9th May 2006, 22:18 | #2181 | Link |
Two possible solutions:
two video types: AVCAVI and ASPAVI.... I'm not sure how that would work, though. The muxers have a list of videocodecs that they support. So, not only does a mux path need to be found, but every muxer after the one that muxes it in needs to support that video codec. (Similar for audio codecs). I like this solution, but it still doesn't work when you just select an avi input file.... you don't know what codec it is. Perhaps MediaInfo would be useful for this? EDIT: About MediaInfoLib. The things I see it as perhaps useful for are:
10th May 2006, 08:16 | #2183 | Link | |||
clueless n00b
10th May 2006, 08:27 | #2184 | Link | |||
10th May 2006, 08:51 | #2185 | Link |
0.2.3.2136 10 May 2006
Commit by berrinam: - Fixed Profile Importing/Exporting's CQM handling for XviD - Added tritical's fix for AviSynthWrapper - Fixed OneClick window loading - Fixed LMP4 config loading bins: http://rapidshare.de/files/20081273/....2136.zip.html or http://www.savefile.com/files/8710945 src: http://rapidshare.de/files/20081338/....2136.zip.html Enjoy. Last edited by berrinam; 10th May 2006 at 12:43. |
10th May 2006, 08:55 | #2186 | Link | |
clueless n00b
10th May 2006, 11:57 | #2187 | Link | |
BluRay Maniac
10th May 2006, 12:48 | #2188 | Link | |
The main difficulty arises from the fact that we now need to know the codec at every level, as opposed to just knowing the VideoType (these aren't always interchangeable). It isn't a terrible problem; it should just require working through all of the code and replacing OutputType with MuxableType (a struct which will contain an OutputType and the codec used). Unfortunately, this sort of tedious work can't be done right now. I'll have to leave it for a little while. @shon3i: edited my above post. |
11th May 2006, 01:38 | #2189 | Link |
Mr. Sandman
Since the CVS is down, latest sources can be found on the anon SVN: https://svn.sourceforge.net/svnroot/megui (use a svn client)
EDIT: i updated the version number in AssemblyInfo.cs to 0.2.3.2136
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 11th May 2006 at 12:36. |
11th May 2006, 11:32 | #2190 | Link | |
Pain and suffering
The checkout went fine, are there are problems for using SVN then? (besides the fact that i can't compile again, see bug report thread) |
11th May 2006, 12:35 | #2191 | Link |
Mr. Sandman
yeah... no, but the old versions history is gone. so it preferable to still use the CVS until we can migrate the whole thing to the SVN.
12th May 2006, 14:20 | #2192 | Link |
Mr. Sandman
Sources and Bins are available here too (from now on):
http://mirror05.x264.nl/Sharktooth/?dir=./MeGUI
12th May 2006, 17:03 | #2193 | Link |
Mr. Sandman
CVS is BACK.
Read the SF email to know how to access the new service.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 12th May 2006 at 17:11. |
13th May 2006, 00:02 | #2196 | Link |
Well, if anon CVS is still broken, then a transition won't be so easy. EDIT: Anonymous CVS is working now -- I just tested. You need to reconfigure the settings, though: http://sourceforge.net/docs/E04/
13th May 2006, 02:16 | #2197 | Link |
0.2.3.2137 13 May 2006 Commit by berrinam: - Added a check for whether muxers support the codec in mux path finding - Added a warning message on the bitrate calculator (it needs a refactor) - Fixed the mp4 bug with the calculator - Fixed a bitrate calculation bug in AutoEncode |
13th May 2006, 14:47 | #2198 | Link |
Mr. Sandman
I'll try to migrate again...
EDIT: migration from CVS is "currently not available"
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 13th May 2006 at 14:52. |
13th May 2006, 19:46 | #2199 | Link |
BeHappy/MeGUI developer
Is this settings valid ???
In C:\MeGUI: "C:\Program Files\TortoiseCVS\cvs.exe" "-q" "checkout" "-P" "MeGUI-src.CVS" CVSROOT=:ext:dimzon@megui.cvs.sourceforge.net:443/cvsroot/megui cvs.exe checkout: bad CVSROOT - Cannot specify port: :ext:dimzon@megui.cvs.sourceforge.net:443/cvsroot/megui cvs.exe [checkout aborted]: Bad CVSROOT. Error, CVS operation failed
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
13th May 2006, 20:35 | #2200 | Link |
Mr. Sandman
port number is wrong. remove it.
development, megui, not a help thread |
