20th December 2017, 22:50 | #47863 | Link | |
Do I disable "Enable automatic fullscreen exclusive mode" ? |
20th December 2017, 23:01 | #47864 | Link |
Yes, the newest madVR also defaults to FSE disabled.
madVR options explained |
20th December 2017, 23:31 | #47867 | Link |
It is not even required for 10-bit anymore, if you are using DX11.
Edit: updated my options explained post, that info was out of date. Does anyone know if you still need FSE for 10-bit in Windows 7/8?
madVR options explained Last edited by Asmodian; 20th December 2017 at 23:33. |
21st December 2017, 02:46 | #47869 | Link |
A (stupid) question: my external DAC provides only 1080p HDMI output, so if in the future I'll want to reach a 2K or 4K display I should use both the two HDMI output from the graphic card (one for video to the display, the other for audio to the DAC), but in this case I'll lost the Exclusive mode of madVR, am I right? Do exist a way to avoid it?
Best Regards! Leo! |
21st December 2017, 02:58 | #47870 | Link |
That would not change anything with regards to madVR, madVR does not care what the audio is doing.
21st December 2017, 03:12 | #47871 | Link |
Thanks Asmodian, but as far as I know madVR works better in Exclusive mode than otherwise, or not?
I've also found out that, depending if I'm using duplicate or extended desktop output, the driver set the RX480 in different way: in duplicate mode Windows loose the DAC (says "not connected) because the driver feels that the projector isn't an audio device; in extended mode the DAC becomes the main device and I loose the PJ abilities, like HDR or 2/4K...
Best Regards! Leo! Last edited by YGPMOLE; 21st December 2017 at 03:31. |
21st December 2017, 04:02 | #47873 | Link |
Due to both exclusive mode getting worse and windowed mode getting better in Windows 10.
21st December 2017, 09:33 | #47874 | Link | |
yes, you need FSE on Win8 for 10bit, and it only works with new path not the old path using dx9, and using dx10.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
21st December 2017, 10:27 | #47875 | Link |
For some reason I don't have the white dots anymore even with compression disabled...
Not sure where the issue came from... so many weird issues. EDIT : ha nope, they are back https://imgur.com/aIdtLu9 Anyone knows what the issue causing this thing ? it worked fine SOMEHOW and I didn't change anything. Setting the Black Level from LOW to HIGH make the white dots disappear but ruins the picture . Setting in MadVR black level instead 0-255 to 16-235 fix the issue also but also ruins the picture... so it's something with MadVR can't show properly HDR. Or maybe it's just the compression of the movies ? but how come no one see them too.. maybe no one is using MadVR and using 16-235 ? or Black Level High ? because there is no other way. In movie Fifty.Shades.Darker.2017 I don't have white dots at all. so could this be the movies specifically ? Last edited by x7007; 21st December 2017 at 11:34. |
21st December 2017, 12:26 | #47877 | Link | |
21st December 2017, 13:07 | #47878 | Link | |
ok, lets go through a process of elimination, start by providing some details about your setup. Windows version: Windows desktop resolution: Pixel: eg, 4:4:4 Full rgb or 4:2:0 YBCR TV details, 4k? HDMI cable speed, 18gbps? Madvr colour space setting, 16-235 or 0-255 Graphics card model: Graphics card dynamic range setting: do you use a receiver or is the PC connected direct to the TV? Do you have a 4k bluray player, does it do the same thing using the same cable and HDMI port? |
21st December 2017, 15:05 | #47880 | Link |
Hi ,Thank you for all developers madVR
My device Intel - NUC6CAYH - Windows 10 64b I made all the recommended Settings in (NUC + MPC-HC + madVR) i Follow guide in (AVSForum) But I have a problem When you open a movie Small screen madVR working Good But when you show the Full screen The image is abnormal I fell Like too too much Judder look at this https://www.dropbox.com/s/poel13lspo...D9%A5.mp4?dl=0 This problem appears when used madVR When using the default Filter , No problems . Last edited by KaBoS; 21st December 2017 at 15:08. |
