 1:1 --level 4.0 --preset veryslow --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --stdin y4m --output "\\DESKTOP-PC\RipBot264temp\job1\Chunks\1.264" -" error: I don't know what "video" means (\\DESKTOP-PC\RipBot264temp\job1\Chunks\1.avs, line 1) y4m [error]: bad sequence header magic x264 [error]: could not open input file `-' Encoding terminated. Nothing has changed on my end other than some IP work. I don't think this would effect things, but instead of having a default IP string from 192.168.1.1 it's been changed to 192.168.35.1 Again, I don't think this is the issue, but felt necessary to post any changes since the program last functioned. I'm running on Windows 7 Pro Last edited by gabbett1; 16th October 2017 at 17:44. |
17th October 2017, 03:10 | #15216 | Link | |
would you leave it on or off? |
17th October 2017, 12:43 | #15217 | Link |
Are you using QMTC or MDegrain in your script?
19th October 2017, 07:51 | #15219 | Link |
OpenCL doesnīt work after Fall Creators Update. Log file says "x264 [warning]: failed to load OpenCL". Open CL Windows shows this:
Platform 0. Name : NVIDIA CUDA Vendor : NVIDIA Corporation Version : OpenCL 1.2 CUDA 9.1.0 Profile : FULL_PROFILE Extensions : cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer 0.0 Device name : GeForce GTX 960 Hardware version : OpenCL 1.2 CUDA Software version : 387.92 OpenCL C version : OpenCL C 1.2 Compute units : 8 Edit: Solved. I reinstalled nvidia driver (same version) and itīs working again. Seems like FCU messes up nvidia drivers. Yesterday my HTPC had problems starting Kodi after Fall Creators Update, something with DXVA. I reinstalled the nvidia driver (the same version as before FCU) and that helped. MS should call it Fail Creators Update. Last edited by stasi; 19th October 2017 at 10:31. |
19th October 2017, 10:25 | #15220 | Link |
I'm not even surprised. Old story. New version=new problems.
I would totally reinstall gpu drivers.
