27th September 2008, 21:03 | #21 | Link |
AviSynth plugger
here is v2.0.0.3 alpha
http://avisynth.org.ru/mvtools/mvtools-v2.0.0.3.zip project file for codeblocks: mvtools-super.cbp New documentaton is missing. Current using (may be changed without notification ): avisource() super=MVSuper(hpad=8, vpad=8, pel=2, sharp=2, rfilter=1) vb=MVAnalyse(super,isb=true) # any old MVAnalyse params besides above vf=MVAnalyse(super,isb=false) MVDegrain1(last,mvbw=vb,mvfw=vf,super=super) I note some speed increasing and memory usage decreasing. Please test. About syntax and implementation. superframe contains all source video data. So, it is possible implement clients (like MVDegrain1) without usage of source (i.e. last clip): MVDegrain1(super,mvbw=vb,mvfw=vf) But super clip does not contain source audio (i killed it). Of course we can use audiodub.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 27th September 2008 at 21:15. |
27th September 2008, 23:45 | #22 | Link |
Avisynth language lover
Sorry to bring up the 'implicit last' issue yet again, but it's such a fundamental part of Avisynth usage that I think it's important to get it as right as possible. Would this be a valid sequence:
avisource() MVSuper(hpad=8, vpad=8, pel=2, sharp=2, rfilter=1) vb=MVAnalyse(isb=true) vf=MVAnalyse(isb=false) MVDegrain1(mvbw=vb,mvfw=vf) with the last 3 implicitly using the result of MVSuper? Why kill the audio? I don't understand that. Or does it hide extra data in what would otherwise be audio properties? |
28th September 2008, 01:04 | #23 | Link |
Looking at the proposal of superframe concept, it seems that some possible kind of processing "tricks" are lost.
One "trick" you could do with v1.x is this: Code:
source = last vb = source.MVAnalyse(isb=true, idx=1) vf = source.MVAnalyse(isb=false,idx=1) alt = source.blur(1) # example for an "alternate" spatial or spatio-temporal filter result = alt.MVDegrain1(vb,vf,idx=1) # *same* idx ! This way you get "automatically" weighting-in of the alternate filter in places where compensated blocks get less weighting (due to thSAD). If all compensations "fail" completely, the result is 100% of the alternate filter. Now with the new superframe concept, it seems no more possible to do this kind of "mixing". You get only vanilla "no processing" for failed compensation areas. To get that "functionality" (though it's a trick) back, it would require to additionally include the alternate filtered clip into the superframe? Some more thoughts should be thrown about handling of "failed compensation" blocks in MVDegrain. (par ex., the mix achieved by the given code example is not optimal either - in areas where compensation is successful, it gives too much weight to "alternate".) But for today, it's too late now.
28th September 2008, 04:19 | #24 | Link |
Avisynth Developer
@Fizick,
I had a thought on a way, for a function like MVSuper, to return a set of clips. Currently you pack all the levels into a monster single clip, "super". Strikes me that you would really like each level to be a single ordinary clip and be able pass all these level clips around as a single unit. If you create all these PClips and then assign each to unique var name, you only need return all the var names, say as a string. Code:
AVSValue __cdecl Create_MVSuper(AVSValue args, void* user_data, IScriptEnvironment* env) { ... // AVSValue level0clip = AVSValue((PClip)(new LevelClip(child, 0, ... , env))); level0clip = env->Invoke("Cache", level0clip); // Add a cache AVSValue level1clip = AVSValue((PClip)(new LevelClip(level0clip.AsClip(), 0, ... , env))); level1clip = env->Invoke("Cache", level0clip); // Add a cache ... // Use hex of object pointer to make a unique name char *level0name = env->Sprintf("MVInternal_%08x", (int)level0clip.AsClip()); char *level1name = env->Sprintf("MVInternal_%08x", (int)level1clip.AsClip()); ... // env->SetGlobalVar(level0name, AVSValue(level0clip)); env->SetGlobalVar(level1name, AVSValue(level1clip)); ... // Pass back all the relevant info char *ReturnString = env->Sprintf("hpad=%d, vpad=%d, pel=%d, levels=%d, level0=%s, level1=%s, ...", hpad, vpad, pels, levels, level0name, level1name, ...); return AVSValue(ReturnString); } |
28th September 2008, 05:52 | #25 | Link |
AviSynth plugger
IanB,
If we would have so many multi-level clips (and GetFrames calls), will it pollute the avisynth cache? Or it is dependent not on number of clips (frames), but on their sizes only? BTW, i have got about 10% speed increasing with v.2.0, probably due to better caching
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 28th September 2008 at 05:55. |
28th September 2008, 06:15 | #26 | Link |
AviSynth plugger
Gavino,
