Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 18th May 2013, 09:57   #21  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for version 2.4
* Don't clean up in case dvdauthor exits with a status > 0
* Replaced some case statements by if conditionals in the aspect ratio code
* Added support for writing the ISO image to a DVD disc. This updates the config file version to 2 and adds the following variables:
   DEFAULT_DVD_DEVICE, DVD_RW_FORMAT and GROWISOFS
* Renamed NICE_VALUE var in the config file to DEFAULT_NICE_VALUE
* Make file2dvd adaptable based on available programs. If a required program is missing, and that program is not critically needed, disable
   the provided functionality. For example, if dvdauthor is missing, warn and disable creation of a DVD structure and subsequent ISO creation.
   If mkisofs or genisoimage is missing, warn and disable creation of an ISO image and DVD burning capability
* Updated the man page
Old 19th May 2013, 11:48   #22  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 2.5
* Added support for MP2 audio encoding for PAL encodes
* Detect audio codec if user chooses to copy it. Based on detection, decide if we exit in case the audio codec isn't supported by the DVD standard
* Added option (nosound) to skip audio encoding
* Minor code optimizations
Old 20th May 2013, 09:56   #23  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 2.6
* Bugfix: in case nosound was selected as audio option, video bitrate couldn't be calculated
* Moved the audio detection code out of the audio copy option
* Detect and display audio channels
* Detect and display video aspect ratio
* Added support for encoding to LPCM audio
* Presets quality optimizations
Old 21st May 2013, 10:11   #24  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 2.7
* Added support for hard-telecining the encode and convert its frame rate from 23.976 to 29.970fps. Note that this requires the latest ffmpeg
from git as the telecine filter is a very recent addition
* Bugfix: 384 kbps option was missing for AC3 audio
Old 22nd May 2013, 08:08   #25  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 2.8
* Set GOP size to 15 for 23.976 fps NTSC
* Added support for the audio volume filter which can be used to increase or decrease the audio volume
* Added support for using MEncoder for encoding. This updates the config file version to 3 and adds the
   following variables: DEFAULT_ENCODER and MENCODER
Old 23rd May 2013, 11:09   #26  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 2.9
* Minor code optimizations to the MEncoder code
* Added support for converting NTSC content to PAL and PAL to NTSC when using MEncoder as encoder
* Added support for the hqdn3d denoise filter
* Added the softskip and harddup filters for MEncoder
* Allow 50 fps and 59.940 fps as input and automatically convert it to supported FPS by DVDs
Old 24th May 2013, 07:50   #27  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.0
* Added support for the owdenoise and dctdnoiz denoise filters for ffmpeg. Requires latest ffmpeg from git
* Added support for the ow denoise filter for MEncoder
* Reduced the video filters code. Now all video filters are placed in one global variable called vidfilters
* Also accept codec names (ac3, mp2,...) in addition to the codec number
* Added support for the mcdeint deinterlacer when using MEncoder as encoder
Old 25th May 2013, 09:24   #28  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.1
* Added a custom MPEG-2 matrix, optimized for low to moderate bitrates (~2000-4000 kbps)
* Bugfix: in case video length must be manually provided when we fail to auto-detect it, video bitrate couldn't be calculated
Old 26th May 2013, 10:48   #29  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.2
* Print calculated video bitrate after user provides target size
* Minor optimizations
* Added support for hard-telecining 23.976fps to PAL when using ffmpeg as encoder
* Added support for enabling/disabling audio and video filters in the config file. This bumps up the version of the config file to 4
Old 27th May 2013, 08:03   #30  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.3
* Added -pix_fmt yuv420p to the ffmpeg options
* Added support for deblocking when using MEncoder as encoder
Old 30th May 2013, 16:10   #31  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.4
* Added three additional quant matrices (KVCD Notch, Bach1, HVS Best)
* Added support for using MPEG-style quantizers. Requires latest ffmpeg from git and mencoder from svn
Old 31st May 2013, 07:32   #32  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.5
* Fix the HVS Best matrix. There was a comma missing before the last value in both intra and inter vars
Old 1st June 2013, 22:09   #33  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.6
* Added one more custom quant matrix, QLB (Quenc Lower Bitrate)
* Added support for the mcdeint deinterlacer when using ffmpeg as encoder. Requires latest ffmpeg from git
Old 2nd June 2013, 12:13   #34  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.7
* Set field order to TFF when telecining with ffmpeg
* Added support for the kerndeint deinterlacer
* Added support for interlacing of 50/59.940 FPS content
Old 3rd June 2013, 11:19   #35  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.8
* Use tinterlace=4 when interlacing with MEncoder
* Added support for the tinterlace filter when using ffmpeg as encoder
* Added support for converting PAL content to NTSC and NTSC to PAL when using ffmpeg as encoder
Old 4th June 2013, 11:36   #36  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 3.9
* Don't ask for PAL -> NTSC conversion in case user has selected to Hard-Telecine to PAL
* Use the setpts filter together with the fps filter when doing NTSC <-> PAL conversions
Old 6th June 2013, 11:28   #37  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.0
* Added support for encoding to DTS audio when using ffmpeg as encoder
Old 6th June 2013, 11:41   #38  |  Link
microchip8
microchip8's Avatar
I guess I was too fast to release
ChangeLog for version 4.1
* Fix audio codecs order
Old 7th June 2013, 15:18   #39  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.2
* Add missing and valid bitrates for DTS audio
Old 8th June 2013, 15:54   #40  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 4.3
* Detect and display audio sample rate
dvd, ffmpeg, file2dvd, mencoder, mpeg2
