17th June 2015, 12:04 | #161 | Link |
global MeGUI_darx = 40 global MeGUI_dary = 17 SetMemoryMax(1024) SetMTMode(5,2) LoadPlugin("D:\Program Files (x86)\MeGUInew\tools\dgindexnv\DGDecodeNV.dll") DGSource("E:\MeGUI\rsxyxu0x.yip\05 You only live twice (1967).dgi",fieldop=0) SetMTMode(5,1) KNLMeansCL(D=2, A=1, h=1.2, device_type="GPU") SetMTMode(2) #deinterlace #crop #resize #denoise The "SetMTMode(5,1)" is completely pointless (since you can't change the number of threads after the first call) as is "SetMTMode(2)" at the end. I tried your script with and without MT (adding "return last" at the end to get it to work), the speed difference in AVSMeter is virtually zero. If you understood how AVS MT works or read the documentation you would know that this is the expected result.
Groucho's Avisynth Stuff |
17th June 2015, 17:34 | #162 | Link | |
Anyway I have a GTX 760, then it should work. |
25th June 2015, 18:08 | #163 | Link |
>>>> KNLMeansCL_v0.5.5.zip <<<<
ChangeLog
VS takes longer. |
25th June 2015, 18:31 | #164 | Link |
#RGB32 Colorbars(1920, 1080, "RGB32").KillAudio().KNLMeansCL() #YV24 Colorbars(1920, 1080, "YV24").KillAudio() y = KNLMeansCL() u = UToY8().KNLMeansCL() v = VToY8().KNLMeansCL() YToUV(u, v, y) #YV12 Colorbars(1920, 1080, "YV12").KillAudio() y = KNLMeansCL() u = UToY8().KNLMeansCL() v = VToY8().KNLMeansCL() YToUV(u, v, y) #Y8 Colorbars(1920, 1080, "YV12").KillAudio() YV24 ------ 22.49 FPS YV12 ------ 43.58 FPS Y8--------- 68.98 FPS GPU architecture. Lovable. |
26th June 2015, 09:24 | #165 | Link |
Does KNLMeansCL support Temporal in Vapoursynth?
Got Error on this Code:
clip = core.knlm.KNLMeansCL (clip = clip, d=1, a=0, h=5.4, device_type="GPU") ##KNLMeans Temporal Medium Code:
clip = core.knlm.KNLMeansCL (clip = clip, d=1, a=1, h=4.5, device_type="GPU") ##KNLMeans Spatio-Temporal Medium Code:
clip = core.knlm.KNLMeansCL (clip = clip, d=0, a=4, h=3.6, device_type="GPU") ##KNLMeans Spatial Medium |
26th June 2015, 09:54 | #166 | Link | |
26th June 2015, 11:33 | #168 | Link |
Script ==>
import vapoursynth as vs core = vs.get_core() core.std.LoadPlugin(r'C:\Apps\Encoders\StaxRip\Apps\Plugins\both\ffms2\ffms2.dll') clip = core.ffms2.Source(source = r'C:\Temp\Media\SampleClip.mpg', cachefile = r'C:\Temp\Media\SampleClip temp files\SampleClip.ffindex') clip = core.knlm.KNLMeansCL (clip = clip, d=1, a=1, h=4.5, device_type="GPU") clip.set_output() Code:
vspipe.exe" "C:\Temp\Media\SampleClip temp files\SampleClip.vpy" - --y4m | x264.exe --crf 22 --demuxer y4m --frames 59 --output "C:\Temp\Media\SampleClip temp files\SampleClip_out.h264" "-" Code:
Negative frame request by: Cache1 x264 [error]: could not open input file `-' https://www.neatvideo.com/files4/testkit.zip |
26th June 2015, 16:09 | #169 | Link |
It should fix everything.
