28th October 2015, 19:23 | #2602 | Link | |
Edit: sorry, it was not avisynth based. It seems that avisynth based deinterlacer is the problem, just checked it. Last edited by den78; 28th October 2015 at 19:28. |
28th October 2015, 19:26 | #2603 | Link |
"Yadif" = done through ffmpeg or mencoder
OR "Yadif (Avisynth)" = applied through avisynth -> make sure you try "Yadif (Avisynth)" otherwise we don't know whether this is a decoder or a deinterlacer problem. Also, have you remuxed the file (with the timecode extraction disabled)? Did the new file then still play sync ? Did you then reencode that file? Cu Selur |
28th October 2015, 19:37 | #2604 | Link |
Did all that & the result is still not good. Btw, with yadif avisynth i get this & it's out of sync too.
& btw, remuxed file in mkv plays like the original ts, so no problem there. Last edited by den78; 28th October 2015 at 19:40. |
28th October 2015, 19:59 | #2605 | Link | |
Here's how I produce a sync file, step-by-step from your sample:
Cu Selur Last edited by Selur; 28th October 2015 at 20:03. |
28th October 2015, 20:10 | #2606 | Link | |
Thanks |
28th October 2015, 20:51 | #2610 | Link |
You might also want to report the problem in the LibAvSource-thread, assuming replacing the LSMASHSource.dll inside the avisynthPlugins-folder with the latest one, doesn't help.
Cu Selur |
29th October 2015, 11:52 | #2611 | Link |
What? This has nothing to do with AVSMeter but missing dependencies for one or more plugins in the auto-load directory. Avisynth will throw errors about missing dependencies once you initialize IScriptEnvironment.
29th October 2015, 15:43 | #2612 | Link |
HI I have encoding some files my blu-ray from makemkv then with hybrid but one of the movies I get crash what can it be ? alle the other file work
exitCode -1073741787 encoding are video x265 audio passthrogh all crf 22 preset ultrafast |
29th October 2015, 17:37 | #2613 | Link | |
@tola5: read http://www.selur.de/support, the infos you present are far from useful
29th October 2015, 17:54 | #2614 | Link | |
30th October 2015, 05:08 | #2620 | Link |
hi selur, how to change audio to 2.0 channels?
i have download video, with 8.0 channels, and encoding using hybrid with these setting - check reencode - Qaac - aac, high efficency - DRC: film standard - Downmix: to stereo and the result is still 8 channel, please help me, thank you |
