Old 21st December 2005, 22:05   #821  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
dunno... it should work (im actually using it).
Old 21st December 2005, 22:05   #822  |  Link
acidsex
ok, copied the libmmd.dll to besweet directory and tried again to no avail.
acidsex is offline   Reply With Quote
Old 21st December 2005, 22:09   #823  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
dunno... really.
it works here.
Old 21st December 2005, 22:10   #824  |  Link
acidsex
my nero dlls versions are AAC.dll v 3.0.0.7 and aacenc32.dll V.4.2.2.3
Old 21st December 2005, 22:14   #825  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
same versions here.
Old 21st December 2005, 22:15   #826  |  Link
acidsex
nope not beta. did a reimage of my laptop yesterday and those were the ones that were installed from the nero 7.0.1.4 package on the web.
Old 21st December 2005, 22:17   #827  |  Link
acidsex
Heres my log from MeGUI after I try to encode.
Next job job1 is an audio job. besweet commandline:
"C:\Documents and Settings\patrick\Desktop\megui\BeSweetv1.5b31\besweet.exe" -core( -input "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.ac3" -output "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.mp4" -logfile "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.besweet.log" ) -azid( -s stereo -c normal -L -3db ) -bsn( -2ch -vbr_streaming -codecquality_high -aacprofile_he ) -ota( -g max )
successfully set up audio encoder and callbacks for job job1
Log for job job1
besweet: "C:\Documents and Settings\patrick\Desktop\megui\BeSweetv1.5b31\besweet.exe" -core( -input "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.ac3" -output "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.mp4" -logfile "C:\DETROIT_ROCK_CI\VIDEO_TS\drc T02 2_0ch 192Kbps DELAY 0ms.besweet.log" ) -azid( -s stereo -c normal -L -3db ) -bsn( -2ch -vbr_streaming -codecquality_high -aacprofile_he ) -ota( -g max )
BeSweet v1.5b31 by DSPguru.
[00:00:00:000] Initializing...
[00:00:00:000] -- Initializing...
Old 21st December 2005, 22:17   #828  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
no... i was wrong...i have the same versions here.
however can you post the besweet commandline generated by MeGUI?
EDIT: d'oh!
Old 21st December 2005, 22:19   #829  |  Link
acidsex
Old 21st December 2005, 22:22   #830  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
seems to be good...
Old 21st December 2005, 22:24   #831  |  Link
acidsex
i thought so too but for some reason it just doesnt want to let me encode the audio using N7 audio. Again, if I throw the old N6 dlls back in there I can encode with them no problem.
Old 21st December 2005, 22:26   #832  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it has no sense... it's working here. and the support for nero dlls is not in MeGUI but in besweet + bsn.
i only added the commandline options for the new encoder.
it even works with belight...
Old 21st December 2005, 22:31   #833  |  Link
acidsex
this is driving me nutz. It has to be a besweet thing. I just loaded up BeLight and tried encoding ac3 to Nero AAC so unless BeLight doesnt support N7, then I have to have a BeSweet prob on my end.
Old 21st December 2005, 22:34   #834  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
get belight 0.22b8 full..
update it with the latest daily build...
place the nero dlls in the belight dir, check if encoding works with PS profiles for nero and if it works set megui to use the besweet.exe in that dir.
Old 21st December 2005, 22:42   #835  |  Link
acidsex
Nope didnt work. Updated it and tried running an encode again from Belight and as soon as I start processing I get a window that tells me Transcoding finished completely.
Old 21st December 2005, 22:45   #836  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
at this point i dont know what to tell... i can zip my belight directory and send it to you... that's the best i can do.
Old 21st December 2005, 22:49   #837  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
here it is: http://www.webalice.it/f.corriga/temp/BeLight.7z (use 7-zip 4.32)
Old 21st December 2005, 22:50   #838  |  Link
acidsex
Thank you very much. Ill give it a shot.
Old 21st December 2005, 22:52   #839  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
if it still doesnt work then you have a problem with your serials.
Old 21st December 2005, 22:54   #840  |  Link
acidsex
It didnt work. I guess Ill just go back to N6 dlls again. : Thansk for trying though.
development, megui, not a help thread