>>>> KNLMeansCL_v0.5.6.zip <<<< ChangeLog
26th June 2015, 18:18 | #170 | Link | |
i tried to use your filter 0.5.6 with vapoursynth under linux. It compiles after some small changes, but vapoursynth stops with errors. vs script: Code:
import vapoursynth as vs core = vs.get_core() file="/home/monarc/Downloads/test.mp4" clip = core.ffms2.Source(source=file) clip = core.knlm.KNLMeansCL (clip = clip, d=0, a=4, h=3.6, info=True) clip.set_output() Code:
Failed to evaluate the script: Python exception: knlm.KNLMeansCL: VapourSynthCreate error (1)! Traceback (most recent call last): File "vapoursynth.pyx", line 1469, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:23703) File "/home/monarc/filters/filters.vpy", line 50, in <module> clip = core.knlm.KNLMeansCL (clip = clip, d=0, a=4, h=3.6, info=True) File "vapoursynth.pyx", line 1368, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:22272) vapoursynth.Error: knlm.KNLMeansCL: VapourSynthCreate error (1)! Quote:
clinfo --help Number of platforms: 1 Platform Profile: FULL_PROFILE Platform Version: OpenCL 1.2 CUDA 7.5.9 Platform Name: NVIDIA CUDA Platform Vendor: NVIDIA Corporation Platform Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts Platform Name: NVIDIA CUDA Number of devices: 1 Device Type: CL_DEVICE_TYPE_GPU Device ID: 4318 Max compute units: 8 Max work items dimensions: 3 Max work items[0]: 1024 Max work items[1]: 1024 Max work items[2]: 64 Max work group size: 1024 Preferred vector width char: 1 Preferred vector width short: 1 Preferred vector width int: 1 Preferred vector width long: 1 Preferred vector width float: 1 Preferred vector width double: 1 Native vector width char: 1 Native vector width short: 1 Native vector width int: 1 Native vector width long: 1 Native vector width float: 1 Native vector width double: 1 Max clock frequency: 1760Mhz Address bits: 64 Max memory allocation: 268222464 Image support: Yes Max number of images read arguments: 128 Max number of images write arguments: 8 Max image 2D width: 16384 Max image 2D height: 16384 Max image 3D width: 2048 Max image 3D height: 2048 Max image 3D depth: 2048 Max samplers within kernel: 16 Max size of kernel argument: 4352 Alignment (bits) of base address: 4096 Minimum alignment (bytes) for any datatype: 128 Single precision floating point capability Denorms: Yes Quiet NaNs: Yes Round to nearest even: Yes Round to zero: Yes Round to +ve and infinity: Yes IEEE754-2008 fused multiply-add: Yes Cache type: Read/Write Cache line size: 128 Cache size: 131072 Global memory size: 1072889856 Constant buffer size: 65536 Max number of constant args: 9 Local memory type: Local Local memory size: 49152 Error correction support: 0 Unified memory for Host and Device: 0 Profiling timer resolution: 1000 Device endianess: Little Available: Yes Compiler available: Yes Execution capabilities: Execute OpenCL kernels: Yes Execute native function: No Queue properties: Out-of-Order: Yes Profiling : Yes Platform ID: 0x234f7f0 Name: GeForce GTX 560 Ti Vendor: NVIDIA Corporation Device OpenCL C version: OpenCL C 1.1 Driver version: 352.21 Profile: FULL_PROFILE Version: OpenCL 1.1 CUDA Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 |
26th June 2015, 19:46 | #171 | Link |
Can you tell me what you had to change? So I implement them.
However, it is a stupid mistake. Just do not use TAB with snprintf. Or just do not break line ("\"). Code:
if (channel == CL_FLOAT) { snprintf(options, 2048, "-Werror -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i -D NLMK_RGB=%i -D NLMK_S=%i -D NLMK_WMODE=%i -D NLMK_TEMPORAL=%i -D NLMK_H2_INV_NORM=%ff", H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); } else { snprintf(options, 2048, "-cl-denorms-are-zero -cl-fast-relaxed-math -Werror -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i -D NLMK_RGB=%i -D NLMK_S=%i -D NLMK_WMODE=%i -D NLMK_TEMPORAL=%i -D NLMK_H2_INV_NORM=%ff", H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); } Last edited by Khanattila; 26th June 2015 at 20:11. |
26th June 2015, 21:18 | #172 | Link |
Does not change much ... maybe i do something wrong.
