Old 27th September 2018, 13:11   #341  |  Link
richy
Hi Nalor,
I've just sent you a couple of log files from 1.10 and 1.17 which will hopefully show you what I was on about regarding incorrect values being found via DVDFab on all more recent versions of FindVUK.
Rich
richy is offline   Reply With Quote
Old 27th September 2018, 21:39   #342  |  Link
nalor
Will check tomorrow in Detail.
Originally Posted by richy View Post
Hi Nalor,
Rich
Gesendet von meinem SM-T800 mit Tapatalk
nalor is offline   Reply With Quote
Old 11th October 2018, 20:39   #343  |  Link
nalor
Released 1.18 - fixes the problems reported by @richy
Old 20th October 2018, 21:55   #344  |  Link
nalor
Released 1.19 - fixes a problem I've noticed myself and another one reported by @Zattica
Old 20th October 2018, 21:58   #345  |  Link
nalor
@Nalor: How often is the online database updated? I've submitted a few discs earlier this week and also tried the sync function with an older entry that's in my own keydb.cfg but not the online one but the online database doesn't seem to have altered at all. I know other discs I've submitted in the past are in there but I just wanted to check that my recent submissions are working as expected. I've not had any error messages that I'm aware of.
Hi - at least the processing of new entries uploaded with FindVUK is working again - so you should find your submissions in the database now
Old 20th October 2018, 23:28   #346  |  Link
richy
Good stuff! However, I'm going to pain now and ask more questions!
I've just tried a sync with 1.19 and noticed that the overall number of titles in my keydb.cfg actually went down, despite some new titles being added. The keydb.cfg file I used when I did the sync was one I downloaded by doing a sync with no keydb.cfg present a few weeks back.
Basically, I've got two queries:
(1) Entries have been completely removed.
These are the first couple I came across when doing a before/after sync comparison:
0x7EE8EFA91EDD5B5934922EF95612E509AE4A573F = TRON (Tron - Blu-ray™)...
0xC57A772D19F81FE96B6450554BE8BD26E5FDE15A = PREDATOR_WW (Predator)...
I've trimmed the rest of the lines above but the information that was there before certainly looked ok. Would they have been removed because the data didn't verify properly or was there some other reason?
(2) Entries that have been trimmed.
I also noticed that some entries that had what I'd call a complete set of data before have now been trimmed down a lot. Again, would this be because some of the information was proven to be incorrect or, again, is there some other reason?
The first one I spotted it on was towards the end of the sync and you can see that there was a lot of info before when submitted via 1.07 but to me it looks like 1.17 just erased pretty much all of it bar the Unit Key, which was one issue I was having before you fixed the problem with 1.18. Is that maybe why?
0xC5462B34EB7557FB5A1FD091ED1FA3C7AC5A089E = BAND OF BROTHERS DISC 4 | D | 2008-09-18 | V | 0xC20F2E53042D15E366B3881C447A6217 | M | 0x8F4541FBAEEB3B636178F8208DB9E003 | I | 0xE3A876E741D375DE0BA3ADACAD8DA061 | U | 1-0x3B654AAD9F8AEBE08A8DC6AF53351CBA ; MKBv9/FindVUK 1.07 - MainPlaylist: 00000.mpls - VolumeSize: 39692075008
0xC5462B34EB7557FB5A1FD091ED1FA3C7AC5A089E = BAND OF BROTHERS DISC 4 | D | 2008-09-18 | U | 1-0x3B654AAD9F8AEBE08A8DC6AF53351CBA ; MKBv9/FindVUK 1.17 (BD)
Old 21st October 2018, 21:39   #347  |  Link
nalor
Hi! Thanks for your report!
About 1) - checked the entries you've reported - but in my case they're still available after the sync? Can you check if those entries are really missing in the keydb-file?
About 2) you're right - introduced a bug into the procedure to check if additional data should be added to an existing entry ... will correct it tomorrow and restore the missing data.
Old 21st October 2018, 22:06   #348  |  Link
richy
I may have got my various different keydb.cfg files a bit mixed up when testing but doing a sync from scratch (i.e. no file named "keydb.cfg" in the aacs folder) gets me 28049 entries and the two I mentioned are definitely missing (along with quite a few others).
