13th November 2004, 11:13 | #22 | Link |
@clickit & Peter1234,
I just tried Nuenc 0.01 this morning, and it worked. It might be because I disable "Extreme & High Quality seetings" in QuEnc 0.56 (guessing) - so perhaps uncheck all settings in QuEnc and then try to load NuEnc again? |
13th November 2004, 11:20 | #24 | Link |
Just a Member
I don't think that would be a problem. I'll separate the registry entries though just in case for next release, which will have to be soon since there seems to be a few bugs.
EDIT: Download problems are because of host.sk. They haven't been reliable for a while now. I've intended to move hosts, but couldn't find any decent ones. Use a download manager. Last edited by Peter Cheat; 13th November 2004 at 11:25. |
13th November 2004, 11:48 | #27 | Link |
High beam
Any error message.
It opens a new window with <encoding> and <statistics> but it remains blank. The encoder don't start. Peter, why the new libavcodec is so small (312ko)? Last edited by freelock7; 13th November 2004 at 11:58. |
13th November 2004, 12:17 | #28 | Link |
Just a Member
The reason it is so small is because I've removed MPEG-4 specific code (and code relating to other codecs). This is just to save bandwidth and to make it easier to download. If its larger than ~700KB, the download seems to dropout all the time.
Technically it would also make it faster, but saving ~100 cycles per frame is not going to make a difference on a machine that does 1,500,000,000 cycles per second I can't figure out why it doesn't work. Try a different source maybe, and see if that works. I can't see how it can freeze with the encoding window without an error, and without starting. |
13th November 2004, 13:08 | #32 | Link |
Just a Member
That is unlikely. I did remove a lot of code, sure. But 90% was related to QPEL and GMC. The rest was audio codecs, and video codecs like mpeg4, snow, cinepak etc. All code relating to MPEG1&2 were left alone. If I wasn't sure, I also left it. Others are not having problems so I doubt its a problem with the DLL. I know the GUI is a little bit dodgy, and just realised that if you minimise the window while encoding, then maximise it sometime later, the encoding stats might disappear. This will be fixed now. I'll have to release a new version tomorrow with all these fixes
EDIT: I won't change back to NuEnc 0.00d DLL, I've fixed all the bugs that were found in it. I could recompile without removing any redundant code, but the only difference will be that it's twice as big. Last edited by Peter Cheat; 13th November 2004 at 13:16. |
13th November 2004, 16:45 | #34 | Link |
HDConvertToX author
look at this
http://www.64k.it/andres/Immagine.png after a while (sometimes never) it display something but fps is like 0.14 per sec... (p4 2.8ghz) great appz btw ! BHH after a while EDIT: http://www.64k.it/andres/post.png I have just clicked on setting.reg launch a conversion Isn't strange "peak bitrate" ? Last edited by buzzqw; 13th November 2004 at 16:57. |
13th November 2004, 18:14 | #35 | Link |
Peter Cheat,
After loading your settings the program starts. When I load an avs file and click the Encode button with your settings, the encode window opens up but encoding does not start. Encode window has no statistics and there is an empty box on it. Debug.log is empty. |
14th November 2004, 11:45 | #36 | Link |
Just a Member
I've now fixed GUI problems in NuEnc 0.01a. It should start up correctly.
There are 2 versions. A small one with most codecs removed and a large one without anything removed. If you have a P4, the large one should work. I may have deleted P4 specific code when removing unused codecs . CQ Mode is now also linear (CQ 50 produces files about half the size of CQ 100). |
14th November 2004, 12:15 | #38 | Link |
Just a Member
I have a feeling that the encoding window is doing something weird. Try to encode, then press CTRL-ALT-DEL, click on the processes tab and see how much CPU NuEnc.exe is using. If its ~99% then its stuck in an endlesss loop somewhere...