Even with all changes, vapoursynth error remains the same. KNLMeansCL.txt: Code:
<kernel>:90:40: error: invalid digit 'f' in decimal constant (NLMK_WMODE == 2) ? fmax(1.0f -sum * NLMK_H2_INV_NORM, 0.0f) * fmax(1.0f -sum * NLMK_H2_INV_NORM, 0.0f) : ^ <built-in>:31:35: note: expanded from here #define NLMK_H2_INV_NORM 61,942730f ^ <kernel>:90:83: error: invalid digit 'f' in decimal constant (NLMK_WMODE == 2) ? fmax(1.0f -sum * NLMK_H2_INV_NORM, 0.0f) * fmax(1.0f -sum * NLMK_H2_INV_NORM, 0.0f) : ^ <built-in>:31:35: note: expanded from here #define NLMK_H2_INV_NORM 61,942730f ^ <kernel>:91:41: error: invalid digit 'f' in decimal constant (NLMK_WMODE == 1) ? native_exp(-sum * NLMK_H2_INV_NORM) : ^ <built-in>:31:35: note: expanded from here #define NLMK_H2_INV_NORM 61,942730f ^ <kernel>:92:29: error: invalid digit 'f' in decimal constant native_recip(1.0f + sum * NLMK_H2_INV_NORM); ^ <built-in>:31:35: note: expanded from here #define NLMK_H2_INV_NORM 61,942730f Code:
clang++-3.7 -o ../KNLMeansCL.so -std=c++11 -O3 -march=native -mtune=native -I/usr/local/include/vapoursynth -shared -fPIC -lOpenCL KNLMeansCL.cpp i wrapped #include "avisynth.h" with #ifdef _WIN32 and added #include "math.h" for ceil in KNLMeansCL.cpp: added a space between " Version " VERSION in line 454 Code:
diff -r -u3 KNLMeansCL/src/KNLMeansCL.cpp KNLMeansCL.patch/src/KNLMeansCL.cpp --- KNLMeansCL/src/KNLMeansCL.cpp 2015-06-26 16:31:48.000000000 +0200 +++ KNLMeansCL.patch/src/KNLMeansCL.cpp 2015-06-26 21:37:16.362359041 +0200 @@ -324,7 +324,7 @@ int pitch = dst->GetPitch(PLANAR_Y); char buffer[2048], str[2048], str1[2048]; DrawString(frm, pitch, 0, y++, "KNLMeansCL"); - DrawString(frm, pitch, 0, y++, " Version "VERSION); + DrawString(frm, pitch, 0, y++, " Version " VERSION); DrawString(frm, pitch, 0, y++, " Copyright(C) Khanattila"); snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * D + 1, 2 * A + 1, 2 * A + 1, 2 * S + 1, 2 * S + 1); DrawString(frm, pitch, 0, y++, buffer); @@ -451,7 +451,7 @@ int pitch = vsapi->getStride(dst, 0); char buffer[2048], str[2048], str1[2048]; DrawString(frm, pitch, 0, y++, "KNLMeansCL"); - DrawString(frm, pitch, 0, y++, " Version "VERSION); + DrawString(frm, pitch, 0, y++, " Version " VERSION); DrawString(frm, pitch, 0, y++, " Copyright(C) Khanattila"); snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); DrawString(frm, pitch, 0, y++, buffer); @@ -703,15 +703,9 @@ d.program = clCreateProgramWithSource(d.context, 1, &source_code, NULL, NULL); char options[2048]; if (channel == CL_FLOAT) { - snprintf(options, 2048, "-Werror \ - -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i \ - -D NLMK_RGB=%i -D NLMK_S=%i -D NLMK_WMODE=%i -D NLMK_TEMPORAL=%i -D NLMK_H2_INV_NORM=%ff", - H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); + snprintf(options, 2048, "-Werror -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i -D NLMK_RGB=%i -D NLMK_S=%li -D NLMK_WMODE=%li -D NLMK_TEMPORAL=%li -D NLMK_H2_INV_NORM=%ff",H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); } else { - snprintf(options, 