If I put my previous keydb.cfg back and do another sync, nothing changes from yesterday's sync that I did but the missing entries are included - in other words, they're not actually being removed, they just don't seem to show up if they weren't already there.... if that makes sense? As far as I can tell, I end up with a total of 28229 entries after this second sync (I started with 28191 before the sync).
Old 24th October 2018, 12:40   #349  |  Link
nalor
Please try again - I've fixed the bugs during processing and now the data should be complete again ...
(currently I only include entries that either have a MediaKey, VolumeId, VolumeUniqueKey or UnitKey(s) )
Old 24th October 2018, 13:42   #350  |  Link
richy
I've just done a complete download from scratch again and having a quick look it appears that the ones that were missing before seem to be back again. Also, I noticed that a load of discs I'd submitted over the last few weeks also seem to have been added now (they never showed up before so I wasn't sure if the info was being submitted correctly) so it certainly seems to be working fine as far as I can tell
Old 14th November 2018, 19:03   #351  |  Link
sarre
Just wanted to report that the 'PID' issue with procdump still exists in 1.19
"Dump 1 initiated: [..]\FindVUK\dump\1672CD54114191BA94D99E2A4A30A4E9D6F58CB9_S9960ER_MAN_3.dmp"
You can probably guess the title.
sarre is offline   Reply With Quote
Old 14th November 2018, 21:51   #352  |  Link
TTide
With the latest DVDFab x64 11.0.0.3 is able to find the vid / bdmv / Disc ID in the log file "Documents/DVDFAb11/dvdfab_internal.log".
The problem is it doesn't output the vuk yet it can play some blu-ray without it.
TTide is offline   Reply With Quote
Old 14th November 2018, 22:41   #353  |  Link
nalor
Thanks for reporting! Please try FindVUK 1.20 - should be fixed with it
Old 14th November 2018, 22:47   #354  |  Link
nalor
Please try again with FindVUK 1.20 - I've added support for DVDfab 11.x a week ago and didn't notice any problems so far (but as always - didn't test too much
Basically it's also working with FindVUK 1.19 - but it's necessary to specify the LogFile and the MainFile because it does not know how to detect it properly.
Now with FindVUK 1.20 it should work out of the box.
Old 15th November 2018, 23:42   #355  |  Link
sarre
Confirmed.
Old 17th November 2018, 11:58   #356  |  Link
nalor
Would be great if someone could send me the AACS folder of one of the following UHD discs:
BATMAN_V_SUPERMAN_UE
BLADE_RUNNER_THE_FINAL_CUT
DUNKIRK
INCEPTION
KING_ARTHUR_LEGEND_OF_SWORD
SUICIDE_SQUAD
SULLY
THE_ACCOUNTANT
WAR_DOGS
Those discs have 2 unitkeys and I noticed that my method to get the encrypted unitkeys is only working for the first one - but e.g. UnitKey 2 is uploaded as zeroes ....
<EncryptedValues>
<UnitKeysENC>
<UnitKey Nr="1">2A8DB639815C44A9954265F1B34BCFB3</UnitKey>
<UnitKey Nr="2">00000000000000000000000000000000</UnitKey>
</UnitKeysENC>
</EncryptedValues>
Need the aacs folder to understand what I'm doing wrong ...
Old 23rd November 2018, 22:43   #357  |  Link
nalor
Got a few AACS folders from UHD's from different people - managed to correct reading of encrypted UnitKeys from UHDs.
The structure of the files on AACS2 discs is a little bit different, hopefully my interpretation of the new structure is correct now
Released FindVUK 1.21, it contains some bugfixes.
Old 24th November 2018, 19:20   #358  |  Link
TTide
FindVUK 1.21 bugs
Can't run FindVUK: FindVUK 1.21 bugs.
