Old 26th March 2008, 11:30   #4001  |  Link
Thunderbolt8
That's bad. My MPEG2 handling module explicitly disallows changes from interlaced to progressive. But if D-Theater actually uses that, I might have no choice than to support it. This has nothing to do with the new TS/M2TS support, though. It's a limitation of my MPEG2 code.
ive had this for quite some mpeg2 sources now (non d-theater), so apparently it does not only happen quite rarely. would be nice if eac3to could be used for those as well.
Thunderbolt8 is offline
Old 26th March 2008, 12:40   #4002  |  Link
Zelos
i remuxed my 1st bluray with eac3to and it works fine .
Great job , and thanks Madshi !
Did eac3to apply audio delay with bluray file ?
Zelos is offline
Old 26th March 2008, 13:30   #4003  |  Link
vwpassion
@Madshi
How long do you think until there is a version that "officially" supports m2ts joining? I have a major issue with a title that requires joining of about 40 segments and which includes a TrueHD track. No matter what I do (copy /b, tssplitter join -> tsremux, etc) the audio seems to be borked and doesnt stay in sync with the video. Xport and eac3to report discontinuity issues as well.
We *really* need proper m2ts joining support within eac3to!
vwpassion is offline
Old 26th March 2008, 13:36   #4004  |  Link
madshi
If it is necessary - yes. However, I've not seen a Blu-Ray title where it was necessary as of yet.
Patience, young Padawan, patience! The first eac3to version with m2ts support is just 2 days old. Code doesn't grow on trees.
madshi is offline
Old 26th March 2008, 14:00   #4005  |  Link
Zelos
perhaps i ask a lot , but will you plan to support subtitle stream ?
Zelos is offline
Old 26th March 2008, 14:05   #4006  |  Link
madshi
Maybe?
madshi is offline
Old 26th March 2008, 14:08   #4007  |  Link
Zelos
btw , did you stop the developement of h264tsto ?
i used it to mux a m2ts file on to a matroska container.
Eac3to , now offer more options included the audio.
Zelos is offline
Old 26th March 2008, 14:44   #4008  |  Link
madshi
h264tsto was never meant to do anything more than just automating some DirectShow filters. h264tsto never did any real work on its own. It just connected some DirectShow filters and that's it. As such there's not much that I can do to improve h264tsto. It does what it does well, and the limitations are dictated by the DirectShow filters (which are written by other people).
eac3to is a totally different thing. It does a lot of stuff on its own and only uses external software (DirectShow filters, dlls, exes) when absolutely necessary. In eac3to I've replaced several DirectShow filters which didn't work well enough (for my taste) with self written code.
madshi is offline
Old 26th March 2008, 15:47   #4009  |  Link
buzzqw
HDConvertToX author
so we can aspect to see all h264tsto in eac3to .. soon (or later) ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 26th March 2008, 15:57   #4010  |  Link
shambles
until madshi tackles the multiple-m2ts titles, demuxing truehd from each m2ts separately and converting each of them separately to wav/pcm and then joining them should get you a synced track.
shambles is offline
Old 26th March 2008, 16:02   #4011  |  Link
madshi
Don't know. Maybe? I usually don't plan that far into the future, especially not with hobby projects. I'm usually just checking what needs to be done next and then look from there...
madshi is offline
Old 26th March 2008, 16:10   #4012  |  Link
buzzqw
HDConvertToX author
ok, i fully agree.. since i am hobby programmer too (even if i usually do change faster than i suppose to do... )
BHH
buzzqw is offline
Old 26th March 2008, 16:10   #4013  |  Link
vwpassion
Actually that's exactly what I did: I demuxed the True-HD track seperately from each m2ts using xport, and then converted to ac3 with eac3to. In the end I joined the ac3 segments, but still the track is borked and goes out of sync in a few scenes, apparently the track doesnt go out of sync progressively. It randomly goes out of sync on some scenes, and basically this can't be fixed by adding a delay or through stretching.
Should I rather convert the demuxed True-HD segments to WAV and then join them, and then covert them to AC3?
Old 26th March 2008, 20:21   #4014  |  Link
shambles
yes, to wav, then join, then to ac3. you should be getting progressive desync with wavs -> ac3s -> join though so don't know if joining before encoding to ac3 will help either
shambles is offline
Old 26th March 2008, 20:47   #4015  |  Link
vwpassion
Which program is recommended to join .wav's?
Old 26th March 2008, 21:10   #4016  |  Link
shambles
wavewizard
shambles is offline
Old 26th March 2008, 22:08   #4017  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Feature Requet:
Madshi have you thought about adding an option for "continue to next .evo" like the one in EVOdemux? This would also be very nice once m2ts joining is implemented since there seem to be some BD titles with many .m2ts files.
I have an .m2ts file from Mr' Magorium's Wonder Emporium that makes eac3to crash. There is the chance that I'm not doing something right in preparing the file to be fed to eac3to, I'm not sure, this is my first attempt at BD. The .m2ts plays in fine in MPC with the exception of an issue seen below. How can I chop out a piece to post for inspection?
Is this what people mean by rainbow frames?
This problem seems to be only at the very end of the movie during the credits.
saint-francis is offline
Old 26th March 2008, 22:08   #4018  |  Link
Rectal Prolapse
That won't work because audio can overlap from one segment to the next. In other words, some m2ts streams will have extra audio at the end (past the last video frame), and other streams will also have extra audio at the beginning (before the first video frame).
You would need to slice off the extra audio in WAV format before joining them to maintain sync!
Rectal Prolapse is offline
Old 26th March 2008, 22:18   #4019  |  Link
vwpassion
How can I slice off the extra audio? And how do I know which tracks need slicing off?
Old 26th March 2008, 22:34   #4020  |  Link
Rectal Prolapse
vwpassion, it depends - every soundtrack may have a different slice point (ie. PCM can be off by up to 5 milliseconds, while AC3 can be off by as much as 32 millliseconds).
You would need to use a WAV editor like Adobe Audition or Audacity to check the WAVs. You would load the WAV file from one segment, then load the WAV file from the next segment, then use your eyeballs to determine the overlap point, and cut one of them so that there is no more overlap.
eac3to
