Old 4th November 2017, 15:26   #14441  |  Link
hubblec4
Matroska Dev-Helper
I never see that, 2 mpls with the same m2ts just in reverse order.
A more strange Bluray for such behaviour is: BASTILLE_DAY.
There are more then 500 playlists with the same m2ts files in different orders.
@mtamimi
Looks like the m2ts files are corrupt.
hubblec4 is offline   Reply With Quote
Old 4th November 2017, 15:52   #14442  |  Link
Boulder
Pig on the wing
Boulder's Avatar
They're not strange, that's a form of copy protection.
Old 4th November 2017, 19:37   #14443  |  Link
mtamimi
The problem seems located at time 0:06:26
You can load each m2ts in [9031+22220+13953+7113+17707+18946...] until reach that point.
Maybe is a corrupt m2ts or without the same audio stream than crash eac3to.
I don't know for what Handbrake work, maybe skip the problems without crash.
Are audio/video in sync after the point 0:06:26?
Handbrake reports 2 playlists just like eac3to, however Handbrake also reports only 4 chapters for the 1st playlist, and 10 for the 2nd one. Hence the 2nd one is the correct one. I did encode the disc in Handbrake and the audio is in sync, no issues at all...
I was told that eac3to encodes audio better than Handbrake, so I thought I will use eac3to instead of Handbrake to encode the audio...
Any suggestions?
mtamimi is offline   Reply With Quote
Old 4th November 2017, 19:38   #14444  |  Link
mtamimi
@mtamimi
So how come Handbrake successfully processed the whole disc?!
Old 4th November 2017, 22:09   #14445  |  Link
kron
Hey, guys, is there someway to be sure the audio converted (using eac3to) from DTS HDMA to flac is really lossless?
I mean a program to show the result of such conversion?
kron is offline   Reply With Quote
Old 4th November 2017, 22:22   #14446  |  Link
LigH
LigH's Avatar
Any compressed audio format (DTS-HD as well) is first decoded to uncompressed PCM samples. And this uncompressed audio is then compressed to FLAC.
The encoding to FLAC is lossless, certainly. The name already tells you: Free Lossless Audio Codec.
New German Gleitz board
LigH is online now   Reply With Quote
Old 4th November 2017, 23:05   #14447  |  Link
tebasuna51
tebasuna51's Avatar
Some soft can skip a error and continue.
eac3to abort with a error.
Maybe is a unique DTS frame corrupt and is only 11 ms lossed.
And the async is unnoticeable.
You can try extract only the dts:
eac3to.exe E:\ 2) 3: Audio.dts
without decode maybe eac3to do the job ok.
And after encode to AC3 with ffmpeg (preferred over libaften):
ffmpeg -i Audio.dts -acodec ac3 -ab 640k -center_mixlev 0.707 Audio.ac3
Old 4th November 2017, 23:20   #14448  |  Link
mtamimi
eac3to.exe E:\ 2) 3:Audio.DTSMA
a03 0:27:28 Skipping dirty PES bytes...
I kept getting hundreds of messages similar to the above, so I halted eac3to...What do you think?!
Old 5th November 2017, 13:48   #14449  |  Link
tebasuna51
tebasuna51's Avatar
Then is bug in eac3to or corrupt data in source.
In order to identify the problem you can test the first m2ts with, for instance:
eac3to.exe E:\BDMV\STREAM\22220.m2ts 2: Audio.dts
and upload a small m2ts than show the problem to http://eac3to.bugs.madshi.net/
Old 8th November 2017, 18:03   #14450  |  Link
pstn
s
Does anyone know of a way to demux the whole playlist instead of just the first title in the playlist ? (for blurays of TV series)
pstn is offline   Reply With Quote
Old 8th November 2017, 21:39   #14451  |  Link
tebasuna51
tebasuna51's Avatar
eac3to show the mpls ordered by duration (maybe is not by the chapters order) and you can select the desired playlist.
In the sample before https://forum.doom9.org/showthread.p...09#post1823609
eac3to E:\ 2)
open the second playlist.
Old 8th November 2017, 23:35   #14452  |  Link
pstn
eac3to E:\ 2)
sorry bud, I think I used the wrong terms, what I meant was how do I demux all .mpls at once from a disc? instead of going
"eac3to C:/ejfslflsifsihf 1) -demux"
"eac3to C:/ejfslflsifsihf 2) -demux"
"eac3to C:/ejfslflsifsihf 3) -demux"
"eac3to C:/ejfslflsifsihf 4) -demux"
Old 8th November 2017, 23:48   #14453  |  Link
Music Fan
You can put all these commands in a bat, it will execute them one after the other.
Music Fan is offline   Reply With Quote
Old 9th November 2017, 05:21   #14454  |  Link
Revgen
Feature Request:
Detect DTS:X audio streams.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 11th November 2017, 01:18   #14455  |  Link
XMEN3
XMEN3's Avatar
Another sample with problems.
Remark the different size of extracted .h265
15/10/2017  22:03       177.693.906 Arrival UHD Sample.mkv_ 0.h265  (mkvextract)
15/10/2017  21:59       157.722.039 Arrival UHD Sample.mkv_1eng.h265 (eac3to)
found problem also with last UHD pirates and man of steel ectracted without problem but video size is 2gb less and have artefacts
XMEN3 is offline   Reply With Quote
Old 12th November 2017, 00:05   #14456  |  Link
pstn
thank you
Old 12th November 2017, 02:02   #14457  |  Link
manuelin
Other samples of h265 videos that eac3to extracts its video track with artifacts:
Baby Driver
Pirates of the Caribbean: Dead Men Tell No Tales
Independence Day
I have also seen that this happens with The Fifth Element and Mad Max: Fury Road.
manuelin is offline   Reply With Quote
Old 12th November 2017, 17:56   #14458  |  Link
madshi
Thanks for the samples, everyone. Could you please confirm that this test build fixes the HEVC/h265 issues?
http://madshi.net/eac3toHevcTest.rar
Old 12th November 2017, 19:18   #14459  |  Link
Thunderbolt8
were you able to find enough documentation about HEVC specs?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 12th November 2017, 21:07   #14460  |  Link
manuelin
Thank you very much madshi, I have made a demux of the UHD disk of Baby Driver and Mad Max and now everything works perfect, there are no more artifacts.
Sorry for my bad english and thank you very much again!
eac3to
