Old 7th May 2009, 14:38   #341  |  Link
If the error code returned is sufficient to distinguish the error from a simple stream error, then theoretically something could be done. But I'd have to keep polling to see when decoding can start succeeding again. It sounds like a nightmare to me.
Guest is offline
Old 9th May 2009, 15:43   #342  |  Link
xandercage
i m using nvidia 8800GTX 768 MB GPU.
I instaled this driver 185.85_desktop_winxp_32bit_english_whql and this cudadriver_2.2_winxp_32_185.85_general.
My OS Win XP PRO SP3
But i can t load VC-1 stream. I always get this error
What kind of license file is missing?
Any ideas how can i load VC-1 stream or m2ts file?
xandercage is offline
Old 9th May 2009, 16:05   #343  |  Link
To get a license, you need to push the yellow button on this page:
http://neuron2.net/dgvc1decnv/dgvc1decnv.html
Guest is offline
Old 9th May 2009, 16:09   #344  |  Link
xandercage
I must donate? Or what do u mean?
Thx for the answer
Old 9th May 2009, 16:10   #345  |  Link
Just read what is written on the page I linked. It's all spelled out for you.
Guest is offline
Old 9th May 2009, 16:55   #346  |  Link
xandercage
OK i m waitting for the activation...
Sorry for my dump qustions.
Thanks for your great work
Old 9th May 2009, 20:40   #347  |  Link
squid_80
You might want to save your money, the 8800GTX can't use CUDA for decoding.
squid_80 is offline
Old 9th May 2009, 23:43   #348  |  Link
He didn't read the page like I asked him to.
Guest is offline
Old 10th May 2009, 11:38   #349  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
How about making your program error out with an "Unsupported hardware"-type error message before even checking for a license file?
np: Casiotone For The Painfully Alone - Northfield, MN (vs. Children)
now playing: [artist] - [track] ([album])
Leak is offline
Old 17th May 2009, 14:53   #350  |  Link
Audionut
Hi Don,
Just to report your tools work fine in Windows 7 x64 with the latest drivers from nvidia. 185.85
Regards,
http://www.7-zip.org/
Audionut is offline
Old 17th May 2009, 16:42   #351  |  Link
Thanks for the test results, Audionut!
Guest is offline
Old 25th May 2009, 16:53   #352  |  Link
rack04
Using DGVC1DecNV 1.0.6 and CUVID Server 1.0.4 I get the following error at 98.4% complete in the first pass.
"cuvidDecodePicture() error."
I'm using Windows XP SP3 with Nvidia 8800GT with driver version 185.85. I have the screen saver disabled. If there is any other information you need to debug please let me know.
The x264 command line that I use to encode is:
"%x264_PATH%" --pass 1 --bitrate %DESIRED_BITRATE% --stats "%WORKING_DIRECTORY%\%SOURCE_FILENAME%.stats" --level 4.1 --keyint 24 --min-keyint 1 --bframes 3 --b-adapt 2 --weightb --direct auto --deblock -1:-1 --subme 2 --partitions none --vbv-bufsize 30000 --vbv-maxrate 24000 --qcomp 0.5 --me dia --threads auto --thread-input --sar 1:1 --aud --progress --no-psnr --no-ssim --output NUL "%INPUT_VIDEO%" --mvrange 511 --nal-hrd
The following zip file contains the raw VC-1 stream, AviSynth script, and DGV file.
http://www.megaupload.com/?d=UYVX1C50
rack04 is offline
Old 25th May 2009, 23:36   #353  |  Link
woah!
looks like frame 253 is the problem, using DGsource is stopping at that frame.
woah! is offline
Old 26th May 2009, 13:34   #354  |  Link
rack04
I did some more testing. It appears that WMVideo Decoder DMO, wmv9, and libavcodec are able to decode this stream properly.
rack04 is offline
Old 4th June 2009, 13:36   #355  |  Link
rack04
Has anyone else bee able to reproduce this problem using the files I linked to above?
rack04 is offline
Old 4th June 2009, 13:40   #356  |  Link
I've reproduced it but haven't had time to get to it as I am finishing up multiple input file support.
Guest is offline
Old 4th June 2009, 13:50   #357  |  Link
rack04
Very well. Thank you for your time.
rack04 is offline
Old 8th June 2009, 04:30   #358  |  Link
rack04
I just tried the encode again using DG NV tools beta and everything works great. Thanks.
rack04 is offline
Old 8th June 2009, 23:19   #359  |  Link
robinsj
So i just donated, how long does it take to get a license.... Thanks!!
robinsj is offline
Old 13th June 2009, 21:28   #360  |  Link
may24
... so this seems to be for NVidia only.
Will there be - by chance - a version for us ATI owners ?
Perhaps one without cuda support, to start with ...
may24 is offline
