14th April 2018, 15:35 | #241 | Link | ||
avfs is to make a "fake" virtual AVI, that allows you to bridge avisynth to other programs which do not accept avs scripts, or avoiding the alternative of using large lossless intermediate files . A common use is some other programs (e.g. NLE's) might not be compatible, and some of them do not accept "YV12" by the avfs method, hence the need for RGB x264 can be compile with avs support (direct avisynth input) , or ffmpeg libx264 can accept avs directly Quote:
14th April 2018, 16:46 | #242 | Link | |
Also, since I did convert to rgb, why the output is yuv? Thnx |
14th April 2018, 16:50 | #243 | Link | ||
This is avoidable loss, and faster without avfs or extraneous conversions Quote:
YUV => RGB => YUV x264 support RGB encoding too, but it's not commonly used and compression efficiency is low. YUV 4:2:0 is the most common |
20th December 2018, 19:42 | #247 | Link |
Does anyone know if this works with DaVinci Resolve or Nuke? Mounting works because I can open the mounted avi (even in avspmod with directshowsource() ) but it refuses to load in said aplications. Everything is x64 on my end. Thanks.
20th December 2018, 20:55 | #248 | Link | |
For example , Resolve expects 10bit RGB and won't accept 8bit |
25th July 2023, 14:00 | #251 | Link | |
Professional Code Monkey
2. "No longer supported". This is where you post the error message. Some formats exist as 10 bit but not all.
