Old 5th January 2012, 11:09   #21  |  Link
Zathor
Originally Posted by meshaun View Post
WIth the OC, should I always Extract the audio and then use it
At the moment the audio files can only be extracted if a DGIndexer is used or the source is a MKV container. If an MKV file is used also subtitle streams can be extracted.
In all other cases it is required to demux the audio/subtitle streams on your own at first (it is planed to improve that step as well).
...or is it okay to just select a .mkv as the input and auto select the audio as the OC does?
Yes
Zathor is offline   Reply With Quote
Old 6th January 2012, 05:44   #22  |  Link
meshaun
Found a problem, select a .srt for subtitle and tick the "Default subtitle" and give's a error . "Megui encounted a fatal error....."
and also, suggestion, for adding a new subtitle, replacing the "Right click" on the subtitle 1 and add new track, double click on the subtitle tab giving a new tab or something would do good .
meshaun is offline   Reply With Quote
Old 6th January 2012, 12:42   #23  |  Link
Zathor
Thanks, fixed the problem also for the forced option.
Added
New build online in the first thread.
- Updated version to 2088
- fixed problem with default/forced flag selection for external files
- double click on audio or subtitle tab will add a new track
- cosmetics on the main page
Old 6th January 2012, 18:57   #24  |  Link
meshaun
Thanks for the fixes Zathor.
How can add a Drag and Drop function too? Like. drag and drop the video files or drag and drop the audio / subs and etc. That will be good to go...
Old 6th January 2012, 21:50   #25  |  Link
kalehrl
I think the new oneclick window is cluttered with options.
I prefer the old one.
kalehrl is offline   Reply With Quote
Old 7th January 2012, 02:02   #26  |  Link
meshaun
The "Old One" as you referred is still there. This a a experimental One Click Part which is still on testing purposes.
I found a problem with megui. Fatal Error. Happens when I click the "GO" in the final part.
Old 7th January 2012, 11:20   #27  |  Link
kalehrl
Yes but I'm afraid that after testing it will be included in the "official" release.
Old 7th January 2012, 11:55   #28  |  Link
meshaun
It's good to have more options than having a little. That expands the MEGUi options and gives more opportunities to the users.
Old 7th January 2012, 13:36   #29  |  Link
Zathor
Please post the log or send me a PM with it.
Yes, that's of course the reason for testing. There will not be a OneClick and "TwoClick" tool in MeGUI. Nevertheless when you disable the "Show Advanced Options" there are less options. Which of the advanced options is confusing for you?
Old 7th January 2012, 18:08   #30  |  Link
kalehrl
I understand all options because they are self explanatory.
I think the current main oneclick window is more compact and not so cluttered with options like the one in this thread.
I mainly encode in xvid avi and never include subtitles in a file so, for me, subtitle part of menu is redundant.
For me, audio language and audio delay are redundant as well.
All these things make new version of oneclick window not so appealing for me.
Old 7th January 2012, 18:10   #31  |  Link
meshaun
PM sent.
How about the Drag and Drop video/audio thing? That might come handy mate. And also, someway to check the Final Size using the Bitrate Calc would be nice. If we form the profiles right, it gives definite bitrates and megui loads the durations and all from the scripts. How about showing the Final Size and things before the encoding?
Old 7th January 2012, 18:56   #32  |  Link
Zathor
PM sent.
Your audio input file has no audio (at least that is what MediaInfo reports). I catch now that problem and you can try the build in the first thread again. I have updated it to 2093 inlcuding your bug fix. If the problem is still there please send me again the log file.
I have tried to enable it quickly but failed. Will try it later again.
Why do you need to know the filesize before? If you target a specific file size you should enable that in the settings - if not you will get the final size at the end.
So you really want a simple tool? I can add an option (off by default) that only the controls from the old tool are shown.
Old 8th January 2012, 05:32   #33  |  Link
meshaun
To know the filesize before an encode is finished, have to use the Bitrate Calc right? But what about encoding with settings for bitrates only?Then can't have a slight idea about the final output. So, knowing the Final Size is a plus information to the Encoder.
Old 8th January 2012, 09:04   #34  |  Link
tebasuna51
tebasuna51's Avatar
You can supply time, audio and video bitrate to Bitrate Calculator and you get the file size.
Old 8th January 2012, 11:07   #35  |  Link
kalehrl
That would be very nice.
Old 8th January 2012, 15:27   #36  |  Link
Zathor
Uploaded a new build. Beside minor fixes/improvements there are
- Drag&Drop support
- Three different GUI modes (basic, default, advanced)
Old 8th January 2012, 20:12   #37  |  Link
alter4
Thx for the nice job!!
When do you expect your changes with main dev branch merging?
alter4 is offline   Reply With Quote
Old 8th January 2012, 23:08   #38  |  Link
Zathor
I do not have a clue At least not before the next stable release and there are still some features missing.
Old 9th January 2012, 10:38   #39  |  Link
meshaun
- Drag&Drop support
The Three Different modes is a good idea mate.
Old 9th January 2012, 15:37   #40  |  Link
meshaun
Error again. PM Sent on log.
Loaded the .mkv and loaded the audio and Go gives the error. And also, after loading the .mkv to the video part, the audio file wasn't recognized. OC window just had this busy mouse pointer for minutes and didn't still recognize the audio or the subtitle files.
