Old 7th September 2007, 13:23   #21  |  Link
Originally Posted by SpAwN_gUy View Post
... but..
But what?
Guest is offline
Old 10th September 2007, 10:30   #22  |  Link
SpAwN_gUy
Junglist
SpAwN_gUy's Avatar
But what?
But, maybe, such an option will be more convinient and more universal(can i use this word in this context?)
Rule Number 6: Concentrate!!!
(c)Hercules, Disney
"I like to build planes.... in the air" (c) some ADV.
tutorials
How to Setup agent-based encoding with x264farm (the easy way)
SpAwN_gUy is offline
Old 12th September 2007, 01:24   #23  |  Link
DGMPGDec 1.5.0 beta 2
* The file type .m2t was added to the open dialog.
* Some array sizes were increased to prevent crashes in the debugger.
* The next_start_code() function was enhanced to add error resiliency for abnormal slice terminations.
* Because the code never writes to the DirectDraw surface anymore (removed long ago!), the DirectDraw Overlay option was removed. DGIndex now never seizes the overlay.
http://neuron2.net/dgmpgdec/dgmpgdec150b2.zip
Guest is offline
Old 13th September 2007, 09:23   #24  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Are you interested in taking a look at a sample in which the delay is way off target?
The reason why I ask you first is that the bad VOB is the result of RipIt4Me+FixVTS, a good delay value is found when the disc is decrypted using DVDFab HD Decrypter. PGCDemux does show the correct value from the bad VOB so it is there somewhere The disc is ARccOS protected (a Sony release) if I'm not mistaken.
Since many people still use RipIt4Me, it might be interesting to know whether this odd behaviour could be avoided in DGIndex (which is used by many applications).
Boulder is offline
Old 13th September 2007, 13:34   #25  |  Link
Sure. Post a fragment of the start of the VOB. Don't cut the start.
Guest is offline
Old 13th September 2007, 16:11   #26  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here it is : http://www.savefile.com/files/1052641
DGIndex 1.5.0 beta 2 reports delay 81112ms, the correct is apparently -128ms which PGCDemux reports, it is also the same value that DGIndex reports when processing the DVDFab HD Decrypter-ripped VOB.
Boulder is offline
Old 13th September 2007, 19:14   #27  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I've just run your .VOB sample thru' EVOdemux and it reports the same delay time as DGIndex.... Strange eh!
Cheers
SeeMoreDigital is offline
Old 13th September 2007, 19:18   #28  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Funny thing is that PGCDemux doesn't find any audio tracks when opening the corresponding .ifo file and using "by PGC" mode. The whole audio track can only be found if I use "by VOBId" and choose the correct VOBId. (choosing "by cell" works as well but it shows the delay only for the cell in question)
Maybe this is the reason for the weird delay?
Boulder is offline
Old 13th September 2007, 20:25   #29  |  Link
File sharing sites are blocked by my employer so I can't get to it until tonight. But did you try the standard trick of starting the project in by several GOPs (e.g., hit > 5 times and then [ before saving the project)?
Guest is offline
Old 13th September 2007, 20:30   #30  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Actually no, this is the first time I've run into this problem. If it solves the issue, what about those applications that use DGIndex, such as DVD-RB? That trick cannot be used with them.
Boulder is offline
Old 13th September 2007, 21:11   #31  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yep, jumping a few GOPs seems to work. I wonder how DVD-RB or MeGUI would behave..I think I'll need to run a test project and see what comes out.
Boulder is offline
Old 13th September 2007, 21:36   #32  |  Link
Well, it means that there is crap at the beginning and it is confusing the delay calculation. I'll have to think about what can be done for DVDRB, etc., in this regard.
Guest is offline
Old 16th September 2007, 16:13   #33  |  Link
the only thing that in nonautomatic is storing of relative paths in the d2v
Just to be completely clear about this...
1. When you say 'relative', do you mean relative to the path location of the D2V file? That path is to be the base location for everything else, yes?
2. You talk about network drives. But I can't make a relative path go to a different drive, i.e., this is not possible from drive c for example:
..\d:\path\file.vob
So how do you intend to use this relative path capability in this scenario?
Guest is offline
Old 16th September 2007, 16:48   #34  |  Link
This has come up so many times now that I have added a warning popup when a large audio delay is calculated. The popup explains the GOP skipping trick.
Guest is offline
Old 16th September 2007, 17:23   #35  |  Link
Boulder
Pig on the wing
Boulder's Avatar
That's a good idea - especially because it has been quite rare but apparently has become more common due to the structure crippling protections.
Boulder is offline
Old 16th September 2007, 18:20   #36  |  Link
Rainy
..\d:\path\file.vob
Just force the storage of absolute paths. Though it doesn't seem that he'd like to use the relativeness feature this way, but simply being able to move the directory structure including the project file from a local hard drive to a network store, without editing d2v internals manually.
Rainy is offline
Old 17th September 2007, 08:52   #37  |  Link
SpAwN_gUy
Junglist
SpAwN_gUy's Avatar
yes. path to VOBs relative to .d2v-file path.
..\d:\path\file.vob
yep. exactly. (as i can remember) Windows stores "relative-paths" when files are on the same drive, and "full-paths" when on different..
just store "d:\path\file.vob"
it is, like, for moving files from one drive to another without loosing playability and encodeability.. without editing .d2v's or making another Indexing..
(c)Hercules, Disney
tutorials
Old 17th September 2007, 13:58   #38  |  Link
You're not answering my question. What is the point of me adding relative path handling for this networking scenario, which you cited as a reason for adding it? We can already store full paths. If you don't make things clear I'm going to move on.
But if I store the full path, you can't have this movability.
I'm just not seeing the point of all this.
Guest is offline
Old 17th September 2007, 14:29   #39  |  Link
Rainy
You're mixing things up: Absolute paths have to be stored whenever the project and video files don't share a common prefix, i.e. are located on different drives, *even* if the user chooses paths to be stored relatively. This is a special handling for the scenario you've mentioned before, since there's no such a thing as relativity between different drives In any other case you simply store relative paths, which makes it possible to move files around and never have to edit the project file.
Rainy is offline
Old 17th September 2007, 14:37   #40  |  Link
Ha ha, I'm not an idiot. I'm asking for justification for the feature. If the only thing he wants is to store his source files away from his D2V, then it's too minor to jump ahead of other stuff on my to-do list. If it can support his farming stuff, which he cited, then it might be more worthwhile. But I don't see how it can help in that regard.
Guest is offline
