Old 26th March 2018, 09:38   #14621  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by LigH View Post
Well, the main purpose of eac3to is processing audio streams. To demultiplex subtitles only, you may find tools better specialized in this task. It would help to know your source format (DVD Video, Blu-ray?) to suggest accordingly.
And as the subtitles are muxed into the corresponding files (m2ts, VOB, mkv etc.), eac3to needs to process the whole stream anyway so extracting only the subs is not much faster than extracting audio and subs.
Old 26th March 2018, 13:35   #14622  |  Link
BonumMonstrum
Originally Posted by r0lZ View Post
You can demux the subtitles exactly like any other stream.
Example: demux English subtitles from a BD playlist.
First, issue this command to inspect the content of the playlist:
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 1
You will see something like this:
M2TS, 2 video tracks, 6 audio tracks, 4 subtitle tracks, 0:07:13, 24p /1.001
1: Chapters, 3 chapters
2: h264/AVC  (left eye), 1080p24 /1.001 (16:9)
3: h264/MVC (right eye), 1080p24 /1.001 (16:9)
4: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
   (core: DTS, 5.1 channels, 1509kbps, 48kHz)
5: DTS Hi-Res, English, 5.1 channels, 2046kbps, 48kHz
6: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz, -24ms
7: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz, -24ms
8: AC3, French, 5.1 channels, 640kbps, 48kHz, -24ms
9: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, -24ms
10: Subtitle (PGS), English
11: Subtitle (PGS), English
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
Track 4 is used for destination file "1".
This audio conversion is not supported.
Now, demux the subtitle streams 10 and 11:
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 10: english1.sup 11: english2.sup
Works perfectly for a BD. I suppose that the same method works with any input file.
Thanks a lot, it works, but not perfectly for my goal: My problem was, that I couldn't get the subtitles from some sources due to some audio streams that wasn't supported - and I always only wanted the subtitles. BUT I also would like to know whether there are forced subtitles or not. Normally eac3to creates a file like
"00125 - 7 - Subtitle (PGS), English, 1080 captions" or "1080 captions, 3 Forced captions"
So the automatic naming of eac3to for files would be nice now
At least I can get the subtitles now, thanks a lot for your help!!!!
BonumMonstrum is offline   Reply With Quote
Old 26th March 2018, 14:18   #14623  |  Link
nevcairiel
Originally Posted by richardpl View Post
Have you found actual EAC3 7.1 which are not test streams?
Maybe if you report such streams, there is higher chance of it being supported in FFmpeg.
There is several Blu-ray discs which use this channel setup. If you need more samples, let me know.
Old 27th March 2018, 07:37   #14624  |  Link
FrasierCrane
Issue with E-AC3 tracks?
Hi!
Whenever I try to demux a BluRay (m2ts files) containing an E-AC3 (7.1) audio track, eac3to fails. It can not even extract the core and it just aborts. See the log:
eac3to v3.34
command line: "F:\Clown_BD\eac3to\eac3to.exe" "V:" 1) 6: "T:\Clown_BD\Audio_6_German.AC3" -progressnumbers -LOG="T:\Clown_BD\LOGS\eac3to_PASS3_LOG.LOG"
M2TS, 1 video track, 6 audio tracks, 7 subtitle tracks, 1:45:00, 72p /1.001
1: Chapters, 28 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz, dialnorm: -3dB
(core: DTS, 5.1 channels, 1509kbps, 48kHz, dialnorm: -3dB)
4: DTS Hi-Res, English, 5.1 channels, 2046kbps, 48kHz, dialnorm: -3dB
5: AC3, English, 2.0 channels, 320kbps, 48kHz, dialnorm: -28dB
6: E-AC3, German, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -27dB)
7: E-AC3, Italian, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
8: AC3, English, 2.0 channels, 320kbps, 48kHz, dialnorm: -27dB
9: Subtitle (PGS), English
10: Subtitle (PGS), German
11: Subtitle (PGS), Italian
12: Subtitle (PGS), English
13: Subtitle (PGS), German
14: Subtitle (PGS), Italian
15: Subtitle (PGS), English
[v02] The video bitstream framerate field doesn't seem to match the timestamps. <WARNING>
[a06] Extracting audio track number 6...
[a06] Removing AC3 dialog normalization...
[a06] Extracting E-AC3 core...
[a06] Decoding with libav/ffmpeg...
[a06] The libav decoder reported error -22 while decoding. <ERROR>
Aborted at file position 1048576. <ERROR>
What is the problem and how do I fix it? When demuxxing the other tracks, they are mostly damaged as well (especially the subtitle tracks) - this only happens when there is such an E-AC3 track present in the m2ts file.
Cheers!
FrasierCrane is offline   Reply With Quote
Old 27th March 2018, 10:17   #14625  |  Link
tebasuna51
tebasuna51's Avatar
The issue is already reported to madshi.
