18th September 2009, 22:02 | #345 | Link |
Speaking of resizing... is there any option to choose what resize algorithm (bilinear, etc) to use? Currently i use Spline36resize() in avisynth and it gives slightly better output (quality wise) than the gpu's.
18th September 2009, 22:25 | #347 | Link |
OK, i think i can live with that... The difference between these 2 algorithms (spline36 and gpu's bilinear - from 1080p to 720p) is only visible when comparing still frames zoomed @ 200%.
19th September 2009, 05:18 | #349 | Link |
I have a G105M. While it's not on the table, it's supposed to be a newer 9300M and I'm also pretty sure it supports VP3. I have the same error as Inspector Gadget: GPU decoder: Failed to create video decoder [100], and I'm running the latest drivers that nVidia has: 186.81.
20th September 2009, 21:09 | #354 | Link | |
Spline36Resize 576 to 1080: DG nVidia resize 576 to 1080: Here are the original ScreenShots: Spline: nVidia: AVS files: 1) Code:
DirectShowSource("C:\Users\rica\Desktop\How to deal\VTS_08_1.grf", fps=25.000, audio=false) Spline36Resize(1920,1080) ConvertToYV12() MPC MPEG Source > MPC MPEG2 Video Decoder 2) Code:
LoadPlugin("C:\users\rica\desktop\Tools\DGNVTools\DGDecodeNV.dll") DGSource("C:\users\rica\desktop\how to deal\DG\VTS_08_1.dgm", resize_w=1920, resize_h=1080) _ _ _ _ _ Last edited by rica; 21st September 2009 at 01:25. |
21st September 2009, 00:03 | #358 | Link |
Well, it's a MEGUI thing. Who's coding this stuff nowadays so I can talk to him about it? If we work together on it I'm sure we can get seamless operation.
@rica When does it happen? Please describe the exact sequence of actions that produces it. |
21st September 2009, 00:18 | #359 | Link | |
Starting MeGui unless CUVidServer running didn't fix the issue. So i uninstall-reinstall MeGui, DGTools and nVidia FW drivers but nothing has changed; i don't know what happened??? PS: BTW MPC-HC opens and plays the same avc files while CUVID Server is opened. So this must be a MeGui issue but what is interesting is how it appeared suddenly? Last edited by rica; 21st September 2009 at 00:55. |
21st September 2009, 00:55 | #360 | Link |
@neuron2: i think Kurtnoise is the man.
@rica: I don't know why it doesn't work for you; the only thing that I suggest you check, is if you have correctly set the path for the DG*NV executables in MeGUI settings, I think that MeGUI uses them to determine the path for CuVIDServer too. |