I agree, that now it is a very good chance to change (improve or brake) the syntax. Implicit last works with super in MVAnalyse v2.0. Implicit last will work perectly with MVDegrain1 and other client fuctions if I make all clips parameters as annamed: Code:
replace c[super]c[mvbw]c[mvfw]c[thsad]i.... to: cccc[thsad]i... MVDegrain1(super=super, mvbw=vb, mvfw=vf) will be not accepted (There are no named param super...) so we must use : MVDegrain1(super, vb, vf) It is easy change of code , it may be done in any moment. I ask opinion from other users and script writers
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
28th September 2008, 06:35 | #27 | Link |
AviSynth plugger
Didée,
yes this is a trick. I do not see that it is used in any script probably beside your secret unpubliched It is not documented way. If you need in such processing, it may be somehow implemented. Well, here is suggested way to use different clips for motion estimation and compensation: avisource() super=MVSuper() # super original clip f=blur(1.0) # filtered clip fsuper=MVSuper(f) # super filtered clip vb=MVAnalyse(fsuper,isb=true) vf=MVAnalyse(fsuper,isb=false) MVDegrain1(last,super=super,vb,vf) So, for your trick the last line should be changed to : MVDegrain1(f,super=super,vb,vf) this should works in v2.0.0.3, please check. BTW, I considered to remove source clip reading in next MVDegrain1 alpha (and get all info from super source clip), but after your request it will be preserved.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 10th October 2008 at 22:39. Reason: new unnamed clips syntax |
28th September 2008, 08:09 | #28 | Link | |
Avisynth Developer
As far as I understand your new code, (still reading it), all the clips and their GetFrame calls are already present in some abstracted form. My theory is to try and make them all separate regular Avisynth clips as much as possible. If a component contains image data then as a separate clip you should be able to process it with any normal Avisynth filter, e.g. once you have a level clip you may use any resizer available to make the next level if you want. The example with Didée above with separate level clips would be a lot better. Only the levels actually used in a Super would be rendered and cached. As you currently have it you must build both complete Super clip at all levels, maybe this is still required and there is no gain to be found, I do not currently understand enough to predict. Also for multithreading having components distinct means that maybe they can be processed in parallel. Also for your implicit last problem you can overload the function definitions twice and use the user data value to know which one is current. Code:
env->AddFunction("MVDegrain1", "ccc[thSAD]i[thSADC]i[plane]i[limit]i[super]c[idx]i[thSCD1]i[thSCD2]i[isse]b", Create_MVDegrain1, (void*)0); env->AddFunction("MVDegrain1", "c[thSAD]i[thSADC]i[plane]i[limit]i[super]c[idx]i[thSCD1]i[thSCD2]i[isse]b[mvbw]c[mvfw]c", Create_MVDegrain1, (void*)2); Code:
AVSValue __cdecl Create_MVDegrain1(AVSValue args, void* user_data, IScriptEnvironment* env) { int A = (int)user_data; int plane = args[5-A].AsInt(4); ... int thSAD = args[3-A].AsInt(400); return new MVDegrain1( args[0].AsClip(), args[A?12:1].AsClip(), // mvbw args[A?13:2].AsClip(), // mvfw thSAD, // thSAD args[4-A].AsInt(thSAD), // thSADC YUVplanes, // YUV planes args[6-A].AsInt(255), // limit args[7-A].AsClip(), // prep clip args[8-A].AsInt(0), args[9-A].AsInt(MV_DEFAULT_SCD1), args[10-A].AsInt(MV_DEFAULT_SCD2), args[11-A].AsBool(true), env); } |
28th September 2008, 16:12 | #30 | Link |
AviSynth plugger
Probably currently i will agree with Gavino and AVIL, and wait when IanB make some internal trick in Avisynth 2.6.X to have option to mark some named agruments mandatory (some modifier like "!")
c[super]c![mvbw]c![mvfw]c![thsad]i.... IanB, probably trick wih strings is possible, but I am not very like globals and checking of non-coincided clip names (with multitreading). But i like idea to have an option to produce super clip without MVTools. That is why I remove all non-pixel metadata from super frames. It is possible to process super clip wit some user filter. Generally say, my goals of MVTools v2.0 are more speed, clarity and stability. With using of normal avisynth cache and removing idx and other hacks. IMO, these goals are achieved Note. I assume that it is not very hard to add some MVTools parameters (mostly MVAnalysisData) to videoinfo structure in avisynth.h like: int mvtools_version; int mvtools_hpad; (or may be simply mvtools1) ... etc, and some reserved space for future using: mvtools_reserved1; (or may be simply reserved1) mvtools_reserved2; ... It is only several bytes fo my metadata parameters. If we will add them to the end of vi structure, we can preserve compatibility with 2.5 plugins, right? I do not see many other plugins what need in such parameters.
