25th December 2008, 23:47 | #3462 | Link | |
Practising Schemer
26th December 2008, 05:05 | #3464 | Link |
Forum Member
Is there any way to disable ConvertAudioTo16bit() when encoding with NeroAAC 1.3.3.0 using MeGUI? I'm trying to encode a two channel 48kHz - 24BPS audio file, but ConvertAudioTo16bit() keeps getting added changing the file from 24bps to 16bps.
I recall that NeroAAC supports 24bps. Does any know why ConvertAudioTo16bit() keeps getting added? Seems to be no way to disable it. I'm going to try using BeHappy, but wanted to see if could be done using MeGUI. |
26th December 2008, 06:51 | #3465 | Link | |
Swallowed in the Sea
anyway, could you try this build ? |
26th December 2008, 12:40 | #3473 | Link | |
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 26th December 2008 at 12:44. Reason: addd link |
26th December 2008, 14:42 | #3475 | Link |
From time to time, I have some problem with the MeGUI AutoCrop functionality : it cuts wrong parts of the video.
I put a small example there (2.7Mb) : wrongcrop.m2v. MeGUI AutoCrop cuts the 26 lines on the top but it shouldn't. |
26th December 2008, 15:18 | #3476 | Link | ||
Banned
Hi, I use fraps to record videos from my games. Fraps likes to split the video into 4 GB chunks and the chunks are named in a way that makes it impossible to segment them using Avisynth unless I rename them to "video.01.avi" "video.02.avi" etc.
After renaming them either manually or with a batch rename tool, I can then use "SegmentedAviSource()" or "SegmentedDirectShowSource()" to automatically combine the videos into a single video. I have to add this command manually by creating the AviSynth script manually, but it can be a real pain trying to create the AviSynth script automatically using MeGUI's "AviSynthScript Creator". When loading the first Avi into the AviSynth Script Creator, I get the following script: Quote:
I am curious if there is an easier way to do this. I want to simplify this process somehow without having to resort to manually modifying the AviSynth script. Thanks in advance for any help or feedback. |
26th December 2008, 18:44 | #3477 | Link |
I have a problem with my audio being out of sync and the FPS of the resulting .mkv file shows up as 25 FPS in both VLC and MediaInfo. I opened the .vob file in MediaInfo and it says it is 29.97 FPS. I used the D2V Creator in MeGUI, selected the .vob file as input, and after it runs it shows the FPS as 23.976 under the Filters tab.
I used DVD Decrypter to rip an episode of Stargate SG-1 (S08E20). I then freshly installed MeGUI and AVISynth, with no other codecs or audio/video programs installed, and used the One-Click encoder to encode it with x264 and 128k MP3 audio. The audio is slightly off at the beginning of the episode, but gets worse and worse as time goes on. Anyone know how to fix this? |
26th December 2008, 19:08 | #3478 | Link |
@VirtualMe : use the build linked in the post #3470 from this thread...
@Neillithan : nope...we can't yet do that more easier unfortunately. @pcjco04 : I'll see what can I do for that...not easy I fear. |
megui |
