28th April 2019, 17:36 | #8822 | Link |
Hi
I have a question about MeGUI's File Indexer. In case of indexing vob files in segment all file are recognised by DGIndex in the directory and the result is one output. When I wish to index mp4 files in segment by FFMSIndex only one file are indexed the others are not recognised. They are named following mode: VID_20190423_163806_0004.MP4 VID_20190423_164733_0005.MP4 VID_20190423_165640_0006.MP4 VID_20190423_170529_0007.MP4 VID_20190423_171459_0008.MP4 VID_20190423_172453_0009.MP4 VID_20190423_173346_0010.MP4 In file explorer only one can be selected. How can I force File Indexer to recognise the all others and handle as one? Regards szabi |
29th April 2019, 12:41 | #8823 | Link | |
Probably the easiest solution is to open the first MP4 with MKVToolNix, append the rest, save the output as a single MKV and index that. |
1st May 2019, 16:33 | #8824 | Link |
I'm having an issue similar to one reported here: http://forum.doom9.net/showthread.ph...13#post1832213.
Essentially, the ColorMatrix plugin causes the Status Violation error when running in the x64 version while everything runs cleanly in the x32 version. Last edited by AGiLiT; 1st May 2019 at 16:37. |
2nd May 2019, 20:17 | #8825 | Link | |
That is wanted to avoid. Merge them all duplicate the size needed on hard drive. If I make index one by one I can merge them by avisynth script. They are 7 files presently but would more sophisticated to do it by one step. Even if there are much more than 7 makes less and less comfortable. |
3rd May 2019, 10:57 | #8826 | Link |
The main problem is, with sequential vob files the video and audio is continuous. That's why they can be indexed as a single file. There's no guarantee that'll be the case for MP4s though, or that the audio and video in each MP4 would be the same length.
Even if you appended them as a single MKV and encoded the video in one go you might still have problems, although after encoding, if you opened the encoded video with MKVToolNixGUI, added the original MKV, de-selected the original video and remuxed, there's some chance the audio and video would still be in sync, although if the audio in any of the MP4s happened to be longer than the video, that probably wouldn't work either. |
8th May 2019, 13:42 | #8827 | Link |
Hello,
i'm using megui with a registered dgindexnv for quite some time now for encoding my tv recordings which worked quite fine. I recently reinstalled windows and megui updated dgindexnv to the latest version, which doesn't put a DELAY Value in the audio file filename anymore therefore i get async mkvs in the end. They say it wasn't reliable and removed it, though it worked fine for me. I can't register in their forum, so i think i should ask here. Is there any way you can force the new dgindexnv to put the value back in the filename? or where can i get the value from now? Any help would be appreciated. |
15th May 2019, 15:49 | #8830 | Link |
Hello. I recently updated my MeGUI from Version 2855 with SEt's AviSynth MT to the latest version of MeGUI with pinterf's AviSynth+. As I was checking some test clips, I noticed that very rarely there's an error message from, I think, AviSynth+ superimposed across the top, center of single frames. Here are two examples: S1.E1-Simpsons[NTSC]-AviSynth+ErrorMessages. Is there any way to stop this happening (other than not creating script errors )? I realize this technically isn't an MeGUI issue, but the last question I asked in the AviSynth+ thread has gone unanswered so I thought I'd ask here. Thanks in advance for any help.
15th May 2019, 21:31 | #8833 | Link |
In case you're asking me, the script is:
SOURCE INFORMATION HERE ### Deinterlace-Match Fields-Decimate ### Function FieldMatch(Clip C) { Global PP = C.DuplicateFrame(0) Global CC = C Global NN = C.DeleteFrame(0) P2 = PP.SeparateFields() C2 = CC.SeparateFields() N2 = NN.SeparateFields() Global PC = Interleave(P2.SelectEven(),C2.SelectOdd()).Weave() Global CP = Interleave(C2.SelectEven(),P2.SelectOdd()).Weave() Global CN = Interleave(C2.SelectEven(),N2.SelectOdd()).Weave() Global NC = Interleave(N2.SelectEven(),C2.SelectOdd()).Weave() Global Deint = QTGMC(CC).SelectEven() Return ScriptClip(CC, \ "!CC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CC : " + \ "!NN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NN : " + \ "!CN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CN : " + \ "!NC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NC : " + \ "!PP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PP : " + \ "!CP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CP : " + \ "!PC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PC : Deint") } TFM(Order=-1,Mode=5,PP=2,Clip2=FieldMatch(),Slow=2,MChroma=False,Ubsco=False,CThresh=12,Chroma=True) TDecimate(Mode=1) ### Fix Line-Doubled Fields ### NNEDI3(Field=-2) Merge(SelectEven(),SelectOdd()) ### Color Conversion ### ColorMatrix(Mode="Rec.601->Rec.709") ### Adjust Color ### MergeChroma(aWarpSharp2(Depth=16)) ### Crop ### Crop(8,0,-8,0) ### Gibbs Noise Block ### Edge=MT_Edge("prewitt",ThY1=20,ThY2=40).RemoveGrain(17) Mask=MT_Logic(Edge.MT_Expand().MT_Expand().MT_Expand().MT_Expand(),Edge.MT_Inflate().MT_Inpand(),"xor").Blur(1.0) MT_Merge(Minblur(),Mask,Luma=True) ### Resize ### NNEDI3_RPow2(4,CShift="Spline64Resize",FWidth=960,FHeight=720) aWarpSharp2(Depth=5) Sharpen(0.2) ### Overall Temporal Denoise ### SMDegrain(TR=3,ThSAD=600,ContraSharp=True,RefineMotion=True,Plane=0,PreFilter=2,Chroma=False,LSB=True,LSB_Out=True) ### Darken-Thin Lines ### F=DitherPost(Mode=-1) S=F.FastLineDarkenMod(Strength=24,Prot=6).aWarpSharp2(Blur=4,Type=1,Depth=8,Chroma=2) D=MT_MakeDiff(S,F).Dither_Convert_8_To_16() Dither_Add16(Last,D,Dif=True,U=2,V=2) ### Deband ### F3KDB(Y=100,Cb=100,Cr=100,GrainY=1,GrainC=1,Input_Mode=1,Output_Depth=16) ## Trim() # SelectRangeEvery(1000,66) ConvertFromStacked.ConvertBits(10,Dither=0) Prefetch(3) Code:
Script error: Invalid arguments to function 'IsCombedTIVTC' ([ScriptClip], line 1) Last edited by LouieChuckyMerry; 15th May 2019 at 21:32. Reason: Syntax |
16th May 2019, 07:25 | #8836 | Link |
I wonder if this issue is better addressed to AviSynth+ developers to check the parser handling complex "eval" function parameters across several lines. Maybe point pinterf at this post.
16th May 2019, 16:45 | #8838 | Link |
LouieChuckyMerry,
Which Minblur() are you using ? (the one on wiki requires at least one Int arg [ function MinBlur(clip clp, int r, int "uv") ] You cannot just make the error go away, the error causing it must be fixed. Also, best if you link to your script in Avisynth devs forum post. (I dont see anything wrong in the FieldMatch function). Here a mod of the FieldMatch function, maybe it makes problem go away [Removes Globals, requires Grunt]. Code:
Function FieldMatch(Clip c) { PP = c.DuplicateFrame(0) CC = c NN = c.DeleteFrame(0) P2 = PP.SeparateFields C2 = CC.SeparateFields N2 = NN.SeparateFields PC = Interleave(P2.SelectEven,C2.SelectOdd).Weave CP = Interleave(C2.SelectEven,P2.SelectOdd).Weave CN = Interleave(C2.SelectEven,N2.SelectOdd).Weave NC = Interleave(N2.SelectEven,C2.SelectOdd).Weave Deint = CC.QTGMC.SelectEven SSS=""" \ !CC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CC \ : !NN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NN \ : !CN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CN \ : !NC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NC \ : !PP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PP \ : !CP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CP \ : !PC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PC \ : Deint """ Args="CC,NN,CN,NC,PP,CP,PC,Deint" Return CC.GScriptClip(SSS,Args=Args,Local=True) }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th May 2019 at 16:47. |
16th May 2019, 23:42 | #8839 | Link |
Thanks for the mental push, StainlessS (I hope you're not offended, but every time I read one of your posts I hear John DiMaggio's voice as Bender in Futurama, a combination of your avatar and signature). As I was editing a copy of the original script to test your modification, I realized the only real change I'd made to the original script, a script that worked just fine some years ago, was to add "PreFetch(3)" to the end. While searching how to upgrade from SEt's AviSynth MT to pinterf's AviSynth+ I decided that starting a script with "SetFilterMTMode("Default_MT_Mode",2)" and ending with PreFetch(X) was a bad idea for interlaced video; however, I accidentally learned that adding "PreFetch(X)" to the end of a script for interlaced video improved the encoding speed. Long story short, a couple tests later and the cause of the AviSynth+ error message was "PreFetch(X)" at the end of the script. I guess the moral is Don't MultiThread Interlaced Video No Matter Which Version Of AviSynth You Use. I'll now hustle over to the AviSynth+ thread with this knowledge, thanks again for your help .
17th May 2019, 14:43 | #8840 | Link |
Glad you got it sorted, but might be a good idea just the same to use the FiledMatch without Globals (globals could have been cause, QTGMC uses Globals I think, and maybe
other scripts functions, if they used same global var name then can interfere with each other and be cause of the 'Invalid arguments' if interfering globals were of wrong type).
megui |
