31st December 2015, 11:45 | #21 | Link |
I’ve got more or less the same performances and thread counts in both versions (i7 4770K, 4 cores 8 threads).
Old 1.0.1: Code:
Frames processed: 200 (0 - 199) FPS (min | max | average): 3.366 | 9.113 | 4.687 Memory usage (phys | virt): 555 | 553 MB Thread count: 14 CPU usage (average): 81% Code:
Frames processed: 200 (0 - 199) FPS (min | max | average): 3.407 | 8.902 | 4.642 Memory usage (phys | virt): 554 | 552 MB Thread count: 14 CPU usage (average): 82% Forcing avstp_set_threads(10): Old 1.0.1: Code:
Frames processed: 200 (0 - 199) FPS (min | max | average): 3.286 | 7.798 | 3.997 Memory usage (phys | virt): 555 | 553 MB Thread count: 16 CPU usage (average): 65% Code:
Frames processed: 200 (0 - 199) FPS (min | max | average): 3.270 | 7.877 | 3.948 Memory usage (phys | virt): 554 | 552 MB Thread count: 16 CPU usage (average): 65%
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
31st December 2015, 12:09 | #22 | Link | |
But why does AVSMeter show the same number of threads for both versions in your setup? |
15th February 2016, 02:12 | #24 | Link | |
Use VirusTotal uploader for checking files. https://www.virustotal.com/en/file/4...is/1455158866/ |
22nd May 2016, 22:53 | #25 | Link | |
LoadPlugin: unable to load "C:\blu\MeGUI\tools\avisynth_plugin\cretindesalpes\avstp.dll", error=0xc1 ED: I was attempting to use avstp with AviSynth MT 2.60, which is apparently stupid and pointless. My mistake. ED2: I was mistakenly attempting to use the X64 version with 32-bit AviSynth (both ST and MT) and it appears that's what caused the error. Loading the one with the proper architecture (duh) avoids this nonsense. Last edited by bilditup1; 23rd May 2016 at 01:00. Reason: foolishness |
7th October 2020, 11:01 | #26 | Link |
For some reason, I just updated the internal code and compiled AVSTP with modern tools. From the end user point of view, there shouldn’t be any significant difference with the previous version, excepted that Win XP is not supported anymore (I guess this isn’t a big deal nowadays).
See the first post for download.
8th October 2020, 06:38 | #27 | Link | |
See My Avisynth Stuff |
8th October 2020, 11:17 | #28 | Link |
real.finder:
I wasn’t aware of it. Using the Avs+ threadpool is probably more logical, but supporting two APIs in each filter is a lot of work.
14th October 2020, 10:17 | #29 | Link |
what about make AVSTP use it (act like a warper for avs+ one) if that possible? if it possible then maybe making special version for avs+ or maybe making AVSTP see if it avs+ or not to either use it own or avs+ one
13th November 2020, 23:22 | #30 | Link | |
Broadcast Encoder
That's too bad, in fact the new version of the package produces an access violation on XP. Is it just a compilation issue or did you change something complex internally not to make it XP compatible? Would you be so kind to re-compile with the v141_xp? |
14th November 2020, 03:43 | #31 | Link | |
just continue using the old version, thats what I would be doing. EDIT: Cretindesalpes probably only updated his project files for new compiler [and dumped the older compiler], just so it would compile properly, probably just done for 'uniformity' of his projects.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th November 2020 at 04:01. |
11th May 2021, 08:15 | #33 | Link |
mvtools bug with avstp.dll here:
https://forum.doom9.org/showthread.p...90#post1942490 |
11th May 2021, 10:06 | #34 | Link | |
anyway, if it not avstp bug (mostly) this should be reported to pinterf since he do update mvools recently, the last login of pinterf was from 2 weeks ago I think, lets hope he is fine
See My Avisynth Stuff Last edited by real.finder; 11th May 2021 at 10:09. |
25th November 2021, 08:52 | #36 | Link |
Hi, I saw you have fmtconv on git, will it happen to avstp as well?
I found some issues with actual 1.04 (both in linux/gcc compatibility and a threading issue), just asking if we can discuss it on git "issues" or "discussions" section or here (or in PM) |
25th November 2021, 13:03 | #37 | Link |
Broadcast Encoder
and let's also remember the "frozen as ice" thingy caused by avstp...
25th November 2021, 19:13 | #38 | Link | ||
24th January 2023, 01:04 | #39 | Link | |
https://github.com/pinterf/AVSTP/releases |
