Old 2nd January 2012, 19:17   #21  |  Link
oreons
MkvToMp4 author
Version 0.218 - http://www.mediafire.com/?u08lyu6ogma1duq
New in version:
1. Added labels to the buttons
2. Separate settings for encoding music files. Ability encode to ALAC.
3. The choice of variant for the encoder CoreAudioToolbox. It uses the QAAC version 1.0 and above.
4. Settings for dynamic range compression (DRC) for AC3 and DTS tracks. Using Sox to DRC.
Ability to create a spectrogram for the audio tracks. They are placed to the directory Temp\Spectrograms
5.The output of tags in text form, comfortable for copying.
6. The "About" form.
7. Correction of the subtitle for the normal display in QuickTime Player.
8. Logs are stored in a separate directory Temp\Logs and have a unique name for each run.
9. Copy chapters from one film to another.
oreons is offline   Reply With Quote
Old 10th January 2012, 21:47   #22  |  Link
Foofaraw
So what do you do when there is no sound in the output?
It's odd though, because in the Temp directory there is a wav file with the sound track (downcoded from ac3)
Foofaraw is offline   Reply With Quote
Old 11th January 2012, 05:56   #23  |  Link
oreons
MkvToMp4 author
Please write program log (at the directory Temp\log)
Old 15th January 2012, 18:19   #24  |  Link
Balthazar2k4
Oreons, are you still looking into the TrueHD->AC3 issue? I know you have been busy and you mentioned you might take a look at it for the next version. The more I use your program the more I wish it worked with TrueHD. I have said several times already, but fantastic tool and that is really the only issue left for me.
Balthazar2k4 is offline   Reply With Quote
Old 15th January 2012, 18:41   #25  |  Link
oreons
MkvToMp4 author
Try this test version: http://www.mediafire.com/?f7lfejo1m4orpyc
(replace MkvToMp4.exe from the archive)
Old 15th January 2012, 20:25   #26  |  Link
Kalle333
problem converting ac3 6ch to AAC5.1 on some files
I only have stereo speaker equipment but after converting to AAC5.1
the centerspeaker track in ac3 is converted to left speaker in aac5.1
i other words: i can hear the center track of ac3 on left+right channel but
the center track of aac on left channel.
This is what MkvToMp4 v0.218 (and v0.219) do:
extract AC3
Azid -p 6ch -a -n true (ac3 to wav)
qaac --quality 2 --ignorelength --tvbr 107 (wav to aac)
the wav file and aac file sounds the same to me. (center on left channel only)
So azid conversion may be wrong. azid have an option to
to analyze this a bit I opened the wav file with reaper and I get this order:
front left
front right
rear left
rear right
center
LFE
which i figured out is wrong.
the right order should be:
front left
center
front right
LFE
rear left
rear right
which i get when i run azid with the following option:
azid -d 3/2 -o L,R,C,LFE,SL,SR "track.ac3" "track.wav"
(btw: this is the same result with LameXP)
please check this and maybe change it in the next version.
Kalle333 is offline   Reply With Quote
Old 15th January 2012, 20:54   #27  |  Link
oreons
MkvToMp4 author
Kalle333
Thank you, I'll test this problem.
Old 16th January 2012, 00:35   #28  |  Link
Balthazar2k4
Thanks Oreons. I will give this a try tonight and let you know. Also, is the program supposed to keep the settings I save? I have to go into settings each time I open the program and change settings to what I want even after hitting "save".
Old 16th January 2012, 06:57   #29  |  Link
Balthazar2k4
TrueHD was a no-go in this version. Here's an excerpt from the log:
Starting FFmpeg with the parameters:
Tools\ffmpeg\ffmpeg -i "P:/Movies/abcd/abcd.Blu-ray.mkv" -map 0.1 -acodec copy -y "TEMP\abcd.Blu-ray_external_audio_0_track_1.TrueHD"
FFmpeg terminated with error: 1
Old 16th January 2012, 08:18   #30  |  Link
oreons
MkvToMp4 author
Balthazar2k4
Yes, I'll fix it. I coded the external TrueHD track, not in a container.
