Old 21st November 2011, 03:33   #18481  |  Link
Hera
.NET Web App Dev
Both are equally confusing.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS
Windows 8.1
Hera is offline
Old 21st November 2011, 03:56   #18482  |  Link
namaiki
I think pre and post-resize is easier to work the meaning out.
namaiki is offline
Old 21st November 2011, 12:52   #18483  |  Link
Superb
Completely agree.
Superb is offline
Old 21st November 2011, 14:59   #18484  |  Link
v0lt
If we are removing "pixel"?
pre-resize pixel shaders -> pre-resize shaders
post-resize pixel shaders -> post-resize shaders
v0lt is offline
Old 21st November 2011, 16:12   #18485  |  Link
nevcairiel
The name is pixel shader, not just shader.
nevcairiel is offline
Old 21st November 2011, 16:54   #18486  |  Link
LigH
LigH's Avatar
Originally, it was named "Fragment Shader"; but that didn't sound advertizing enough.
New German Gleitz board
LigH is offline
Old 21st November 2011, 20:28   #18487  |  Link
Octo-puss
Originally Posted by bozek View Post
I'm kind of surprised MPC-HC still uses the ancient win98 look...
I love it. Don't touch it! Simplicity and retro FTW!
Octo-puss is offline
Old 22nd November 2011, 10:19   #18488  |  Link
bozek
Meh, speak for yourself. Though, there's nothing wrong with adding some more skins... I mean, one doesn't have to swap one look for another.
bozek is offline
Old 22nd November 2011, 15:17   #18489  |  Link
kasper93
MPC-HC Developer
Originally Posted by v0lt View Post
@kasper93
RC file is not needed. (\src\apps\mplayerc\mpcresources\mplayerc.pl.rc)
We need a modified TXT file. (\src\apps\mplayerc\mpcresources\text\mplayerc.pl.rc.txt)
I know and I meant TXT files. (\src\apps\mplayerc\mpcresources\text\mplayerc.rc.txt) String in the line 1743 is no longer needed after rev. 3841 so it can be wipe out from language files and
resource.h to keep that files clean.
Anyway, thanks for little polish translation updated in r3841. There are a few more changes in the file attached to the ticket and we (me and haix) would be glad to see them also included sometime.
kasper93 is offline
Old 23rd November 2011, 03:13   #18490  |  Link
ageback
rev.3850 compile failed:
1>MPCVideoDecFilter.cpp(1956): error C2065: “nPCIDevice”: 未声明的标识符
ageback is offline
Old 23rd November 2011, 14:09   #18491  |  Link
Hera
.NET Web App Dev
In the installer have various skin options.
Windows 8.1
Hera is offline
Old 23rd November 2011, 18:25   #18492  |  Link
JarrettH
Is there some obvious reason why EVR-CP will not work with Intel HD Graphics 2000? I've tried several revisions over the course of 4 months and nothing has changed, always get a black screen on playback. EVR works though.
JarrettH is offline
Old 23rd November 2011, 19:49   #18493  |  Link
clsid
The internal DXVA decoder is not compatible with the integrated graphics of the Sandy Bridge processors.
Try build 3851 or newer. That might solve the black screen issue. If not, disable the internal DXVA decoder.
clsid is offline
Old 23rd November 2011, 23:46   #18494  |  Link
Wodde
I have a (maybe stupid) Question:
When i load a Bluray, MPC HC selects automatically the longest Videotrack on the Disc.
So far, so good, this works in 95% of my BDs.
But on a few Discs there is a Extended Version or an Extra Track which is longer than the MainMovie, and this Track is loading instead of the MainMovie.
For Mediaportal there is a Plugin named BD Handler, which allows my to choose which Videotrack i want to play.
Is it possible to integrate such a Function into MPC HC?
Thanks in Advance.
Wodde is offline
Old 25th November 2011, 15:16   #18495  |  Link
Tiduz
rev 3851 gives me vertical stripes in dark scenes, not black lines but kinda transparant.
am i the only one with the problem?
i only see them when i go fullscreen and i use a ati hd6850
Tiduz is offline
Old 25th November 2011, 15:23   #18496  |  Link
namaiki
What items are present in the menu 'Play-> Filters' when you have that video open in MPC-HC?
Also, please post a non-resized screenshot of the issue.
namaiki is offline
Old 25th November 2011, 15:36   #18497  |  Link
LigH
LigH's Avatar
@ Tiduz:
Did you activate automatic contrast enhancement (or whatever it is called) in your ATI drivers? Don't do that...
LigH is offline
Old 25th November 2011, 15:39   #18498  |  Link
Tiduz
no i have disabled dynamic contrast
the problem with posting a screenshot is i only see it in full screen, maybe i can use print screen to show the issue instead of the build in screenshot taker, ill try that
heres a sd screen, it also happens with HD tho.
http://i.imgur.com/2HZjX.jpg
filters:
Default directsound device
enhanced video renderer (custom presenter)
Audio Switcher
MPC Video Decoder
MPEG-1 Audio Decoder
Tiduz is offline
Old 26th November 2011, 06:56   #18499  |  Link
Blitzker
I have updated my MPC-HC BE builds with the new r3855 sources. You can grab it while its fresh here http://www.mediafire.com/?nbb4gclb828ax
(I tried a new gcc build for this one (4.6.2) and so far, it seems to behave as good as the xvidvideo.ru gcc 4.6.1. Feel free to give some feedback if you experience problems while using it)
Latest dev builds of AssFilterMod can be found here: https://www.mediafire.com/folder/w1w...s/AssFilterMod
Blitzker is offline
Old 26th November 2011, 07:44   #18500  |  Link
disto
Hello i have a question is it possible to add gamma correction slider in mpc-hc for EVR or MadVR render.
disto is offline
dxva, h264, home cinema, media player classic, mpc-hc
