Old 25th July 2010, 22:11   #2201  |  Link
cweb
cweb's Avatar
Originally Posted by Lyle_JP View Post
Same errors. GT 220 1GB, 257.21 Windows 7 x64. Also, to clarify, this is not an issue of trying to open an older .dgi file. These errors occur when I try to run DGIndexNV to create a new .dgi.
Same errors. GTX 285, 196.21 driver. Win7 x32.
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 25th July 2010, 22:12   #2202  |  Link
Please see my last post. Thank you.
Old 25th July 2010, 22:15   #2203  |  Link
cweb
cweb's Avatar
I've updated the 32-bit executable to add additional error reporting. I need someone for which it failed to re-download 2022 and try again with this and post the error popups that occur. Thank you.
Ok. Now it gave me this error as soon as dgindexnv was loaded.
Old 25th July 2010, 22:16   #2204  |  Link
kebulek
kebulek's Avatar
Same here.
kebulek is offline   Reply With Quote
Old 25th July 2010, 22:17   #2205  |  Link
Oops, I know what's wrong. Thanks for your test result.
Stand by for fixed version...
Old 25th July 2010, 22:18   #2206  |  Link
cweb
cweb's Avatar
thanks
Old 25th July 2010, 22:24   #2207  |  Link
Re-download 2022 and get the cubin file into the same directory as DGIndexNV.exe.
Report your success.
Old 25th July 2010, 22:29   #2208  |  Link
cweb
cweb's Avatar
I redownloaded it but the result was the same. I didn't find a cubin file. Could the file have been cached somehow? I cleared my cache and redownloaded just to be sure.
Old 25th July 2010, 22:29   #2209  |  Link
kebulek
kebulek's Avatar
I don't see any "cubin file" in current 2022 zip archive.
Old 25th July 2010, 22:35   #2210  |  Link
Oops.
Try again.
Thank you for your patience.
Old 25th July 2010, 22:38   #2211  |  Link
kebulek
kebulek's Avatar
Now it works for me. Looks like you did it after all...
Old 25th July 2010, 22:43   #2212  |  Link
I was hurrying to get you guys squared away and accidentally re-uploaded version 2002.
Also, I kinda forgot that the cubin executables are dynamically loaded, and that kinda means you need to have the binaries.
Old 25th July 2010, 23:20   #2213  |  Link
Groucho2004
Still getting this:
Old 26th July 2010, 00:02   #2214  |  Link
Your path refers to build 2021. What's up with that?
Verify that the correct cubin file (32 or 64 bit) is in the same directory as version 2022 DGIndexNV.
Old 26th July 2010, 00:15   #2215  |  Link
Groucho2004
Don't mind the path, I just didn't create a new directory.
I just tried again in a new directory with just the license file carried over from 2021. Same error message.
Edit: I'll try with XP now.
Edit1: Same thing on XP SP3.
Old 26th July 2010, 00:40   #2216  |  Link
State your Nvidia card type, memory size, and driver version.
Old 26th July 2010, 00:44   #2217  |  Link
Groucho2004
Asus GT 240 GDDR5, 512 MB, driver is 191.07.
Old 26th July 2010, 00:47   #2218  |  Link
Version 191.07 is very old and this error is known to occur with older driver versions. Please upgrade drivers to latest version and report results. FYI, I am running 257.21.
http://www.nvidia.com/object/winxp-2...ql-driver.html
Old 26th July 2010, 05:00   #2219  |  Link
SubJunk
Hi, I just registered 2 days ago and wanted to say thanks, it's really great. I was using 2021 and it worked perfectly, and 2022 works too.
It seems to be faster than before as well, though I haven't run tests.
SubJunk is offline   Reply With Quote
Old 26th July 2010, 05:38   #2220  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by Audionut View Post
Self reminder to delete old dll's from plugin dir when Don renames.
Good point. Otherwise people's scripts will continue to use the old DLL and not know it.