29th September 2008, 00:37 | #31 | Link | |||||
Avisynth Developer
vi.num_audio_samples=nHeight+(nHPad<<16)+(nVPad<<24)+((_int64)(nPel)<<32)+((_int64)nModeYUV<<40)+((_int64)nLevels<<48); If you continue with using a packed super clip then you might as well just pack this data into every super clip frame. If you use my string idea then it comes for free. If you use an AVSValue array as we had discussed a while ago then it is also for free. Last edited by IanB; 29th September 2008 at 00:40. |
30th September 2008, 04:46 | #32 | Link |
AviSynth plugger
AVIL,
I switch to planar packed to interleaved YUY2 (same as kassandro) for super clip storage in next alpha. It is faster.
30th September 2008, 04:48 | #33 | Link |
AviSynth plugger
IanB, can 48 bytes be extended in v2.6?
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 8th November 2008 at 09:06. |
30th September 2008, 15:32 | #35 | Link | |
An idea. ¿Could be make compatibility between kassandro's YUY2 planar form and YV16? Anyway thanks for your efforts. |
30th September 2008, 18:05 | #36 | Link |
AviSynth plugger
IanB,
it is not a irresistible reason to stop progress. Let's add first extra vi parameter as an some keymark (Is26ExtraParamsUsed), and check this key in new 2.6 filters and plugins with appropriate ThrowError message if it is not coincide. AVIL, are you use Avisynth v2.6 prealpha? What do you mean as "compatibility" ? Some format conversion function (plugin)?
30th September 2008, 18:38 | #37 | Link |
@Fizick:
Actually i use version 2.5.7. For compatibility means that clips used by interleaved2planar()/planar2interleaved() follows the avisynth planar structure : http://avisynth.org/mediawiki/Filter..._Planar_Images so almost native (or external) plugin that accepts planar files (yv12, yv16,...) could accepts this clips too. Number of conversions in complexe scripts (see http://forum.doom9.org/showpost.php?...&postcount=150) could be dramatically reduced. |
30th September 2008, 19:19 | #38 | Link |
AviSynth plugger
AVIL,
I missed, that MaskTools recently (in February ) got support of yuy2 planar. I will consider to add support of this to MVTools
2nd October 2008, 13:12 | #39 | Link |
AviSynth plugger
here is next 2.0.7.0 alpha.
http://avisynth.org.ru/mvtools/mvtools-v2.0.7.0.zip Docs is absent. Implemented functions: MVSuper(source, hpad, vpad, pel, levels, chroma, sharp, rfilter, pelclip, isse, planar) MVAnalyse(super,blksize,...) MVFlowFps(source,super,mvbw,mvfw,...,planar=true) MVFlow(source,super,vec,...,planar=true) MVCompensate(source,super,vec,...,planar=true) MVShow(source,vec,...,planar=true) MVMask(source,vec,...,planar=true) MVDegrain1(source,super,mvbw,mvfw,...,planar=true) MVDegrain2(source,super,mvbw,mvfw,mvbw2,mvfw2,...,planar=true) So, all functions (besides MVAnalyse) got planar parameter for YUY2 planar input and output. Default = false (i.e. normal interleaved YUY2), slower. All (mandatory) clip parameters lost their names, and mvbw=vb is not correct syntax now. Use unnamed syntax. I will consider IanB's suggestion later, afrer small "vacations"
13th October 2008, 21:21 | #40 | Link |
AviSynth plugger
here is next 2.0.9.0 alpha.
http://avisynth.org.ru/mvtools/mvtools-v2.0.9.0.zip Implemented more functions without idx: MVSCDetection, MVDepan, MVFlowInter, MVBlockFps, MVFlowBlur, MVDegrain3, MVRecalculate Fixed crashes with MVSuper(chroma=false) Some small changes and fixes for v2.0 of course Documentation for v2.0, see here: http://avisynth.org.ru/mvtools/mvtools2.html I also have an intention to remove some obsolete functions, in particular MVDenoise, MVFlowFPS2
