19th January 2012, 02:35 | #1363 | Link | |
I also have a lot of experience using Arcsoft codecs in MPC (this is because I *have* to use their renderer in order to pass-through DTS-MA or TrueHD.) Long story, it can be done, but it's really tricky (the GUI for the Standalone Arcsoft decoder is buggy since it's not used in TMT for instance.) I'm typing this at the auto mechanic on my phone, so I cannot go into more detail right now. A few questions (sorry if they're answered in your earlier posts-it's too tough to check on the phone.) -I've seen you talk about multiple fps's...which has the sync issues (60fps?) The reason I ask what country is some countries use PAL for their tv's (this is on the tv itself) (25/50 fps) and others use NTSC (60 fps with movies at 24 (not 25 fps.) If your source material is 25 and your tv is 24, or if the source is 60 and your display is 50...there's your audio disconnect! Arcsoft handles this internally but Reclock does even better. -If it is a matter of overloading your GPU I would suggest looking into software decoding (ie turn off CUVID...set it to "none") -Are you having these problems with Lossless material (like TrueHD) or lossy? Your screenshots are all over the place-for instance you don't have h264 selected as an input on the video decoder and you didn't have DTS selected on the audio decoder. that will cause it to bypass to the next highest merit codec. In short, they're handled completely differently. Ok my car is ready...I hope this helps. Id be willing to chat you through in more detail when your home (like checking GPU-Z, codec merits, input settings, etc...) |
25th January 2012, 13:33 | #1364 | Link |
I've tested LAV CUVID on my HTPC Asrock 330ION with ATOM330 CPU and nVidia ION GPU, but the performance is rather slow if compared with CoreAVC CUDA, even if I get the best results with ffdshow DXVA decoder or MPC-HC DXVA internal decoder. Instead, I love LAV splitter, which on my HTPC is much more performant then Haali.
3rd February 2012, 03:06 | #1365 | Link |
Kid for Today
hi nev, this splitter is getting better and better so kudos for that =)
I've had some problems w/ some 25fps progessive mpeg2 content that would output as 50fps for some reason...I'll try to come up w/ a sample, but do you think you could possibly put the version number on the very top of this thread please? so when we hover the mouse on top of your thread, we could see the latest version number as w/ mVR: Last edited by leeperry; 3rd February 2012 at 22:36. |
3rd February 2012, 07:49 | #1366 | Link |
Its kind of useless to mention a version number for a filter that is essentially dead and deprecated, so i put that commend in there instead.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd February 2012 at 07:52. |
3rd February 2012, 20:56 | #1367 | Link | |
Look here:http://forum.doom9.org/showthread.php?t=156191 Use this please, my test result always shows that LAV Video(CUVID) performs faster than CoreAVC CUDA or ffdshow DXVA on my VP4 card or VP5. |
4th February 2012, 02:26 | #1368 | Link | |
Kid for Today
I've sent you a link in PM to that sample I mentioned earlier. |
9th February 2012, 18:28 | #1370 | Link |
Why is this thread still at the top of the page? Dump this already. LAV Filters should be at the top! BTW I think both LAV CUVID or LAV Filters should be in the same subforum it's confusing :P
9th February 2012, 18:33 | #1371 | Link |
Its on the top of the page because people like you keep pushing it. :P
13th February 2012, 14:28 | #1372 | Link |
I vote for LAV CUVID Decoder continued to live and updated!
And that's why: 1. It's a PURE hardware mode decoder. 2. When I using it, I can be sure that the GPU only is processing the video, but not CPU. It has meaning when you need all CPU power for another purposes. (LAV Video Decoder, sometimes, not switch to hardware mode (for ex.: when using DVB Viewer with H.264 streams), unlike LAV CUVID Decoder). Maybe 'Pure Hardware Mode' option for LAV Video Decoder will solve it? ... |
13th February 2012, 14:29 | #1373 | Link |
You can vote all you want, its not going to change anything.
19th February 2012, 10:03 | #1375 | Link | |
Why such a big difference between CUVID and DXVA2? |
19th February 2012, 17:08 | #1376 | Link |
Because in dxva mode the video is passed directly to the video renderer. In CUVID mode, the video is copied out of video memory back into system ram. Then depending on the renderer, copied back into video memory for presentation.
19th February 2012, 17:33 | #1377 | Link |
An ION is probably just borderline fast enough to deal with CUVID, so that some content makes it go over the edge. ION is certainly not a fast system.
3rd July 2012, 22:01 | #1379 | Link |
One question: I noticed it's necessary to change that "output mode" to 25/30 instead of 50/60 while watching 1080i contents (saved in Matroska (lossless) or not), otherwise we face audio sync problems. Is that change necessary? Once I changed, it seemed like the playback was fine.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." |
4th July 2012, 13:20 | #1380 | Link |
GPU too slow?
Probably want to ask questions in the new thread, though: http://forum.doom9.org/showthread.php?t=156191 |
