Old 1st July 2017, 20:13   #14961  |  Link
klopsknoedel
Even in my case DTSMA - Tracks can't be found if "StoreTempFilesin=D" is set in RipBot264.ini on Windows 10.
No problems in RipBot264 1.19.x
@Atak ... I've send you the trimmed BD as you requested via PM 1-2 days ago. Hope it helps find the bug within the "Edit Playlist" - Window.
klopsknoedel is offline   Reply With Quote
Old 2nd July 2017, 01:04   #14962  |  Link
Calimero1609
@klopsknoedel
I have the same problem ... see post #14950
StoreTempFilesin=C -> OK
StoreTempFilesin=D -> no Audio
StoreTempFilesin=E -> OK
StoreTempFilesin=F -> OK
StoreTempFilesin=G -> OK
StoreTempFilesin=H -> OK
@tkwou
Windows 10?
Calimero1609 is offline   Reply With Quote
Old 2nd July 2017, 01:35   #14963  |  Link
cyperous
Failing to add all items in batch
There a bug in the most recent version around adding a batch of files.
When I initiate the add for a list of files using the batch mode. At some point the process stops in the middle of the batch and requires user intervention to close the add window and go back into the batch window to resume.
This is very annoying and would like for it to be fixed.
cyperous is offline   Reply With Quote
Old 2nd July 2017, 11:42   #14964  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Can you make a screen shot or even better record that using fraps?
Atak_Snajpera is online now   Reply With Quote
Old 2nd July 2017, 14:59   #14965  |  Link
klopsknoedel
Originally Posted by Calimero1609 View Post
@klopsknoedel
@tkwou
Windows 10?
For me this only happens if all tracks (1/1 or 2/2) are DTSMA. If for example the first one is encoded in AC3 and the second in DTSMA all works fine.
Old 2nd July 2017, 18:06   #14966  |  Link
Calimero1609
@klopsknoedel
@Atak
RipBot264 1.20 Beta / Windows 10 Pro
StoreTempFilesin=C / E / F / G / H
AC3 Core = OK
E-AC3 Demux = OK
True HD Demux = OK
DTS Core = OK
DTS MA Demux = OK
DTS Hi-Res Demux = not supported !?
DTS Hi-Res Core = OK
StoreTempFilesin=D
AC3 Core = OK
E-AC3 Demux = OK
True HD Demux = OK
DTS Core = OK
DTS MA Demux = no Audio
RipBot264 1.19.5 / Windows 10 Pro
StoreTempFilesin=C / D / E / F / G / H
AC3 Core = OK
E-AC3 Demux = OK
True HD Demux = OK
DTS Core = OK
DTS MA Demux = OK
Old 2nd July 2017, 20:05   #14967  |  Link
Calimero1609
@Atak
the new Ripbot264 V1.20 RC1 works great again :-) Big thx
RipBot264 1.20 RC1 / Windows 10 Pro
AC3 Core = OK
E-AC3 Demux = OK
True HD Demux = OK
True HD Atmos Demux = OK
DTS Core = OK
DTS MA Demux = OK
Would it be possible to support DTS Hi-RES (demux)?
Old 4th July 2017, 00:21   #14968  |  Link
Calimero1609
@Atak
Thanks for supporting DTS HI-RES
In RC1 / RC2 sometimes the window disappears into the background or the program terminates when a movie is read
Old 7th July 2017, 14:51   #14969  |  Link
nekrosoft13
hmm... there is something wrong with the new 1.20 versions (beta, RC2) still doing the same.
When I set it to x265 10bit 2pass and set bitrate to lets say 6000
First pass all looks fine, I can see the bitrate in ripbot gui, but when second pass starts bit rate according to ripbot gui drops to 400-600, and I end up with tiny files that are 100-300 mb, files look beyond horrible.
Older 1.18/1.19 versions never did that.
nekrosoft13 is offline   Reply With Quote
Old 7th July 2017, 16:02   #14970  |  Link
Atak_Snajpera
Show me .cmd files and log in your job folder
Old 8th July 2017, 20:52   #14971  |  Link
jonesjrgr
Problem with batch mode!!!
Hello everyone!!!
Just updated ripbot from 1.19.6 version to 1.20.0..!!!!
So far,so good for this amazing program!!!!!
But,there is a tiny flaw for me......I cannot use in batch automated mode.....I mean,if i go to batch mode (normal mode-file selection),all is good!!But if i go to batch mode (automated-folder selection),nothing happens!!!!No ripbot temp folder is created,no CPU usage,nothing!!!!Am i doing something wrong?Do i have to do some steps extra???
