Old 3rd December 2008, 14:48   #1661  |  Link
Originally Posted by komisar View Post
neuron2, sorry for my misunderstand (more beer not good, sorry). Where can I get you use version of libavcodec?
ffdshow-tryout 1837
Guest is offline
Old 3rd December 2008, 15:03   #1662  |  Link
laserfan
Aging Video Hobbyist
Hmmm, it's right in the DGAVCDec package--and you have read the included docs, yes?
laserfan is offline
Old 3rd December 2008, 15:43   #1663  |  Link
The docs don't (currently) specify the source code version I used, so his was a quite reasonable question, given that he is trying to rebuild the DLL I ship.
Guest is offline
Old 3rd December 2008, 22:43   #1664  |  Link
laserfan
Ah, sorry komisar I misunderstood your intentions.
laserfan is offline
Old 4th December 2008, 15:15   #1665  |  Link
komisar
komisar's Avatar
neuron2, ok. I grab all for my need but:
I have made a small modification to return a different version string to
manage compatibility issues. This modification is available on request.
Can I "request" this modification?
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline
Old 4th December 2008, 15:56   #1666  |  Link
Here is my modified src/ffmpeg directory:
http://neuron2.net/misc/ffmpeg1837dg.zip
Please coordinate any release of a new libavcodec.dll with me please, as it is quite easy to break DGAVCDec functionality if you upgrade to more recent ffmpeg code.
Guest is offline
Old 4th December 2008, 16:05   #1667  |  Link
komisar
komisar's Avatar
neuron2, THNX.
Ok. No problem. If I successfully build what i need -- i am post patch here.
komisar is offline
Old 4th December 2008, 20:33   #1668  |  Link
komisar
komisar's Avatar
neuron2, latest version of ffdshow-tryout not work correctly. Version of 1837 with h264_predictive_lossless2.diff non-lossless open correctly, lossless -- open with message
show first frame correctly, but crash with save .dga or play [F5]
tested with dgavcdec107.zip
P.S. latest ffdshow-tryout and dgavcdec100a35.zip work (without h264_predictive_lossless2.diff).
komisar is offline
Old 4th December 2008, 21:23   #1669  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
@neuron
Could you check this sample http://www.mediafire.com/?ymugtm4zhnj
DGAVCindex reports insane audio delay (CANALplus.FILM.HD.Nordic.Thor.0.8W.10jul.2007 PID 281 3_2ch 384Kbps DELAY -45759574ms.ac3).
eac3to reports -241ms
Atak_Snajpera is online now
Old 5th December 2008, 02:48   #1670  |  Link
I've been working on audio delay for the last two days and found quite a few bugs. It's now working well in my private build, which fixes your stream.
The canTsTop stream is a different matter. It has the AVC equivalent of the problem we sometimes saw with DGIndex where you have to start your project in by a GOP. It's a pathologic stream and I wrote a timestamps analysis tool to prove it. For that stream, starting in by a GOP together with the fixes I mentioned produces a good result. I'll explain it all in detail when I make the release. I just have to do some regression testing.
BTW, I am removing the Treat I as IDR option. There's no reason not to have it on always. Speak up now if you disagree.
Guest is offline
Old 5th December 2008, 02:50   #1671  |  Link
Sagekilla
x264aholic
is h264_predictive_lossless2.diff the one that changes the lossless mode from intra --> inter frame based?
If it is, that's why ffdshow-tryouts won't open it. No decoder except CoreAVC (I think) supports predictive lossless.
Sagekilla is offline
Old 5th December 2008, 02:52   #1672  |  Link
If you give me the changes I can try to debug it for you.
It may appear to work for simple streams but random access is broken with many of my test streams. Anyway, why use such an old version of DGAVCDec?
Guest is offline
Old 5th December 2008, 07:37   #1673  |  Link
komisar
komisar's Avatar
neuron2
http://komisar.gin.by/test/ffdshow-tryout_1837.7z (Clear 1837 version)
http://komisar.gin.by/test/dg_ffdshow-tryout_1837.diff (You modification for 1837 version)
http://komisar.gin.by/test/libavcodec.dll (compiled version with predictive_lossless2 patch)
http://komisar.gin.by/test/ff_lossless_old_ffmpeg.diff (lossless patch for old version of ffmpeg)
http://komisar.gin.by/x.patch/last.u...lossless2.diff (lossless patch for actual version of ffmpeg)
I am forgot to update the version...
komisar is offline
Old 5th December 2008, 13:52   #1674  |  Link
DGAVCIndex108test: audio sync fixes
As the changes were extensive, I'd like to get some testing on this before a release.
http://neuron2.net/misc/dgavcindex108test.zip
@Atak_Snajpera
It fixes your bug.
@canTsTop
Your stream has an issue at the beginning. After loading your file, hit the > button and then the [ button to start the project in by one GOP. Then Save project.
Test results will be appreciated. Thank you.
Guest is offline
Old 5th December 2008, 13:54   #1675  |  Link
...stuff...
Thank you. Can you also provide me a lossless sample stream?
Guest is offline
Old 5th December 2008, 14:03   #1676  |  Link
komisar
komisar's Avatar
http://komisar.gin.by/test/test_ll.264 (lossless)
http://komisar.gin.by/test/test_safe.264 (safe, crf=26)
komisar is offline
Old 5th December 2008, 14:05   #1677  |  Link
You be da man. Thank you.
Guest is offline
Old 5th December 2008, 16:55   #1678  |  Link
canTsTop
canTsTop's Avatar
This way i get correct a/v synchronization
And with this new version i can see difference in other video, now i get perfect synchronization. i made samples if anyone interest, difference is small but exist:
with old DGAVCIndex: http://www.mediafire.com/file/ulgogijzmnu/old.avi
with new DGAVCIndex: http://www.mediafire.com/file/2j231mdmtz1/new.avi
Thank You neuron2 very much
p.s. with this new version dgavcindex108test, i get this warning then i save project, is it normal?
with dgavcdec107 there is no such warning
canTsTop is offline
Old 5th December 2008, 17:17   #1679  |  Link
For the error popup, can you give me a stream? Thank you.
Guest is offline
Old 5th December 2008, 17:22   #1680  |  Link
canTsTop
canTsTop's Avatar
here it is http://www.mediafire.com/?0yndynjgfnm
canTsTop is offline
