Old 25th January 2018, 23:39   #5861  |  Link
mini-moose
pausing
Hi
I'm trying x265 for the first time now.
Is pausing encode by clicking on the console window safe and won't cause any corruptions?
i.e touch to pause and then space bar to resume.
I've been told to use avs2pipemod64 to pipe x265 through. Don't know if that could have any effect on pausing.
thanks in advance.
mini-moose is offline   Reply With Quote
Old 26th January 2018, 02:39   #5862  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
@mini-moose... I did it accidentally more than once and it didn't corrupt my encode; everything resumed fine and the final output wasn't affected. I think x265 *just* waits for frames from the pipe to encode them. Clicking on the console prevents the pipe from processing frames, therefore x265 waits.
Old 26th January 2018, 04:15   #5863  |  Link
Selur
Selur's Avatar
From my experience only thing that might be 'off' are encoding speed/time indications/estimations when pausing an encoding,...
Old 26th January 2018, 07:26   #5864  |  Link
birdie
birdie's Avatar
@mini-moose
100% safe unless you press Ctrl + C which will simply terminate your encoding.
birdie is offline   Reply With Quote
Old 26th January 2018, 20:16   #5865  |  Link
mini-moose
thanks for all the answers!
Old 27th January 2018, 08:40   #5866  |  Link
dcxero
Does anyone have any CLI tricks for cutting down on the grid of "squares" that pop up during encoding? I'm still trying out various options, trying to keep most options near placebo level, but this seems to be a common occurrence, am I misusing a switch?
Example, Source:
Encode
Originally Posted by x265 CLI
--ctu 64 --bframes 8 --b-adapt 2 --rc-lookahead 60 --lookahead-slices 1 --ref 6 --limit-refs 0 --me 3 --merange 92 --subme 5 --rect --amp --limit-modes --max-merge 5 --no-rskip --no-fast-intra --b-intra --limit-sao --weightb --rd 6 --rdoq-level 2 --tu-intra-depth 4 --tu-inter-depth 4 --cbqpoffs -3 --crqpoffs -3 --deblock -3:-3 --no-strong-intra-smoothing --psy-rd 2.10 --psy-rdoq 4 --qcomp .75 --input-res 3840x2160 --fps 24000/1001 --aq-strength 1.00 --ipratio 1.3 --pbratio 1.2 --crf 16.5 --vbv-bufsize 160000 --vbv-maxrate 160000
dcxero is offline   Reply With Quote
Old 27th January 2018, 10:29   #5867  |  Link
Taurus
Taurus's Avatar
Sorry, my english is maybe bad.
But I cant see
grid of "squares"
in your pictures.
Just the normal encoding artefacts.
Your
and your posted images are 1280x720.
Even bumping up the monitor brightness and magnifying the png
shows no squares on my side.
Or maybe my eyesight is vanishing.
Just an old horse with dull eyes !
Taurus is offline   Reply With Quote
Old 27th January 2018, 17:29   #5868  |  Link
Asmodian
-3 is probably too weak deblocking for x265, try -1 or -2 at most.
madVR options explained
Asmodian is online now   Reply With Quote
Old 27th January 2018, 18:29   #5869  |  Link
froggy1
ffx264/ffhevc author
froggy1's Avatar
I doubt it, I use -3 for all my encodes and don't experience any blocking here
ffx264--ffhevc--ffxvid
froggy1 is offline   Reply With Quote
Old 27th January 2018, 21:38   #5870  |  Link
dcxero
Cheers, that seemed to be it. I guess I assumed the deblocking was more like x264, but I ran the same CLI a dozen more times, only changing deblock between -3,-3 -2,-2... all the way back to +3,+3 and then disabled. +2,+2 had the least offensive blocking (practically none) while remaining closer to the source (+3,+3 started to alter it)
Old 27th January 2018, 21:54   #5871  |  Link
froggy1
froggy1's Avatar
I can't see any blocking in your image you posted. Maybe my display isn't good enough?
Old 27th January 2018, 22:07   #5872  |  Link
jlpsvk
any cons to using --no-deblock in CLI? i I want to preserve as much sharpness as ist gets? my CLI:
--crf 18 --profile main10 --level-idc 5.1 --output-depth 10 --ctu 32 --amp --vbv-bufsize 160000 --vbv-maxrate 160000
--me star --max-merge 5 --rc-lookahead 40 --lookahead-slices 4 --ref 5 --min-keyint 24 --keyint 240 --colorprim bt709
--colormatrix bt709 --transfer bt709 --no-info --no-deblock --no-sao --no-strong-intra-smoothing --high-tier
jlpsvk is offline   Reply With Quote
Old 27th January 2018, 22:18   #5873  |  Link
dcxero
Maybe? I'm using a BenQ 2160p/10-bit (8-bit+RFC) display. I find it more prominent in grainy sources, here's a quick/better example which you might be able to see
Source:
-3,-3 deblock:
+2,+2 deblock:
Old 27th January 2018, 22:27   #5874  |  Link
froggy1
froggy1's Avatar
Source:
-3,-3 deblock:
+2,+2 deblock:
Still can't see it. All I can see is that the +2 one looks smoother than the -3 one. Can't see blocking, though. But indeed, the +2 one is closer to the source
Anyways, if you're happy with +2, use it
Old 27th January 2018, 22:36   #5875  |  Link
dcxero
Still can't see it.
