Go Back   Doom9's Forum > Capturing and Editing Video > DV
Old 28th January 2005, 09:14   #1  |  Link
Dmitry Vergheles
Dmitry Vergheles's Avatar
The tool to trimm DV AVI type1,2
Solveig Multimedia AVI Trimmer is a freeware tool to enable a very fast trimming any necessary part of the source DV AVI file of any size without quality loss.
description:
http://www.solveigmm.com/?Products&p=AVITrimmer
download page:
http://www.solveigmm.com/files/Solve...r_1_0_beta.exe
The product thread on Elecard's forum:
http://www.moonlight.co.il/forum/viewtopic.php?t=458
Also there is SolveigMM AVI Trimmer Component that is an engine designed for nonlinear editing of AVI files, implemented as COM object based on Microsoft® DirectShow®. The component package has all necessary binaries, Developer Reference Manual and Visual C++ application sample code, that demonstrates an usage of SolveigMM AVI Trimmer Component.
description:
http://www.solveigmm.com/?Products&p=AVITrimmerCOM
download page:
http://www.solveigmm.com/files/Solve...t_1_0_beta.zip
http://www.moonlight.co.il/forum/viewforum.php?f=26
Regards,
Dmitry Vergeles
Solveig Multimedia - Video Editing Software
Dmitry Vergheles is offline   Reply With Quote
Old 28th January 2005, 18:13   #2  |  Link
bb
bb's Avatar
That sounds interesting. I have read the products page, but did not yet try the software. Do you - or does anybody else - have sufficient experience with the Solveig MM AVI Trimmer?
bb
bb is offline   Reply With Quote
Old 29th January 2005, 11:32   #3  |  Link
Dmitry Vergheles
Shure We had developed this
Regards,
Dmitry Vergeles
Old 29th January 2005, 21:20   #4  |  Link
bb
bb's Avatar
Nice
As soon as I find the time to test it, I'll probably add it to the "Links" sticky in this forum.
bb
Old 14th February 2005, 22:03   #5  |  Link
Valky
Valky's Avatar
Couple of things I would like to have:
1. Somekind of preview so that I dont have to use VD for this
2. Ability to cut some part from middle of the file
And both these are the things I need for my TV-captures that I have made with my DV-cam so that I could cut out the commercials
Valky is offline   Reply With Quote
Old 15th February 2005, 14:24   #6  |  Link
Dmitry Vergheles
Hello Valky,
First of all thank you for the interest in our software.
The preview featuare will be added in the nearest feature.
Do you just mean several DV parts instead of one part?
Or you mean deleting some part from input DV file?
Regards,
Dmitry Vergeles
Old 15th February 2005, 18:02   #7  |  Link
Valky
Valky's Avatar
Well, I mean things like commercials. There can be etc 2 short parts somewhere in the middle of my 60 min file that I want to cut out of my final file if you know what I mean?
Lets just say that I have a file that has two parts (commercials in example) that I dont wanna keep:
1. Now I have to first trim the first file from beginning of the file to the one frame before commersials (or any part that I dont wanna keep).
2. Then I have to trim the second file from first frame after the commercials to one frame before next commercial.
3. Then I have to trim the third file from beginning of the first frame after the commercial to the last frame of my file.
4. Then I have to join these three files to get the final file I wanna keep and compress or put back to my dv-tape.
If your software could do all this (cut unwanted parts) at one session, it would be perfect from my opinion
Old 16th February 2005, 08:29   #8  |  Link
Dmitry Vergheles
Hello Valky,
Thank you for the so detailed explanation
I have understood what you mean.
I think such feature will appear soon.
Do you need some more useful features? In reality for the futher timmer evolution we are trying to collect consumers feedback.
So we'll take into account all critical remarks!
Regards,
Dmitry Vergeles
Old 16th February 2005, 21:03   #9  |  Link
Valky
Valky's Avatar
Well if everything I mentioned above works without bugs,
then I dont need anything more
But we'll see...
Old 7th June 2005, 12:12   #10  |  Link
Dmitry Vergheles
AVI Trimmer Pugin for Elecard XMuxerPro
SolveigMM AVI Trimmer plugin for Elecard XMuxer Pro http://www.elecard.com/products/xmux_pro.shtml is available on http://solveigmm.com/?Downloads
Regards,
Dmitry Vergeles
Old 8th June 2005, 02:40   #11  |  Link
FredThompson
FredThompson's Avatar
You want traffic to your site from DV users? Create a proper freeware DV capture utility, especially one which works at the data packet level, not the Windows API level, so PAL can be read on NTSC devices and vice versa. There are 2 freeware DV capture utilities; WinDV and DVIO. WinDV does not capture large files and neither can properly handle DV tapes with unrecorded sections. DVIO has no viewing window and no control of the firewire device. Something like WinDV with the ability to capture until the end of the tape and low-level data packet reading would be nice.
