15th November 2009, 13:42 | #9201 | Link |
Media Control author
Thank you all for your encouragements, but we still lack of results
Here is an updated and working version (at least for AC3/DTS) of MPC renderer Actually wasapi implementation is buggy : it may be due to the drivers or to an incompatibility butween wasapi with event driver mode (which is the easiest to implement) and directshow. Anyway, here it is There are 2 versions : one debug and one release (that should avoid glitches) THank you for your feedbacks ! EDIT : I have an audio delay on this one but no more glitches. I will fix this later. Last edited by albain; 15th November 2009 at 13:53. |
15th November 2009, 14:49 | #9202 | Link |
A.K.A Mangoat
Hi albain.
Thanks for yet again more excellent work. Here are my results with the new renderer: TrueHD: The sample played jerkily, and in PCM: http://pastebin.com/f34f6be21 DD Plus: As above: http://pastebin.com/f7d40474e DTS HD MA (from m2ts): The file played, but I got no audio: http://pastebin.com/f702b8304 DTS HD MA (from mkv): The file played as PCM, but halli splitter loaded rather than your mpeg splitter: http://pastebin.com/f38172210 Thanks! |
15th November 2009, 15:00 | #9203 | Link |
Thanks but you have a xonar right ?
It seems that the xonar will refuse the arcsoft media types (!). I believe that there is additional security rules in the audio driver that will refuse the connection if for example the process is not protected or something like that (because otherwise FFDShow will try different media types including the arcsoft's ones). Sorry, but for now I need a radeon 5xxx owner. Maybe this is fixable for the xonar : for that I am still trying to improve the dumper tool to retrieve more information from the *well known player* |
15th November 2009, 16:16 | #9207 | Link |
albain, your sample thd m2ts gives dolby digital but ffdshow output gives only 2 channels.
Btw i created some sample m2ts files via eac3to+tsmuxer but ffdshow never accepted to connect to MPCAudio Renderer (with those files) while your sample m2ts (thd) file works; dunno why? Would you please remux your dtshd.mkv to m2ts? |
15th November 2009, 16:32 | #9208 | Link |
TrueHD: http://pastebin.com/pastebin.php?dl=d1931dda2
DTS-HD MA: http://pastebin.com/pastebin.php?dl=d5ef51a85 TrueHD shows me lights. DTS-HD MA shows me DTS. Neither give me audio. This is the debug version. I can try the release version now but I'm not hopeful. |
15th November 2009, 17:16 | #9213 | Link |
Something is wrong. I don't see many traces from MPC renderer. Is MPC renderer really used at the end ?
Please use graphstudio with the MPC splitter that I released in the last pack, thanks Could you try with this one Thanks |
15th November 2009, 17:29 | #9217 | Link |
DTS-HD MA...it's an mkv converted to m2ts and played in GS.
http://pastebin.com/pastebin.php?dl=d518707c6 DTS light, no audio. |
15th November 2009, 17:34 | #9218 | Link | |
truhd > Dolby Digital light on > with sound (ffdshow output gives two channels only) dtshd-ma > no light on > without sound dts (core) > DTS light on > with sound (ffdshow output gives two channels only) EDIT: btw- those trials made with ex-filter; didn't see new update while writing Now i'm trying the new one. Last edited by rica; 15th November 2009 at 17:38. |
15th November 2009, 17:37 | #9219 | Link |
I'm getting mixed results here on the formats I am able to test.
AC3 passthrough has the same behavior as before with me having to check "output strings to debugger" and run DebugView to get bitstreaming to work. One or the other of these does not work, it requires both. When it *does* bitstream, though, it now seems to be mostly glitch-free with maybe a couple of skips when first starting playback. TrueHD, unsurprisingly, falls back to decoding and outputting PCM. With my sample, it is able to play back the decoded PCM audio as 5.1 channels (matching my speaker configuration) and sounds fine. No distortion, no glitches. DD+ and DTS-MA also fall back to PCM, but play back with a lot of distortion. Another odd behavior pops up when trying to test with a file with an MP3 audio track. FFDShow won't connect directly to the MPC audio renderer and instead inserts the WMAaudio Encoder/Decoder combo in between. Deleting these filters from the graph makes the FFDshow filter connect to the renderer directly. Either connected directly or with the WMAudio filters in between there is distortion of the audio during playback. |
15th November 2009, 17:59 | #9220 | Link |
Here are the results:
truhd > Dolby Digital light is on > with sound (ffdshow output gives 5.1 even it shows 2 channel output in ffdshow properties page) _this is maybe comes from using thd+ac3 file (created by eac3to) in tsmuxer? dtshd-ma > no light is on > without sound dts (core) > DTS light is on > with sound (ffdshow output gives 5.1 even it shows 2 channel output in ffdshow properties page) Seems there is a conflict between the results of mine and samuri? Last edited by rica; 15th November 2009 at 18:19. |
