Old 13th August 2018, 17:52   #52081  |  Link
that's messed up i try may r9 270 later.
edit: and with later i mean days i guess at week end.
sorry my r9 270 is working like a charm.
but my windows has a lot of changed settings to make it usable.
Old 13th August 2018, 19:50   #52082  |  Link
kostik
Previously D3D11 fullscreen windowed was showing only 8 bit but now , OSD shows me D3D11 fullscreen windowed (10 bit) .
Both in HDR and SDR modes.
I am not sure whether nvidia 398.98 hotfix fixed it or the new Win10 18214 build or maybe the latest madVR test build.
kostik is offline   Reply With Quote
Old 13th August 2018, 21:25   #52083  |  Link
KoKlusz
Originally Posted by oldpainlesskodi View Post
Ok thanks, that's what I was hoping for.
EDIT:
Just re-read what you said. Not sure the latest version is using the same tonemapping as madVRhdrTestFinalColor4.zip, as they look very different on my setup, to my eyes anyway.
Well, I wrote that just minutes before latest version dropped, which did changed how madVR reads metadata.
KoKlusz is offline   Reply With Quote
Old 13th August 2018, 22:04   #52084  |  Link
Siso
Siso's Avatar
Where is this thread in the AVS forum?
Old 13th August 2018, 22:19   #52085  |  Link
videoh
https://www.avsforum.com/forum/24-di...projector.html
Old 14th August 2018, 00:05   #52086  |  Link
ryrynz
ryrynz's Avatar
Test build fixed it. Surprised madshi didn't release an interim build or quick fix release here, he's pretty dedicated to avsforum and playing with HDR right now so I guess that's why.
Old 14th August 2018, 03:43   #52087  |  Link
ajp_anton
ajp_anton's Avatar
yes they could go and read the timestamps before starting playback and could choice the refreshrate and if or if not SM should be used.
but this sounds like a lot of work.
just the info if it is VFR is not enough. the first frame could be reported with a shorter frame time and the rest is CFR but the file would still be reported back as VFR. this is a real "problem" BTW. but real VFR is really uncommon.
you could add a tag to force SM. sorry i don't know the name of them but pretty sure there is one.
If there's a lot of "fake" VFR, then that's a problem for sure. But VFR isn't as rare as you think. All of my recent smartphones record VFR video. Sometimes frames are skipped or delayed for whatever reasons... CPU throttling because of overheating, background tasks, who knows. Learned it after many hours of pulling my hair when trying to re-encode my videos using tools that assume CFR.
Old 14th August 2018, 10:01   #52088  |  Link
svengun
Where are these test builds available ?
svengun is offline   Reply With Quote
Old 14th August 2018, 10:07   #52089  |  Link
ryrynz
ryrynz's Avatar
Been linked multiple times.. with the last like a page ago..
Old 14th August 2018, 14:56   #52090  |  Link
svengun
I checked the last two pages , I can't find it , can you give me a hint ?
Old 14th August 2018, 15:08   #52091  |  Link
videoh
You need to follow this thread:
madshi links new test builds there. Scan backwards from the last post to find recent builds. E.g., see post #1601.
Old 14th August 2018, 17:31   #52092  |  Link
i hope people read the >projector< part.
Old 14th August 2018, 18:34   #52093  |  Link
SamuriHL
SamuriHL's Avatar
Once the project is done, in theory it'll work on any display and could be better than the HDR on some TV's. But it's still very early stages.
HTPC: Windows 10, I7 3770k, GTX 1060, Pioneer Elite VSX-LX303, LG C8 65" OLED
Laptop: MSI GT70 Dominator (Optimus)
Old 14th August 2018, 21:39   #52094  |  Link
cyberscott
True but madshi did implement at least one fix on the test builds in that forum: 10 bit full screen is (non-exclusive)working again. It was stuck in 8 bit after the Windows 1803 update.
Iím glad to see him actively working on madVR even if not within this forum.
cyberscott is offline   Reply With Quote
Old 14th August 2018, 23:23   #52095  |  Link
Asmodian
It was not due to the Windows 1803 update. It was due to the Nvidia drivers returning poor quality when using HDR + Windowed 10 bit at the same time, so madshi disabled Windowed 10 bit as a quick and dirty "fix".
madVR options explained
Old 15th August 2018, 00:24   #52096  |  Link
KoKlusz
It's already working on any display, and it's much, much better than tonemapping of my TV.
Old 15th August 2018, 00:45   #52097  |  Link
SamuriHL
SamuriHL's Avatar
Yup, I've been following the AVS thread with great interest. I'm glad to see the work and testing being done. I've not had time to contribute to the testing, unfortunately, but, I'm very interested to see where it goes.
Old 15th August 2018, 07:00   #52098  |  Link
Sunset1982
So do the latest divers work?
Intel i5 6600, 16 GB DDR4, AMD RX480 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 15th August 2018, 08:54   #52099  |  Link
Asmodian
I don't know how the fix worked, perhaps madshi simply changed it to only disable Windowed 10 bit for HDR (where the problem is)?
Old 15th August 2018, 11:39   #52100  |  Link
tony359
Originally Posted by Weirdo View Post
You were right, thanks. It's strange because Focus Assist was supposedly disabled, but problem went away only after unticking all options.
THANK YOU! I had set Focus Assist to OFF but it was still causing issues. I did not realise I had to "untick all the options" as you said!!
Cheers!
tony359 is offline   Reply With Quote