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 9th June 2005, 06:04   #12  |  Link
Dmitry Vergheles
Hello Fred,
Thank you for the suggestition, we will certainly discuss your consideration.
Regards,
Dmitry Vergeles
Old 19th August 2005, 14:59   #13  |  Link
Dmitry Vergheles
SolveigMM Video Splitter 1.0 beta
Solveig Multimedia Video Splitter is a powerful tool to perform fast video trimming tasks without any quality loss. It has intuitive user-friendly interface and allows splitting a video file in few mouse clicks. Based on SolveigMM AVI Trimmer Component, SolveigMM Video Splitter is very fast (much more than real-time playback) since it’s free from encoding/decoding operations.
Solveig Multimedia is proud to introduce a new feature that makes video editing more comfortable and easy. Now it’s possible to define fragments in video file, turn them on or off and render final video in one pass.
SolveigMM Video Splitter features:
Based on SolveigMM AVI Trimmer Component (COM object)
Supports any AVI file format (DV type 1 and 2, OpenDML) with any video (DivX, XviD, 3ivX, etc.) and audio (MPEG-1, MPEG-2 layer 3, AC3, etc.) content.
Supports large AVI files (more than 2GB)
Allows trimming AVI files contained VBR audio without synchronization loss
Advanced K frame navigation
K frame accuracy
WYSIWYG preview
Allows multiple fragment processing in single pass
http://www.solveigmm.com/?Products&id=VideoSplitter
Regards,
Dmitry Vergeles
Old 8th September 2005, 07:02   #14  |  Link
Dmitry Vergheles
Review of SolveigMM Video Splitter
Review of SolveigMM Video Splitter by Marc Peters, Digital Director:
http://www.videoforums.co.uk/reviews...2_articleid/86
Regards,
Dmitry Vergeles
Old 9th September 2005, 16:09   #15  |  Link
Valky
Valky's Avatar
Seems to me that this is not freeware anymore, now that I finally wanted to try this?
Hmm..Seems to me that it does open and preview some of my dv-files, but not all of them. Is there some kind of time or filesize limit? They are all captured with the same ap and trimmed with virtualdub.
Old 12th September 2005, 08:00   #16  |  Link
Dmitry Vergheles
Hi Valky,
The beta version you have has some issues concerning DV.
Now we are preparing the release version where these troubles have been fixed. I hope it will appear within this week.
As for freeware, you right -Video Spliter is sharaware version of AVI Trimmer with GUI and advanced features. But in the nearest future we'll update our freeware trimmer with features of the Splitter (preview and multi-fragment processing) since both of them are based on our AVI Trimmer Component.
Regards,
Dmitry Vergeles
Old 24th September 2005, 12:30   #17  |  Link
Dmitry Vergheles
SolveigMM Video Splitter 1.0 Release
SolveigMM Video Splitter 1.0 Release is available.
Enhanced:
- An input AVI file Drug and Drop feature has been added
Fixes:
- K frame navigation has been improved
- DV AVI type 1,2 preview has been added
- The bug when an initial output file was overwritten during a second trimming operation has been fixed.
- WYSIWYG feature ( i.e. precision ) has been improved
- Some issues with out of sync on some kind of AVI files have been fixed
Changes:
- An ability to register the version has been added
- An ability to view the filters info has been added
Regards,
Dmitry Vergeles
Old 3rd November 2005, 07:11   #18  |  Link
Dmitry Vergheles
SolveigMM Video Splitter 1.0.2.1 Release is available
Fixes:
- The bug with messed control colors when Video Card bit depth is 24 or 8 bits has been fixed.
Changes:
- To avoid registration problems with COM components the following system DLLs have been added to installation: atl71.dll, msvcp71.dll, msvcr71.dll
Regards,
Dmitry Vergeles
Old 28th December 2005, 17:27   #19  |  Link
Dmitry Vergheles
SolveigMM Video Splitter 1.0.3.13 Release is available
Enhanced:
- A feature of getting output AVI file size has been added
Regards,
Dmitry Vergeles
Old 18th January 2006, 16:15   #20  |  Link
Dmitry Vergheles
SolveigMM AVI Trimmer 1.1 is out
A feature of visual control and preview has been added
Regards,
Dmitry Vergeles