2048, "-cl-denorms-are-zero -cl-fast-relaxed-math -Werror \ - -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i \ - -D NLMK_RGB=%i -D NLMK_S=%i -D NLMK_WMODE=%i -D NLMK_TEMPORAL=%i -D NLMK_H2_INV_NORM=%ff", - H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); + snprintf(options, 2048, "-cl-denorms-are-zero -cl-fast-relaxed-math -Werror -D H_BLOCK_X=%i -D H_BLOCK_Y=%i -D V_BLOCK_X=%i -D V_BLOCK_Y=%i -D NLMK_RGB=%i -D NLMK_S=%li -D NLMK_WMODE=%li -D NLMK_TEMPORAL=%li -D NLMK_H2_INV_NORM=%ff",H_BLOCK_X, H_BLOCK_Y, V_BLOCK_X, V_BLOCK_Y, 0, d.s, d.wmode, d.d, 65025.0 / (d.h*d.h*(2 * d.s + 1) * (2 * d.s + 1))); } ret = clBuildProgram(d.program, 1, &d.deviceID, options, NULL, NULL); if (ret != CL_SUCCESS) { diff -r -u3 KNLMeansCL/src/KNLMeansCL.h KNLMeansCL.patch/src/KNLMeansCL.h --- KNLMeansCL/src/KNLMeansCL.h 2015-06-26 16:32:42.000000000 +0200 +++ KNLMeansCL.patch/src/KNLMeansCL.h 2015-06-26 18:52:07.686612969 +0200 @@ -31,7 +31,10 @@ #include <CL/cl.h> #include "kernel.h" #include "startchar.h" +#ifdef _WIN32 #include "avisynth.h" +#endif +#include "math.h" #include "VapourSynth.h" #include "VSHelper.h" Code:
clang++-3.7 -ferror-limit=0 -o ../KNLMeansCL.so -std=c++11 -O3 -march=native -mtune=native -I/usr/local/include/vapoursynth -shared -fPIC -lOpenCL KNLMeansCL.cpp KNLMeansCL.cpp:397:60: warning: implicit conversion of NULL constant to 'cl_uint' (aka 'unsigned int') [-Wnull-conversion] vsapi->getStride(src, 0), 0, vsapi->getReadPtr(src, 0), NULL, NULL, NULL); ^~~~ 0 KNLMeansCL.cpp:405:36: warning: implicit conversion of NULL constant to 'cl_uint' (aka 'unsigned int') [-Wnull-conversion] 0, vsapi->getReadPtr(src, 0), NULL, NULL, NULL); ^~~~ 0 KNLMeansCL.cpp:439:35: warning: implicit conversion of NULL constant to 'cl_uint' (aka 'unsigned int') [-Wnull-conversion] 0, vsapi->getWritePtr(dst, 0), NULL, NULL, NULL); ^~~~ 0 KNLMeansCL.cpp:456:54: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); ~~ ^~~~~~~~~~~~ %li KNLMeansCL.cpp:456:68: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); ~~ ^~~~~~~~~~~~ %li KNLMeansCL.cpp:456:82: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); ~~ ^~~~~~~~~~~~ %li KNLMeansCL.cpp:456:96: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); ~~ ^~~~~~~~~~~~ %li KNLMeansCL.cpp:456:110: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " D:%i A:%ix%i S:%ix%i", 2 * d->d + 1, 2 * d->a + 1, 2 * d->a + 1, 2 * d->s + 1, 2 * d->s + 1); ~~ ^~~~~~~~~~~~ %li KNLMeansCL.cpp:458:46: warning: format specifies type 'int' but the argument has type 'long' [-Wformat] snprintf(buffer, 2048, " Iterations: %i", ((2 * d->d + 1)*(2 * d->a + 1)*(2 * d->a + 1) - 1) / (d->d ? 