Old 16th January 2012, 09:19   #31  |  Link
Foofaraw
Repack/encoder video to MP4 for Apple iPhone, iPad, ATV2. MkvToMp4 version 0.218
Build from: Jan  1 2012 22:57:24
Use log file: Temp\Logs\11_01_2012_16_29_57.txt
QuickTime version: 7.5.5
CoreAudioToolbox not installed.
Added on list: D:/File.mkv
Started processing file: D:/File.mkv
Starting MkvExtract with the parameters:
Tools\mkvextract\mkvextract tracks "D:/File.mkv"  1:"Temp\video.264"  2:"Temp\File_internal_audio_2.AC3"
Extracting track 1 with the CodecID 'V_MPEG4/ISO/AVC' to the file 'Temp\video.264'. Container format: AVC/h.264 elementary stream
Extracting track 2 with the CodecID 'A_AC3' to the file 'Temp\File_internal_audio_2.AC3'. Container format: Dolby Digital (AC3)
Starting DelayCut with the parameters:
Tools\DelayCut\delaycut.exe -start 24 "D:/MkvToMp4_0.218/Temp/File_internal_audio_2.AC3"
Starting Azid with the parameters:
Tools\Azid\Azid -a -n true  -c heavy  "D:/MkvToMp4_0.218/Temp/File_internal_audio_2.AC3" "Temp\File_internal_audio_2.wav"
Azid AC3 Decoder 1.9 (build 922) -- for Intel Pentium 4
Copyright (C) 1997-2003 By Midas <midas@egon.gyaloglo.hu>
Starting Qaac with the parameters:
Tools\qaac\qaac  --quality 2 --ignorelength --tvbr 95 "D:/MkvToMp4_0.218/Temp/File_internal_audio_2.wav" -o "Temp\File_internal_audio_2.m4a"
initializing QTML...done
qaac 0.86, QuickTime 7.5.5
Error: -206: setProperty: scda/osbd
Qaac terminated with error: 2
Starting Mp4Box with the parameters:
Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=25.000:lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.218" "D:\File.m4v"
AVC-H264 import - frame size 1280 x 720 at 25.000 FPS
Import results: 926 samples - Slices: 18 I 283 P 625 B - 0 SEI - 13 IDR
	Stream uses B-slice references - max frame delay 2
Setting up iTunes/iPod file...
Forcing AVC/H264 SAR to 1:1...
Saving D:\File.m4v: 0.500 secs Interleaving
Correction mp4 file.
TKHD atom correction for video. TRAK 1
The file <b>D:/File.mkv</b> is processed successfully
File processing time: 4 sec.
Total time: 4 sec.
Old 16th January 2012, 09:49   #32  |  Link
oreons
MkvToMp4 author
Foofaraw
An error occurred while encoding the sound, try changing the codec to Nero (Setup-tab Audio), or reinstall QuickTime.
Old 16th January 2012, 15:56   #33  |  Link
Foofaraw
Ah, so quicktime has to be installed. Oh well.
Old 16th January 2012, 16:41   #34  |  Link
Hobbe
Is it ok to update programs in the tools folder?.. Some are very old.. like ffmpeg, mkvtoolnix, x264, qaac...
Hobbe is offline   Reply With Quote
Old 16th January 2012, 20:02   #35  |  Link
oreons
MkvToMp4 author
Hobbe
Complete set of programs been tested, the new version may be unstable.
Old 19th January 2012, 04:05   #36  |  Link
Balthazar2k4
Not to be pushy, but any updates on the TrueHD issue?
Old 19th January 2012, 15:24   #37  |  Link
oreons
MkvToMp4 author
Not yet.
Old 19th January 2012, 17:13   #38  |  Link
Foofaraw
Are there plans to one day make this repack work without quicktime being installed?
Old 19th January 2012, 17:58   #39  |  Link
oreons
MkvToMp4 author
Foofaraw
You can use Nero or CoreAudioToolbox codec, see Setup-Audio-AAC codec.
Old 20th January 2012, 10:33   #40  |  Link
Foofaraw
Foofaraw
Let me rephrase: Will it ever be possible to remux without having to install codec on the computer.
mkv, mkvtomp4, mp4, repack, video
