6th January 2006, 17:19 | #1062 | Link |
Mr. Sandman
CVS update:
Made x264DialogTriStateAdjustment() to restore some of the default settings when switching profiles or enabling options that enables a group. It makes it crash without any message though... It doesnt let me debug too. Any ideas?
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th January 2006 at 17:27. |
6th January 2006, 18:20 | #1063 | Link |
Mr. Sandman
CVS update:
Reverted the previous changes Completed the code to enable/disable controls and labels in both tri-state and encoding mode
6th January 2006, 19:19 | #1064 | Link |
clueless n00b
Is it just me or has the tri state thingie probably not been done the way I specified? I recall writing something about using the same code just for different objects (GUI versus x264Settings).. but when I had a quick look the last time I worked on MeGUI, it sorta looked different and I found pieces of the adjustments in the actual x264 commandline generation as well (I already moved it.. please wait for my next major update). There should be one method doing all the adjustments.. based on the settings options are enabled/disabled and the counterpart in the commandlinegenerator class would do the same with removing/adding options to the commandline. I still think that ought to work just fine when you just make sure you have every case covered.
6th January 2006, 20:16 | #1065 | Link | |
BTW, it seems the "Fixed the "and close" checkbox in D2V Creator and LoadOnComplete control size" in 0.2.3.1031 took the 'and close' checkbox out of the d2v creator that pops up when someone selects an mpeg2 file in the avisynth creator, but not from the d2v creator that's produced directly from the menu selection. What was the rationale behind this? Unfortunately that broke the routing control I put in to allow the ability to load mpeg2 files directly in the avisynth creator (comments in the forums indicated that some were confused by the various options in the Tools menu so I put in some code to guide people through the process). |
6th January 2006, 22:00 | #1067 | Link | |
clueless n00b
So if in the GUI we have level X disabled a,b,c, then in the corresponding commandline method we have a = false, b = false, c = false.
6th January 2006, 22:28 | #1068 | Link | ||
6th January 2006, 22:42 | #1069 | Link | |
clueless n00b
Let's take an example: I8x8mv. The control is enabled when the profile is set to high profile, and disabled otherwise. However, if you go to high profile, check it, then go to main profile, it should remain checked, but just be disabled. So the x264Settings.i8x8mv variable would still evaluate to true when it gets to the commandlinegenerator. Then in the method x264TriStateAdjustment, it would have to be set to false. That similarity extends to a lot more. In the GUI method x264DialogTriStateAdjustment you enable/disable controls without checking their checked state or position in the dropdown.. in the x264TriStateAdjustment you set the booleans to true/false as needed. Thats why I keep saying the whole thing is basically the same.. the method in the GUI enables/disabled GUI fields, the one in the commandlinegenerator sets variables to true/false.
7th January 2006, 01:19 | #1070 | Link |
I've submitted a patch for the following:
add support for the -name tag in mp4box Description: N/A Status: godhead is working on it After talking with Doom9, I've implemented the feature using the :name=foo syntax that's been in older compiles of mp4box rather than the new -name switch. Also these are currently only applied to Video and Audio. Should these also be added to the Subtitles? Hope one of the admins can get these changes integrated soon, so the patch isn't reflected against an old CVS. Here's a quick list of changes MuxSettings.cs * Added VideoName property to hold the Video track name MuxWindos.cs * Added Label and Input controls for Video and Audio track names. * Added Event to handle audio track name changes. CommandLineGenerator.cs * Added more string concats for track names on generateMP4BoxCommandline() |
7th January 2006, 01:38 | #1072 | Link | |
http://msdn2.microsoft.com/en-us/library/d14azbfh.aspx
7th January 2006, 01:41 | #1073 | Link | |
7th January 2006, 01:53 | #1074 | Link | |
7th January 2006, 15:13 | #1076 | Link |
Mr. Sandman
Closed.
7th January 2006, 16:24 | #1077 | Link |
Mr. Sandman
CVS Update:
http://forum.doom9.org/showthread.ph...847#post763847 Some logic is still to be revised though. i'll do it tonight or tomorrow.
7th January 2006, 22:27 | #1079 | Link |
Mr. Sandman
well... coz i steel need to fix a couple of things.
however now the version number is up to date. http://files.x264.nl/?dir=./Sharktooth/megui/Sources
8th January 2006, 01:32 | #1080 | Link |
when distributing the binaries, you need to distribute the Data folder containing the ContextHelp.xml file aswell. Otherwise the tooltips are disabled. I'll grab a few bugs/feature requests and take a look at em tomorrow. I've been away the last few days.
development, megui, not a help thread |
