18th June 2005, 09:27 | #461 | Link | |
PgcEdit daemon
18th June 2005, 11:55 | #463 | Link | ||
PgcEdit daemon
18th June 2005, 17:10 | #465 | Link | |
PgcEdit daemon
Also, some files are not included in some distribs, if they are not needed. In the source zip, all files are present.
19th June 2005, 02:45 | #466 | Link |
PGC Navigator in Training
@blutach
PgcEdit's reference manual looks great! If you are working on an update, can you insert example images of the color coding highlights in Main window, goto calling command dialog, and search log? did I miss anything? Anyways, here's a post for some reference.
2COOL |
26th June 2005, 07:27 | #467 | Link |
@r01Z
Please consider the function of setting default stream (audio, sutitle) for Re-Authored by DVDShrink (if possible, by others). A little before I backed up by DVDShrink(Re-Authore), but I've forgot to set the default stream as usual, so I corrected IFO after processes. Then I thought it would be very useful if possible to set the default stream by PgcEdit. Even it needs only correction of IFO a little, but it needs to know about IFO a little, if not it needs long time for re-processing of DVDShrink. I think it is possible to add pre-command of two lines for each title like below, .....(SetSTN) Set Audio stream = ? .....(SetSTN) Set Sub-picture stream = ?, on ................< ? is selected favorite> Sorry to request selfish hope. Last edited by jinjin_jp; 26th June 2005 at 07:30. |
26th June 2005, 08:14 | #468 | Link |
Country Member
@jinjin_jp - you can do this already with the new Jump to PGC Upon DVD Insert macro.
Just trace through your DVD to the main menu and then click on the audio menu and pick the stream you want. Do the same for subpictures. Return to the main menu. The streams you want will be set. Then execute the macro. By the way, DVD Shrink remapping streams is not good to do IMHO - see my discussion here. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
26th June 2005, 09:12 | #469 | Link |
PgcEdit daemon
@blutach: jinjin_jp was talking about reauthored movies. You don't have menus anymore.
@jinjin_jp: I think it easy enough to do it yourself. After all, it's only one (or two) SetSTN commands to insert in the pre-commands of the main title. For me, it's not so simple, because I need to check if the SetSTN command already exists. But maybe I will do that. Not soon, anyway...
26th June 2005, 09:39 | #470 | Link |
@r01Z
I understood. Surely it is difficult if considering various cases to be checked. @blutach About remapping streams I noticed interesting thing in DvdReMakePro which have the function of removing stream after ver.3. When using this function, "Delete track" is selectable from last stream, but from middle stream "Delete track" is glay out and "Disable track" is only selectable. I think this is the same thought as yours. |
26th June 2005, 09:46 | #471 | Link |
PgcEdit daemon
I don't use DVDReMake anymore , but I believe that it does that this way because it is uable to remap the streams. If you remove a stream (before the last one), the references to the remaining streams are wrong, and remapping them is not easy, especially if there are indirect SetSTN commands somewhere. (Indirect commands = commands using a GPRM instead of a constant value)
26th June 2005, 13:41 | #473 | Link |
Country Member
And yes, sorry gentlemen. I should have read closer. I see now the re-authored.
But jinjin, I think you know you can do this automatically in DVD Shrink. And if you forget, it's only 1 command to add in before the title. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 26th June 2005 at 13:44. |
26th June 2005, 13:52 | #474 | Link |
PgcEdit daemon
PgcEdit 0.6.0 beta 14
Yes, it's a relatively long work for me for a little advantage.
And I prefer to work on more useful additions, like the new function I just wrote, available in PgcEdit 0.6.0 beta 14. This function allow you to renumber the Titles in the DVD. I hate these DVD with title 1 being a logo, and with a main movie title number being 2 or more! The new function (Utilities -> Remap Title numbers) takes care of the Jump_TT commands in the VMG, including in menu buttons. Enjoy...
26th June 2005, 13:59 | #476 | Link |
Country Member
OK to both. Goodness r0lZ, v6 won't get released LOL. But I gotta agree. I hate it when title 1 is right down the bottom in VTS 23.
More work on the help file, I guess Regards
26th June 2005, 14:02 | #477 | Link | |
PgcEdit daemon
I will probably release v6 on july 7, because I have inserted a front page on my site, regarding the pattents european directive. I will remove it and release PgcEdit 0.6 when this page will be obsolete, on july 6.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 26th June 2005 at 14:07. |
26th June 2005, 14:03 | #478 | Link |
Country Member
Tell you what I reckon would be useful:
If you have killed enough material to make whole titlesets unreferenced, then a little utility to pull them out of the structure (as you know, it's only 3 bytes in VIDEO_TS.IFO that need changing), moving the VOBs, IFOS and BUPs to a special backup folder.Whaddya reckon? Regards
26th June 2005, 14:04 | #479 | Link | |
Country Member
G'night from here. Regards
26th June 2005, 14:37 | #480 | Link | |
PgcEdit daemon
Also, removing the last titleset is relatively simple, but removing any titleset would require to fix the references to the next titlesets. I think that an unreferenced titleset is not so annoying, because, when blanked, it doesn't use a lot of space, and when playing the DVD, you will not notice his presence. But I may add a simple Remove Last Titleset function, without checks for references. Is it enough for you?