1 : 2)); ~~ ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ %li KNLMeansCL.cpp:460:55: warning: format specifies type 'int' but the argument has type 'size_t' (aka 'unsigned long') [-Wformat] snprintf(buffer, 2048, " Global work size: %ix%i", global_work[0], global_work[1]); ~~ ^~~~~~~~~~~~~~ %zu KNLMeansCL.cpp:460:71: warning: format specifies type 'int' but the argument has type 'size_t' (aka 'unsigned long') [-Wformat] snprintf(buffer, 2048, " Global work size: %ix%i", global_work[0], global_work[1]); ~~ ^~~~~~~~~~~~~~ %zu KNLMeansCL.cpp:664:52: warning: implicit conversion of NULL constant to 'cl_uint' (aka 'unsigned int') [-Wnull-conversion] ret |= clGetDeviceIDs(temp_platforms[i], device, NULL, NULL, &num_devices); ~~~~~~~~~~~~~~ ^~~~ 0 KNLMeansCL.cpp:694:16: warning: 'clCreateImage2D' is deprecated [-Wdeprecated-declarations] d.mem_in[0] = clCreateImage2D(d.context, CL_MEM_READ_ONLY, &image_format, d.image_dimensions[0], d.image_dimensions[1], 0, NULL, NULL); ^ /usr/include/CL/cl.h:1170:1: note: 'clCreateImage2D' has been explicitly marked deprecated here clCreateImage2D(cl_context /* context */, ^ KNLMeansCL.cpp:695:25: warning: 'clCreateImage2D' is deprecated [-Wdeprecated-declarations] if (d.d) d.mem_in[1] = clCreateImage2D(d.context, CL_MEM_READ_ONLY, &image_format, d.image_dimensions[0], d.image_dimensions[1], 0, NULL, NULL); ^ /usr/include/CL/cl.h:1170:1: note: 'clCreateImage2D' has been explicitly marked deprecated here clCreateImage2D(cl_context /* context */, ^ KNLMeansCL.cpp:696:14: warning: 'clCreateImage2D' is deprecated [-Wdeprecated-declarations] d.mem_out = clCreateImage2D(d.context, CL_MEM_WRITE_ONLY, &image_format, d.image_dimensions[0], d.image_dimensions[1], 0, NULL, NULL); ^ /usr/include/CL/cl.h:1170:1: note: 'clCreateImage2D' has been explicitly marked deprecated here clCreateImage2D(cl_context /* context */, ^ 15 warnings generated. |
27th June 2015, 10:08 | #175 | Link | |
Example: Red RGB(255, 0, 0) YUV(76, 84, 255) Violet RGB(127, 0, 255) YUV(67, 234, 170) Squared Euclidean distance between two points p(r, g, b) and q(r, g, b). d^2(p, q) = (p.r -q.r)^2 + (p.g - q.g)^2 + (p.b - q.b)^2 d^2(p, q) = (255 - 127)^2 + (0 - 0)^2 + (0 - 255)^2 d^2(p, q) = 81409 Squared Euclidean distance between two points p(y, u, v) and q(y, u, v). d^2(p, q) = (p.y - q.y)^2 + (p.u - q.u) ^2 + (p.v - q.u)^2 d^2(p, q) = (76 - 64)^2 + (84 - 234)^2 + (255 - 170)^2 d^2(p, q) = 29869 EDIT. Some people suggested a weighted Euclidean distance in RGB, example: d^2(p, q) = 3*(p.r -q.r)^2 + 4*(p.g - q.g)^2 + 2*(p.b - q.b)^2 = 179202 d^2(p, q) = 2*(p.r -q.r)^2 + 4*(p.g - q.g)^2 + 3*(p.b - q.b)^2 = 227843 Future investigations are needed. Last edited by Khanattila; 27th June 2015 at 10:58. |
27th June 2015, 12:58 | #176 | Link |
#define NLMK_H2_INV_NORM 61,942730f In german floats are written in plain text with a comma : e.g. 3,14 In english with point: 3.14 if i start vapoursynth with LC_ALL=C, the error is gone. |
27th June 2015, 15:24 | #178 | Link |
I want to try Dithertools to denoise with 16 bit precision. Would the following code be correct?
Dither_convert_8_to_16() y = KNLMeansCL(D = 1, A = 1, h = 1.5, lsb_inout = true) u = UToY8().KNLMeansCL(D = 1, A = 1, h = 1.5, lsb_inout = true) v = VToY8().KNLMeansCL(D = 1, A = 1, h = 1.5, lsb_inout = true) YToUV(u, v, y) f3kdb(sample_mode = 2, keep_tv_range = true, input_mode = 1, output_mode = 1) DitherPost()
27th June 2015, 16:09 | #180 | Link | |
I'm Siri
