29th June 2015, 08:41 | #13661 | Link |
Meanwhile I just did the 4mins in one chunk to see how how it turns out using crf 23 1st pass (first pass without defined bitrate).
There is a noticeable difference even without breaking the video into chunks: http://screenshotcomparison.com/comparison/132941 Maybe simply upscaling the bitrate for 2nd pass isn't that good? I noticed the first pass bitrate results are considerably smaller 2nd pass target, and I used a relatively low bitrate for 2nd pass (first passes were around 1000, 2nd pass was 3000). I'm not a big expert, but the stats file seem to include all sorts of stuff that maybe isn't just bitrate related: cpbdur:2 q:26.11 aq:21.71 tex:273375 mv:20072 misc:1193 imb:534 pmb:2811 smb:175 d:s ref:0 Last edited by mini-moose; 29th June 2015 at 08:55. |
29th June 2015, 14:49 | #13662 | Link | |
30th June 2015, 11:35 | #13663 | Link | |
It was mostly to demonstrate that cq first pass doesn't give the same reference as real first pass does. Remember this is not split first pass. It was a lot worse when I used 60 seconds chunks. |
30th June 2015, 19:26 | #13664 | Link | |
It turns out that default CRF 23 is not accurate enough to estimate chunk's complexity. CRF value increased to 16 seems to be much more accurate. Screenshot from chunk 6 Normal mode -> http://i.cubeupload.com/hM3KmT.png DE crf 23 -> http://i.cubeupload.com/uJqdy8.png DE crf 16 -> http://i.cubeupload.com/1yJNyf.png And here is explanation why some chunks have poor quality. Bitrate Distribution for chunks with CRF 23 Bitrate Distribution for chunks with CRF 16 No wonder that chunk 6 has such poor quality if it only gets 0.66 of target bitrate instead of ~1. Also first and last chunk wastes a lot of bitrate budget because when I was comparing those two sections I had not seen any obvious differences in quality. Try this patch http://www.mediafire.com/download/gr..._for_1.18.3.7z
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 30th June 2015 at 19:29. |
30th June 2015, 23:36 | #13665 | Link | |
Did you try any crf values in between too or went straight to 16? I'll give it a try too. Thanks. |
1st July 2015, 10:52 | #13666 | Link |
16 seems to be a good value
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 1st July 2015 at 14:49. |
1st July 2015, 16:50 | #13667 | Link |
After further investigation I've noticed that even with higher crf value there are still cases where quality of the frame drops. I guess that .stat file generated using CQ mode is not always compatible in second pass so I decided to restore previous old method with 10 min chunks with constant bitrate for each chunk.
Please re-download again 1.18.3 if you use DE mode with 2-pass. Sorry for this mess. I should have tested this method a little bit more...
1st July 2015, 22:36 | #13669 | Link |
yes if you can accept less optimal bitrate distribution.
1st July 2015, 22:39 | #13670 | Link |
I can not create AVCHD discs because Ripbot264 is stopping at the end of the first pass in this latest version. This is happening in my two pc.
Edit: I test using another source but this source has been converted without problems in the CQ mode. Last edited by soneca; 1st July 2015 at 22:52. |
2nd July 2015, 02:37 | #13672 | Link |
I searched first but this is such a long thread it may have been answered but I can't find it. Anyway, how do you use a DTS track in the new versions of Ripbot? Just started doing some encoding again and I remember a couple years ago if I did COPY STREAM I'd get the actual DTS track in my mkv. Now, no matter what I do, loading the MT2S, or muxing the DTS track out and loading it separately, it's converted to FLAC ("converting DTS-MA to FLAC"), and that seems like the highest audio I can get.
Am I missing something, how do you get an untouched DTS track in the encode? Last edited by essential; 2nd July 2015 at 02:39. |
2nd July 2015, 04:47 | #13674 | Link | |
Are you having issues with v.1.18.3?
2nd July 2015, 06:22 | #13675 | Link | |
Edit: DTS/Core selection worked when loading in the MT2S, but doesn't work when loading in the .DTS file directly, that is converted to FLAC automatically, not sure why, but thanks, I'll just work from the MT2S. Also, has AC3 640 been removed? The highest AC3 stream selectable now (MT2S or .dts) seems to be 256? Last edited by essential; 2nd July 2015 at 07:41. |
2nd July 2015, 09:42 | #13676 | Link | |
2nd July 2015, 10:51 | #13677 | Link |
ABR in first pass is not very accurate in estimating chunk's complexity. I tried that before using cq mode.
@soneca When first pass hangs run process explorer and do screenshot. I need to see what processes started by ripbot264.exe are still running.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd July 2015 at 11:38. |
2nd July 2015, 13:15 | #13680 | Link |
Run manually job6_EncodeAudio1.cmd and show me what you get.