C:\FindVUK_1.21\log\2018-11-24_FindVUK.txt
2018-11-24 17:51:38 # 0 # [I] main / (legacy) / #############################################################################
2018-11-24 17:51:38 # 97 # [I] main / (legacy) / ----------- FindVUK 1.21 -----------
2018-11-24 17:51:38 # 97 # [I] main / (legacy) / Operating System: Windows 10
2018-11-24 17:51:38 # 98 # [I] main / Settings_GetFilename(legacy) / SettingsFile: >C:\FindVUK_1.21\config\FindVUK.ini<
2018-11-24 17:51:38 # 98 # [I] main / Settings_CreateOrUpdate(legacy) / Settingsfile does not exist - create it with default values
2018-11-24 17:51:38 # 772 # [I] main / ConsoleBufferSize(legacy) / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-11-24 17:51:38 # 772 # [I] main / ConsoleBufferSize(legacy) / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-11-24 17:51:38 # 785 # [I] main / ConsoleBufferSize(legacy) / Max. ScreenSize 240 x 55
2018-11-24 17:51:38 # 785 # [I] main / ConsoleBufferSize(legacy) / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-11-24 17:51:38 # 785 # [I] main / ConsoleBufferSize(legacy) / M1 - New BufferSize 120 x 9001
2018-11-24 17:51:38 # 793 # [I] main / ConsoleBufferSize(legacy) / Mx2 - New ScreenSize 120 x 50
2018-11-24 17:51:38 # 801 # [I] main / BlurayMeta_CheckLanguage(legacy) / Please check if the following language is correct.
2018-11-24 17:51:40 # 2242 # [I] main / (legacy) / Open Main-KEYDB file: >C:\Users\gamer\AppData\Roaming\aacs\KEYDB.cfg<
2018-11-24 17:51:41 # 3192 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\gamer\AppData\Roaming\aacs\KEYDB.cfg< opened!
2018-11-24 17:51:41 # 3200 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\gamer\AppData\Roaming\aacs\KEYDB.cfg< in memory now
2018-11-24 17:51:43 # 4997 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >0BBFAAE132F557850E76F2CFC41A2C0EA36600A6<
2018-11-24 17:51:43 # 5150 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >55020D329F3F994623265FBDCAD93D90572EE6B2<
2018-11-24 17:51:43 # 5288 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >461D817C01E805BCE68506016F0091C4A66D81CE<
2018-11-24 17:51:43 # 5424 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >043D58001A95B96ABCD83370CD993908E572B5CB<
2018-11-24 17:51:43 # 5552 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >93C80CA53E2EE293C9268E1CFB8C35D5083E661B<
2018-11-24 17:51:43 # 5681 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >18B75086AA278D195B0D267F09E27DC776027A84<
2018-11-24 17:51:44 # 5813 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >E1DD32036B1D56FAD8D91CF94C0F4C06665A5965<
2018-11-24 17:51:44 # 5946 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >D53A13D83FAF40E536AF5E1E017FE19C341E3883<
2018-11-24 17:51:44 # 6089 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >9072028F338B1B839B93516EE933B3E18E436762<
2018-11-24 17:51:44 # 6234 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >C5BD514FCD1FF9A098E4D9D566387EDDCEC3F2BC<
2018-11-24 17:58:53 # 434897 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >FF1EB210D5BA8321AE1C3008FB957F043B961E46<
2018-11-24 17:58:53 # 435054 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >CB5132749C65FD9C9C997E708BDBF02B8D9EAB89<
2018-11-24 17:58:53 # 435167 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >9C3402B8C88307DDED4DA8FCD7144F1051A5BB01<
2018-11-24 17:58:53 # 435281 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >009BB39E1986116DD968F36B0255CCCFCF44F5A5<
2018-11-24 17:58:53 # 435490 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >1730D1D0560EA1FB9D69CCA98A2FE3F2242BBEAF<
2018-11-24 17:58:53 # 435691 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >A60282DD2B615318AE0095B60AE080DCA58D9DAC<
2018-11-24 17:58:54 # 435866 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >E0F91AD99A9DF02950727718E63CCDEA4B458639<
2018-11-24 17:58:54 # 435996 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >A8DCCAB89AE10FB3C2BBC379CAED730490F6FF7B<
2018-11-24 17:58:54 # 436131 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >8B454A41644FE6BF56B13A9C5E42D50B970EF5BB<
2018-11-24 17:58:54 # 436254 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >331B0EAF5E9DA3457E78DB46DF0AD35F21F157B0<
2018-11-24 17:58:54 # 436383 # [I] bluray_keydb / _DeleteDiscId / Delete >1< duplicate entries of discid >31AB865D191178E5F279338F5533CAE5F79D5D83<
Old 25th November 2018, 01:21   #359  |  Link
nalor
Please share your keydb.cfg file with me - I've really no idea what's going wrong in your case...
Old 25th November 2018, 01:22   #360  |  Link
nalor
Release FindVUK 1.22 - it includes another small fix:
FIX: set unitkey-status to 'untested' in case no validation has been possible
