15th April 2010, 04:45 | #12481 | Link | |
As for the refresh rate, if you cannot get 24hz I would advise using 72hz (is a multiple of 24) and a tool called reclock (http://forum.slysoft.com/forumdisplay.php?f=85) but it can be tricky to set up. What you need to get is the reclock icon in the taskbar to go green, you change both the speed and slowdown media options in it to 5%. Enable the v-sync options in reclock also. This tool will speed up the media to match your refresh rate. Lasty use EVR-SYNC renderer (with reclock) with the option present at nearest v-sync. If you do everything right you will get stutter free playback. |
15th April 2010, 10:57 | #12483 | Link |
Tested some new ATI beta drivers:
http://forums.guru3d.com/showthread.php?t=319691 The drivers works for XP/Vista/W7 ,32&64bit. Also works for old AGP HD2xxx and 3xxx series. Tested a video 720p H264,L@5.1 profile and 16ref.frames in MPC-HC. With internal MPC_HC DXVA decoder (compatibility mode=no check) the video plays with artifacts , less visible than with the previous ATI drivers. A slightly improvement though. Nice AVIVO features with these drivers too. Edit: Tested with Vista32bit and my old HD3650 based HTPC. Last edited by edigee; 15th April 2010 at 11:07. |
15th April 2010, 12:31 | #12484 | Link | |
MPC-HC Project Manager
http://sourceforge.net/apps/trac/mpc-hc/ticket/153
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
15th April 2010, 15:09 | #12485 | Link |
MPC-BE DEV
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
16th April 2010, 06:56 | #12487 | Link | |
But we need someone to test it and post the result here, otherwise the progress will be slow down a lot.
Hong Kong - International Joke Center (after 1997-6-30) |
16th April 2010, 09:25 | #12488 | Link |
Hello people,
I've just installed Windows 7-64 bit, coming from XP SP3 32 bit. I´ve installed Win7 via dual-boot. When i installed MPT-HT 1788 yesterday, it didnt work. It started up almost full-screen and without file-menu. After a short while i figured out that i have to start the process in Vista SP1 compatibility mode. All works fine then. Is this a known issue ? Last edited by G_M_C; 16th April 2010 at 09:34. |
16th April 2010, 09:40 | #12489 | Link | |
16th April 2010, 10:59 | #12490 | Link |
I just installed the catalyst 10.5 and it's true, there is now support for above L4.1 files. Also some L4.1 files i had that showed corruption do not anymore.
But some of the files i tested still hang, so no more corruption but the video gets stuck while the audio continues, good chance that this is a bug in mpc-hc/ffdshow dxva code though
16th April 2010, 12:07 | #12491 | Link |
Perhaps it just ignores the level now and only looks at the other parameters like references frames?
MPC-HC 2.2.1 |
16th April 2010, 12:09 | #12492 | Link |
@tetsuo55:
Are we talking about the same drivers? http://forums.guru3d.com/showthread.php?t=319691 http://forum.doom9.org/showthread.ph...59#post1391859 Maybe you have a card with UVD2 or 2.2 . Mine is UVD+ and the changes are minor. Edit: Does anyone tested the new ATI drivers with ffdshow H264 DXVA decoder? Last edited by edigee; 16th April 2010 at 12:11. |
16th April 2010, 12:10 | #12493 | Link | ||
Yes! After disabling the DXVA-check within the MPC-videodecoder my Radeon 5450 card played some 1080P-MKV with 8 B-Frames without any errors! This also runs fine with the Catalyst 10.3 and 10.4 preview driver.
However I found out there are some video files with lower resolutions that does show artefacts while playing with DXVA, so the DXVA-check list needs to be updated. Here is some info about files that shows artefacts on Radeon 4000/5000-cards. For this files DXVA should be disabled. Quote:
16th April 2010, 13:05 | #12495 | Link | ||
After using load subtitles then save subtitles functions MPC-HC doesn't "see" the subtitles (the .srt file) saved in the same folder as the video unless I delete (or empty) the default.mpcpl file from the MPC-HC folder ( I'm using a ini file for settings) or I play other video with subtitles
If I open the default.mpcpl after trying to play the video for which I've used load then save subtitles functions I can see only the video file inside and NOT the srt file too or nothing (= the default behavior) EDIT : Last working version I've tested is 1775 first not working is 1779 so my guess is that problem starts in rev Quote:
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 16th April 2010 at 14:46. |
16th April 2010, 17:15 | #12497 | Link | ||
I just grabbed the installer version of MPC-HT 1788 from xvid-video.ru and installed that on this clean system. one point of interest maybe: Windows 7 insists on numbering my secondary-display, my TV, as "1" and my main screen as "2". Have no idea how to reverse that order, and why windows does that for that matter. Maybe Windows chooses the main display based on which has the highest resolution ? Second point of interest: User account control [UAC] is switched. on. It protects by limiting reading from and writing to registry, am i right ? It does pop up when i dont start up in vista compatilbillity mode. Might that be what's preventing MPC-HT to start up reguarly ? Last edited by G_M_C; 17th April 2010 at 08:05. |
16th April 2010, 17:39 | #12498 | Link |
Fullscreen problem still exists in image below, where the image isn't 100% filling the screen, the taskbar can be seen.
For the evr-cp guys, can you notice any problem with the graph above. It was playing perfectly for a few minutes, then all of a sudden it moves like 3 frames every second. The above image is taken when it starts this. It has happened with all versions of nvidia drivers for the last few months, and only happens maybe once a week. Do any of the stats indicate what the stutter problem is caused by? |
