9th August 2010, 14:27 | #2343 | Link |
Might MKV indexing possibly be optimized for better speed? It seems it's a lot slower then TS indexing.
9th August 2010, 15:04 | #2344 | Link |
I use Haali's low level library as is because it is released for free use without licensing. I can look at the other available libraries if they are LGPL so that I can invoke them as DLLs. Alternatively I can look at optimizing Haali's code. Can't promise an ETA but I will put it on the to-do list.
9th August 2010, 23:48 | #2346 | Link |
^Nvidia's drivers don't support lossless.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
10th August 2010, 10:14 | #2349 | Link |
Can extract subtitle using DGIndexNV?
Hi all!
Sorry for off topic. I am using DGIndexNV for getting index files dga and Dolby digital sound from set of mts files. I do not have problem with video and audio, but how I can get subtitles from set of mts files? Please advice. With kind regards yup. |
10th August 2010, 10:29 | #2350 | Link |
DGIndexNV can't extract subtitles, there are two common ways:
1. MakeMKV > mkvextract, StaxRip and RipBot264 fully automate mkvextract. DGDecNV, ffms2, DSS/DSS2 all can open MKV containing AVC/VC-1/MPEG-2. Works equally and great for both DVD and Blu-ray. 2. eac3to demuxing, this is a command line tool, most GUIs make it easy to use, StaxRip, RipBot264, MeGUI, HD-DVD/Blu-Ray Stream Extractor and many others.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 10th August 2010 at 11:00. |
10th August 2010, 13:50 | #2352 | Link | |
Aging Video Hobbyist
10th August 2010, 16:51 | #2355 | Link |
Ha, ha! Well, I appreciate your candor!
Neither do I know anything about SLI, but I do have a sexy little jumper-bracket for linking two cards together...somewhere, provided I haven't lost it. That's all I know. In one of the DGNV threads sometime ago someone said SLI didn't help; maybe that someone will trip across these posts and re-confirm... |
10th August 2010, 21:52 | #2357 | Link |
Posts: n/a
Being able to choose which GPU to do the decoding on would be a great addition. I've just upgraded from a 9500gt to a gtx460 and although DGNV still runs perfectly, i've found that while decoding videos it stops the Video Card from going into low power mode. With the new video card in, while decoding, my computer users another 200watts of electricity for no speed benefit as my encoding is the same speed using either the 9500 or the gtx460. In Australia, that 200watts of electricity it is using will end up being quite expensive when my electricity bill arrives as i'm encoding 24 hours a day.
What i would like to do is put my 9500gt back in, and set DGNV to decode on that which hopefully would allow my gtx460 to go into low power mode dropping my electricity usage considerably. Would this work with what you are planning for supporting of multiple video cards? I don't mind donating again if you can make this work this way. |
11th August 2010, 00:32 | #2360 | Link | |
I was also thinking if I split my encodes in half & used multiple video cards that I could improve processing time by running the encodes of both halves at the same time. I have a xeon quad core with turbo/hyperthreading. I can't seem to utilize more than 50% CPU even with MT. |
