Old 2nd January 2008, 18:35   #401  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I think I have AC3Filter installed, is there some kind of setting I need to change.
Disable DTS decoder in FFDshow Audio
Old 2nd January 2008, 18:48   #402  |  Link
Atak_Snajpera
I mean at the end of the ecoding using the mkv extension there is no file at all, but if I select the mp4 extension there is a file at the end. Just don't know why mkv doesn't work.
You are using limited account therefore mkvmerge cannot save on C:\ . Save on desktop instead or in another partition.
Old 2nd January 2008, 19:16   #403  |  Link
mikenadia
I have an 5.5G Ipod and cannot import from itunes to ipod a file with level 3.0 (I used the IPOD 1.3 profile and edited the level number )
I can import the same file with the IPOD1.3 profile but my res is limited to 320x240).
I can do it with Videora (level 3.0 and res of 640x480 ) and wanted to know if it was related to http://www.redkawa.com/blog/post.php?t=3820
Videora is using FFmpeg with x264.
I cannot import also successfully with megui.
Thx.
mikenadia is offline   Reply With Quote
Old 2nd January 2008, 19:34   #404  |  Link
--PlayStation3--
Posts: n/a
Alright, it's disabled. So I should convert the video again the same I did last time and it should work?
Thanks for all your help.
Old 2nd January 2008, 19:36   #405  |  Link
Atak_Snajpera
mikenadia
Did you try floola instead of iTunes?
http://www.floola.com/
Yes if you will see 6 channels in RipBot
Old 2nd January 2008, 19:46   #406  |  Link
--PlayStation3--
Posts: n/a
mikenadia
Awesome, thanks a lot.
Your program is the only program that I've found that converts HD .mkv files without a hitch!
Old 2nd January 2008, 19:56   #407  |  Link
DJ_Price
I was saving to my desktop. I have full admin rights on my computer.
DJ_Price is offline   Reply With Quote
Old 2nd January 2008, 20:06   #408  |  Link
Atak_Snajpera
Once RipBot finishes task try to find ripbot264tmp directory.
Inside Jobx directory you should see four .cmd files. Open jobx_MuxFiles.cmd in notepad and add pause. Save.
Before executing jobx_MuxFiles.cmd make sure that video.264 and audio.aac is present in RipBot264tmp directory.
I need to know what mkvmerge says. (make a sreenshot)
Old 2nd January 2008, 20:40   #409  |  Link
DJ_Price
No need now as for whatever reason it has just worked, strange. I haven't done anything since when I tried it yesterday. Thank you for your input If I get any problems again I will let you know. Thanks for making such a great x264 encoder
Old 3rd January 2008, 01:21   #410  |  Link
--PlayStation3--
Posts: n/a
Do I need to have a surround sound receiver in order to test if a file I converted with '5.1 CT AAC-LC 320kbps[cbr]' will work on the 360 or PS3? The 360 doesn't play the file and the PS3 tells me that the audio cannot be read, but video plays fine.
Old 3rd January 2008, 01:32   #411  |  Link
Atak_Snajpera
Unfortunately you need new receiver with AAC support otherwise PS3 (v2.10) will downmix to stereo (if you unchecked AAC in Audio Settings)
5.1 AAC is not even downmixed on XBOX360
Old 3rd January 2008, 01:36   #412  |  Link
--PlayStation3--
Posts: n/a
So if I simply have an HDTV(which I'm guessing is Stereo) and no other receiver, and I try to play it on the 360: it won't work at all, and, playing it on the PS3: only video will work?
Old 3rd January 2008, 01:54   #413  |  Link
Atak_Snajpera
I have only access to PS3 so I will describe how it works on that console. If I select AAC in audio settings video plays fine but I have no audio (receiver doesn't recognize AAC stream). if AAC is not selected I have only stereo. if you need receiver with AAC support check this http://forum.doom9.org/showthread.ph...82#post1080982
Old 3rd January 2008, 02:07   #414  |  Link
--PlayStation3--
Posts: n/a
I understand now. 1 channel of the audio works now after I enabled AAC and DTS 5.1.
Old 3rd January 2008, 02:32   #415  |  Link
survivant001
@Atak_Snajpera did you check the bug for my movie with DIB instead ofr UYV12 ? the .avs isn't right
survivant001 is offline   Reply With Quote
Old 3rd January 2008, 06:07   #416  |  Link
DJ_Price
Where do the mp4 files go on the psp? I tried them in VIDEO, but nothing or do they have to be renamed to the old style naming to work?
Old 3rd January 2008, 08:13   #417  |  Link
--PlayStation3--
Posts: n/a
What is Normalizing? For the audio. It gives me 3 options, OFF; 100%, 200%. Default is OFF for imported .dts track. Which should I choose?
Old 3rd January 2008, 11:54   #418  |  Link
survivant001
@Atak_Snajpera
i'm trying to convert a movie using CQF. I try 22 and 18.. each time I obtain a movie of 1.8 gigs. THe source is 4 gigs.
any idea why ?
D:\DVD-convertion\encode\temp>"D:\DVD-tools\tools\AutoMKV093_NORIP\exe\encoder\x
264.exe" movie.avs --crf 18 --level 4.1 --filter 0,0 --aq-strength 0.5 --aq-sen
sitivity 5 --ref 3 --mixed-refs --bframes 3 --b-pyramid --b-rdo --bime -
-weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x
8dct --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --au
d --nal-hrd --sar 1:1 --vbv-bufsize 14745 --vbv-maxrate 16000 --output movie_rip
bot.264
avis [info]: 1280x720 @ 23.98 fps (109920 frames)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX MMXEXT SSE SSE2 3DNow!
x264 [info]: slice I:1496 Avg QP:12.53 size: 94007a 0:00:00
x264 [info]: slice P:82354 Avg QP:14.45 size: 21911
x264 [info]: slice B:26070 Avg QP:17.02 size: 7155
x264 [info]: mb I I16..4: 30.2% 22.1% 47.7%
x264 [info]: mb P I16..4: 7.0% 4.5% 3.7% P16..4: 39.2% 4.6% 3.5% 0.0% 0
.0% skip:37.6%
x264 [info]: mb B I16..4: 0.8% 0.6% 0.7% B16..8: 19.9% 1.0% 2.0% direct:
2.1% skip:72.9%
x264 [info]: 8x8 transform intra:28.7% inter:39.4%
x264 [info]: direct mvs spatial:98.8% temporal:1.2%
x264 [info]: ref P 85.6% 9.1% 5.3%
x264 [info]: ref B 84.1% 10.2% 5.7%
x264 [info]: kb/s:3719.6
encoded 109920 frames, 5.38 fps, 3723.62 kb/s
Old 3rd January 2008, 12:33   #419  |  Link
Atak_Snajpera
Don't worry I'm working at new version.
Did you update your firmware? The latest is 3.80.
Use 100% . 200% was added mainly for PSP users due to low volume on speakers.
Old 3rd January 2008, 14:23   #420  |  Link
DJ_Price
I have the latest custom firmware, 3.71-M33-4.