You definitely need a new monitor then!
I suppose it's harder to see if you look at it unless zooming, or blown up on a TV/projector. Try flipping back and forth between the source image zoomed in, there's a faint grid of squares about 16x16 pixels wide across the whole image
It seems to be something inherent to HEVC (or just more noticeable), because I've seen it in some retail UHD discs as well (unless they're just using x264 too! )
Old 27th January 2018, 22:41   #5876  |  Link
froggy1
froggy1's Avatar
Perhaps. My monitor is a plain 6 bit+FRC from AOC (LG Display panel). My TV has a PVA panel (Samsung) at true 8 bits
I don't have any 4K displays here, all are FHD and on FHD I can't see it on any of my displays
Old 28th January 2018, 00:09   #5877  |  Link
burfadel
It doesn't look like a true transfer from the film original. Is it The Fifth Element? It's a movie I thought they would have done a proper 4k transfer for. The grain doesn't help much either, as the grain acts as detail that needs to be encoded. If it changes each frame it is probably using most of the bandwidth and bit allocation for the grain and not the actual picture. I think you'll find using a denoiser first could greatly improve the success of your output. Maybe give my mClean (v2.1) a go? https://forum.doom9.org/showthread.php?t=174804
I'm not specifically spruiking my script! This situation is just one of many that it is designed to help with. You will need to use the latest Avisynth+, updated RGTools, MVTools, Masktools, Modplus, f3kdb, as the script utilises new functions that weren't available in older versions of these. It's designed in such a way that the base settings should be adequate and retain some grain in a way that it will be more encoder bit friendly.
Old 29th January 2018, 05:59   #5878  |  Link
Sp00kyFox
Sp00kyFox's Avatar
hi there. I was wondering what are the thoughts about the aq-motion option regarding cartoon or anime content. In my experience it's beneficial to use with real world content where the higher quantization of moving parts is masked by the motion blur they introduce. but with drawn content moving parts are usually as sharp as still areas. I made a little encoding test to see the effect on bitrate and with drawn content it doesn't seem to do much anyways. any experiences with this option here?
Sp00kyFox is offline   Reply With Quote
Old 29th January 2018, 23:53   #5879  |  Link
divxmaster
@burfadel, thats interesting, I will have to check your filter out! I am currently getting very good results with smdegrain:
vid = haf.SMDegrain(vid, tr=3,thSAD=150,RefineMotion=True,contrasharp=True,pel=2)
varying thSAD from 100-400 depending on grain, or smdegrain off if no grain (ironman3, Star Trek Beyond).
Cheers,
Divxmaster
divxmaster is offline   Reply With Quote
Old 30th January 2018, 04:58   #5880  |  Link
WhatZit
Originally Posted by jlpsvk View Post
any cons to using --no-deblock in CLI? i I want to preserve as much sharpness as it gets?
http://ieeexplore.ieee.org/stamp/sta...number=6324414
The --deblock loop filter uses a PAIR of values that correspond to STRENGTH,DECISION.
STRENGTH needs no explanation, but DECISION (literally) decides how often to employ the filter on coding units.
The default value of 0 activates on relatively balanced values between the block boundaries.
The maximum value of 6 activates on ALL block boundaries regardless of disparity, producing whole-scene smoothing.
The minimum value of -6 activates only on those block boundaries which have significant threshold disparity, producing virtually no deblocking on anything other than already unwatchable artifacts.
To answer your question, unless you are using a high enough bitrate to never create blocking artifacts in the first place, you should always have some level of deblocking active (even -6,-6), because blocking is something that the eye just spots immediately.
To figure out what values the filter should be set to FOR YOU and your bitrates, get yourself a high-detail sample with stationary foreground elements & rapidly moving background elements. A sunny panning shot of people running in front of plants or other complex backgrounds is perfect.
Adjust DECISION until the background blocking stops (or is acceptable) whilst the foreground remains untouched. Then adjust STRENGTH to suit.
I personally use -2,-3.
WhatZit is offline   Reply With Quote