Thanks in advance for your help!!!!
jonesjrgr is offline   Reply With Quote
Old 8th July 2017, 21:58   #14972  |  Link
Atak_Snajpera
Automated batch mode basically works as Watch folder mode. When you add new file to watched folder then ripbot automatically creates job according to your settings. (each watched folder can have different encoding settings)
You can also use shortcuts instead of physical file.
Old 8th July 2017, 22:12   #14973  |  Link
jonesjrgr
OMG!!!!It works!!!!!Too many thanks to count for your help!!!
Maybe can i ask for a small request??
Can ripbot have an option to maintain original folder structure (with subs) in the target directory?And option to delete original files afterwards?
If it is too much hassle,i understand....
THANKS AGAIN!!!!!!!
Old 9th July 2017, 18:25   #14974  |  Link
nekrosoft13
job16_EncodeVideoPass1.cmd
"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64_10bit.exe" --pass 1 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --no-slow-firstpass --y4m --output NUL -
job16_EncodeVideoPass2.cmd
"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64_10bit.exe" --pass 2 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --y4m --output "C:\Temp\RipBot264temp\video.265" -
and log
C:\>"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64_10bit.exe" --pass 1 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --no-slow-firstpass --y4m --output NUL -
y4m [info]: 3840x2160 fps 24000/1001 i420p8 sar 1:1 unknown frame count
raw [info]: output file: NUL
x265 [info]: HEVC encoder version 2.4+87-5f2330bdb8fa
x265 [info]: build info [Windows][GCC 7.1.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 10 profile, Level-5 (Main tier)
x265 [info]: Thread pool created using 4 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 2 / wpp(34 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : dia / 57 / 2 / 1
x265 [info]: Keyframe min / max / scenecut / bias: 24 / 240 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 1 / on / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : ABR-6000 kbps / 0.60
x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip signhide tmvp fast-intra
x265 [info]: tools: strong-intra-smoothing lslices=8 deblock sao stats-write
C:\Temp\RipBot264temp\job16\job16.avs: 3840x2160, 10000000/417083 fps, 86332 frames
x265 [info]: frame I: 1019, Avg QP:22.11 kb/s: 27348.60
x265 [info]: frame P: 23147, Avg QP:21.76 kb/s: 10991.24
x265 [info]: frame B: 62164, Avg QP:25.57 kb/s: 3754.12
x265 [info]: Weighted P-Frames: Y:2.3% UV:2.0%
x265 [info]: consecutive B-frames: 12.2% 5.7% 6.4% 63.8% 11.8%
encoded 86330 frames in 18695.58s (4.62 fps), 5973.05 kb/s, Avg QP:24.51
C:\>"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64_10bit.exe" --pass 2 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --y4m --output "C:\Temp\RipBot264temp\video.265" -
raw [info]: output file: C:\Temp\RipBot264temp\video.265
x265 [warning]: Error: 2pass curve failed to converge
x265 [warning]: target: 6000.00 kbit/s, expected: 33933.62 kbit/s, avg QP: nan
x265 [warning]: internal error
x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2
x265 [info]: References / ref-limit cu / depth : 3 / on / on
x265 [info]: tools: rd=3 psy-rd=2.00 rskip signhide tmvp strong-intra-smoothing
x265 [info]: tools: lslices=8 deblock sao stats-read
x265 [info]: frame I: 1019, Avg QP:50.78 kb/s: 993.41
x265 [info]: frame P: 23147, Avg QP:48.59 kb/s: 569.96
x265 [info]: frame B: 62164, Avg QP:50.80 kb/s: 201.68
x265 [info]: Weighted P-Frames: Y:1.1% UV:1.0%
encoded 86330 frames in 14084.37s (6.13 fps), 309.77 kb/s, Avg QP:50.21
C:\>"C:\Program Files (x86)\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Administrator\Desktop\Big Little Lies - S01E07 - You Get What You Need.mkv" --compression 0:none --title "Big Little Lies - S01E07 - You Get What You Need" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng --sync 0:0 "C:\Temp\RipBot264temp\job16\1_audio_English.eac3" --default-track 0:no --language 0:eng -s 0 -D -A "C:\Temp\RipBot264temp\job16\2_subtitles_English.srt"
mkvmerge v13.0.0 ('The Juggler') 32bit
'C:\Temp\RipBot264temp\video.265': Using the demultiplexer for the format 'HEVC/h.265'.