The eac3 7.1 tracks reported by eac3to like:
6: E-AC3, German, 7.1 channels, XXXkbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, YYYkbps, 48kHz, dialnorm: -27dB)
Fails when try to extract to EAC3 with:
eac3to "INPUT" 1) 6: output.eac3
[a06] Applying (E-)AC3 delay failed. <ERROR>
Aborted at file position ... <ERROR>
Also fails when try to recode to AC3 (seems than can't extract the core):
eac3to "INPUT" 1) 6: output.ac3
The unique workaround than work is recode the core to AC3 with a explicit -core parameter:
eac3to "INPUT" 1) 6: output.ac3 -core
[a06] Remapping channels...
[a06] Encoding AC3 <640kbps> with libAften...
[a06] Creating file "output.ac3"...
Video track 1 contains X frames.
eac3to processing took Z seconds.
Done.
Old 27th March 2018, 10:24   #14626  |  Link
LigH
LigH's Avatar
So it is one of the usual "notorious" Blu-ray E-AC3 streams with 5.1 AC3 core + 2 differential E-AC3 channels as substream?
New German Gleitz board
Old 27th March 2018, 10:27   #14627  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
I'm not sure I understand. eac3to (and all M2TS demuxers) cannot know if there are forced subtitles without analysing the content of the M2TS file, because that information is not stored in a header or in the MPLS file. So, you have to launch the analysis anyway, then inspect the output and manually give proper file names for the demuxed tracks. I suppose that a good GUI should be able to automate that, but with a GUI, you will have to select manually the streams you want to demux. So, unless you write yourself a tool to do exactly what you want, there will always be things to do manually.
BTW, I forgot to specify that if your M2TS is multi-angle, you have to specify the angle to demux with this (assuming angle 1):
path\to\eac3to.exe V:\BDMV\PLAYLIST\00200.mpls 1) 10: english1.sup 11: english2.sup
(I have edited my previous post accordingly.)
r0lZ
Old 27th March 2018, 16:43   #14628  |  Link
mbcd
This is right, if you have a single forced subtitle at the end of the stream / film, you can not recognize it at beginning of the stream, so you have parse the whole stream to find it. If you dont have some addition file which contains a listing of all streams, you have to decode the complete stream.
mbcd is offline   Reply With Quote
Old 28th March 2018, 21:23   #14629  |  Link
Smithy
The NEW DD+ @ BD have 4 (EAC3) Surround Ch's that replace the 2 Surrounds of the 5.1 AC3 Core Track when 7.1 DD+ is playing !
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3
Smithy is offline   Reply With Quote
Old 29th March 2018, 09:18   #14630  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
After a stalled start with HD-DVD there's no doubt that Dolby Digital Plus is back and expanding it's feature-set, especially as more streaming services embrace object-based (Atmos) audio.
With Atmos in mind... Have any of you guys downloaded Dolby's 7.1.4 and 9.1.6 (DD+ with Atmos) samples, that were muxed into the .mp4 container?
Old 29th March 2018, 09:22   #14631  |  Link
nevcairiel
This is not exactly "new", this setup has been allowed on Blu-ray since forever, it was just rarely used. Still is somewhat rare, but it occurs sometimes.
All that said, FFmpeg should be able to handle this very soon. The patch is basically ready for inclusion. It should come to FFmpeg based players and tools then eventually.
Old 29th March 2018, 10:05   #14632  |  Link
tebasuna51
tebasuna51's Avatar
...FFmpeg should be able to handle this very soon.
Nice to know.
BTW, I suggest a parameter to extract/decode only the 5.1 part for users of 5.1 audio equipment (like me) without need downmix.
Old 29th March 2018, 10:18   #14633  |  Link
richardpl
Yes, there is already eac3_core bitstream filter in git master.
richardpl is offline   Reply With Quote
Old 29th March 2018, 14:26   #14634  |  Link
LigH
LigH's Avatar
Only loosely related: After more than a year, the ffmpeg trac ticket #3595 is active again ... its title got renamed.
Old 29th March 2018, 15:24   #14635  |  Link
richardpl
And everybody donated single penny.
Old 29th March 2018, 20:21   #14636  |  Link
LigH
LigH's Avatar
If I knew it would certainly accelerate something, I would even donate more.
Old 14th April 2018, 05:37   #14637  |  Link
pstn
does anyone know which command to use to demux a 3d bluray but isolate the 2d part?
pstn is offline   Reply With Quote
Old 14th April 2018, 08:31   #14638  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Isn't the video for both eyes as its own track? IIRC the left eye stream is the "main" one to demux.
Old 14th April 2018, 08:47   #14639  |  Link
LigH
LigH's Avatar
This is true when the one eye's content is encoded as AVC video stream, and the other eye's content as MVC substream.
Old 14th April 2018, 09:04   #14640  |  Link
nevcairiel
That is the case for 3DBDs, always. Although left/right could be swapped and the AVC stream actually be the right eye, but there is always one main AVC stream you can just take without the MVC stream to get 2D.
eac3to