'C:\Temp\RipBot264temp\job16\1_audio_English.eac3': Using the demultiplexer for the format 'AC-3'.
'C:\Temp\RipBot264temp\job16\2_subtitles_English.srt': Using the demultiplexer for the format 'SRT subtitles'.
'C:\Temp\RipBot264temp\video.265' track 0: Using the output module for the format 'HEVC/h.265 (unframed)'.
'C:\Temp\RipBot264temp\job16\1_audio_English.eac3' track 0: Using the output module for the format 'AC-3'.
'C:\Temp\RipBot264temp\job16\2_subtitles_English.srt' track 0: Using the output module for the format 'text subtitles'.
The file 'C:\Users\Administrator\Desktop\Big Little Lies - S01E07 - You Get What You Need.mkv' has been opened for writing.
'C:\Temp\RipBot264temp\video.265' track 0: Extracted the aspect ratio information from the HEVC video data and set the display dimensions to 3840/2160.
The cue entries (the index) are being written...
Multiplexing took 4 seconds.
Elapsed Time: 09h:06m:31s
and again i picked 6000 kb/s and I ended up with 311 kb/s
this started with 1.20 version, version 1.9.6 never gave me this issue.
Old 9th July 2017, 19:42   #14975  |  Link
Atak_Snajpera
Looks like x265 problem. Update x265 and see if this helps.
Old 9th July 2017, 20:15   #14976  |  Link
nekrosoft13
running again with x265 dated 7-7-17. since this binary was supplied by ripbot264 auto updater, just letting you know, its a problem.
Old 10th July 2017, 14:38   #14977  |  Link
Danette
PCM Audio Issue In 1.20
Is the PCM Audio bug back? RipBot264 demuxes the PCM audio, but it appears as "[NO AUDIO]" in the audio drop-down list.
When I try it in batch mode, the drop-down options are available, but the audio is left out of the resulting file.
Danette is offline   Reply With Quote
Old 10th July 2017, 16:06   #14978  |  Link
nekrosoft13
Atak, it seems to work now
I got the x265 from here https://builds.x265.eu/
but now I have another issue, I selected 10bit, and i'm only getting 8bit files....
C:\>"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64.exe" --pass 1 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --no-slow-firstpass --y4m --output NUL -
x265 [warning]: falling back to default bit-depth
x265 [info]: HEVC encoder version 2.4+98-06217c0e0f5f
x265 [info]: build info [Windows][GCC 6.2.1][64 bit] 8bit
x265 [info]: Main profile, Level-5 (Main tier)
x265 [info]: frame I: 1032, Avg QP:22.47 kb/s: 28228.50
x265 [info]: frame P: 23233, Avg QP:22.91 kb/s: 11014.27
x265 [info]: frame B: 62065, Avg QP:26.60 kb/s: 3738.32
x265 [info]: Weighted P-Frames: Y:1.8% UV:1.6%
x265 [info]: consecutive B-frames: 12.3% 6.1% 6.3% 64.2% 11.1%
encoded 86330 frames in 15677.57s (5.51 fps), 5989.18 kb/s, Avg QP:25.55
C:\>"C:\Program Files (x86)\RipBot264\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job16\job16.avs" -o - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64.exe" --pass 2 --bitrate 6000 --stats "C:\Temp\RipBot264temp\job16\job16.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 86330 --sar 1:1 --profile main10 --output-depth 10 --y4m --output "C:\Temp\RipBot264temp\video.265" -
x265 [info]: frame I: 1032, Avg QP:22.56 kb/s: 28865.64
x265 [info]: frame P: 23233, Avg QP:25.00 kb/s: 11107.88
x265 [info]: frame B: 62065, Avg QP:28.49 kb/s: 3713.67
x265 [info]: Weighted P-Frames: Y:0.8% UV:0.7%
encoded 86330 frames in 21661.35s (3.99 fps), 6004.26 kb/s, Avg QP:27.48
Multiplexing took 58 seconds.
Elapsed Time: 10h:23m:32s
Old 10th July 2017, 16:46   #14979  |  Link
sneaker_ger
That x265 binary was only built for 8 bit. You need to use a binary that's compiled for 10 bit (either 10 bit only or multi bitdepth).
Old 10th July 2017, 17:38   #14980  |  Link
Atak_Snajpera
Try these https://forum.doom9.org/showthread.p...75#post1811575
